MBRS1535CT – MBRS15150CT
Taiwan Semiconductor
15A, 35V - 150V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
15
A
VRRM
35 - 150
V
IFSM
150
A
TJ MAX
150
APPLICATIONS
°C
2
Package
TO-263AB (D PAK)
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.37g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse
(1)
surge current
Peak repetitive forward
current (Rated VR, Square
wave, 20KHz)
Critical rate of rise of offstate voltage
Notes:
1. tp = 2.0μs, 1.0KHz
MBRS
SYMBOL 1535
CT
MBRS
1535CT
MBRS
1545
CT
MBRS
1545CT
MBRS
1550
CT
MBRS
1550CT
MBRS
1560
CT
MBRS
1560CT
MBRS MBRS MBRS
1590 15100 15150 UNIT
CT
CT
CT
MBRS MBRS
MBRS
1590CT 15100CT 15150CT
VRRM
35
45
50
60
90
100
150
V
VR(RMS)
24
31
35
42
63
70
105
V
IF
15
A
IFSM
150
A
IRRM
1
0.5
A
IFRM
15
A
dv/dt
10,000
V/μs
1
Version: L2103
PARAMETER
MBRS MBRS MBRS MBRS MBRS MBRS
SYMBOL 1535 1545 1550 1560 1590 15100
CT
CT
CT
CT
CT
CT
MBRS
15150 UNIT
CT
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
50
°C/W
Junction-to-case thermal resistance
RӨJC
2
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per
(1)
diode
CONDITIONS
MBRS1535CT
MBRS1545CT
MBRS1550CT
MBRS1560CT
MBRS1590CT
MBRS15100CT
MBRS15150CT
MBRS1535CT
MBRS1545CT
MBRS1550CT
MBRS1560CT
MBRS1590CT
MBRS15100CT
MBRS15150CT
MBRS1535CT
MBRS1545CT
MBRS1550CT
MBRS1560CT
MBRS1590CT
MBRS15100CT
MBRS15150CT
MBRS1535CT
MBRS1545CT
MBRS1550CT
MBRS1560CT
MBRS1590CT
MBRS15100CT
MBRS15150CT
SYMBOL
IF = 7.5A, TJ = 25°C
IF = 15.0A, TJ = 25°C
VF
IF = 7.5A, TJ = 125°C
IF = 15.0A, TJ = 125°C
2
TYP
MAX
UNIT
V
0.75
V
0.92
V
0.95
V
0.84
V
V
V
V
0.57
V
0.65
V
0.82
V
0.92
V
0.72
V
V
V
V
Version: L2103
PARAMETER
Reverse current @ rated VR
(2)
per diode
CONDITIONS
MBRS1535CT
MBRS1545CT
MBRS1550CT
MBRS1560CT TJ = 25°C
MBRS1590CT
MBRS15100CT
MBRS15150CT
MBRS1535CT
MBRS1545CT
MBRS1550CT
MBRS1560CT TJ = 125°C
MBRS1590CT
MBRS15100CT
MBRS15150CT
SYMBOL
TYP
MAX
UNIT
100
µA
15
mA
10
mA
5
mA
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
MBRS15xCT
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. “x” defines voltage from 35V(MBRS1535CT) to 150V(MBRS15150CT)
3
Version: L2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
15
CAPACITANCE (pF)
10
5
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
1
TJ=75°C
0.1
TJ=25°C
MBRS1535CT-1545CT
MBRS1550CT-15150CT
0.0001
10
40
50
60
70
80
90 100
100 10
10
UF1DLW
T =125°C
1
J
TJ=125°C
TJ=25°C
TJ=25°C
0.1
Pulse width 300μs
1% duty cycle
1
0.01
MBRS1535CT-1545CT
MBRS1550CT-1560CT
MBRS1590CT-15150CT
Pulse width
0.1
0.001
0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
TJ=125°C
0.001
100
Fig.4 Typical Forward Characteristics
100
0.01
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
MBRS1535CT-1545CT
MBRS1550CT-1560CT
MBRS1590CT-15150CT
(A)
AVERAGE FORWARD CURRENT (A)
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: L2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: L2103
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: L2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: L2103
很抱歉,暂时无法提供与“MBRS15100CTHMNG”相匹配的价格&库存,您可以联系我们找货
