SFAF507GHC0G
SFAF507GHC0G
    TAIWANSEMICONDUCTOR(台半)
    TO220-2
    DIODE GEN PURP 500V 5A ITO220AC
SFAF507GHC0G 数据手册
SFAF501G – SFAF508G Taiwan Semiconductor 5A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High reliability High surge current capability Low power loss UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 5 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C Package ITO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SFAF 501G SFAF 501G SFAF 502G SFAF 502G SFAF 503G SFAF 503G SFAF 504G SFAF 504G SFAF 505G SFAF 505G SFAF 506G SFAF 506G SFAF 507G SFAF 507G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V SYMBOL SFAF UNIT 508G SFAF 508G IF 5 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: I2105 SFAF501G – SFAF508G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 5 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS SFAF501G SFAF502G SFAF503G SFAF504G SFAF505G SFAF506G SFAF507G SFAF508G (1) Reverse current @ rated VR (2) Junction capacitance Reverse recovery time IF = 5A, TJ = 25°C TJ = 25°C TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 10 µA - 400 µA CJ 70 - pF trr - 35 ns VF IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SFAF5xG ITO-220AC 50 / Tube SFAF5xGH ITO-220AC 50 / Tube Notes: 1. “x” defines voltage from 50V(SFAF501G) to 600V(SFAF508G) 2. “H” means AEC-Q101 qualified 2 Version: I2105 SFAF501G – SFAF508G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 5 CAPACITANCE (pF) 4 3 2 100 10 1 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 1 150 10 CASE TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=100°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 10 10 SFAF501G-504G 1 UF1DLW TJ=125°C TJ=25°C SFAF505G-506G 0.1 1 0.01 SFAF507G-508G 0.001 0.1 0.3 0.4 0.5 0.2 0.4 0.6 0.8 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width Pulse width 300μs 1% duty cycle 0.6 1 0.7 0.8 0.9 1 1.2 1.4 1.6 1.8 2 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 6 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2105 1.2 SFAF501G – SFAF508G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: I2105 SFAF501G – SFAF508G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: I2105 SFAF501G – SFAF508G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2105
SFAF507GHC0G 价格&库存
很抱歉,暂时无法提供与“SFAF507GHC0G”相匹配的价格&库存,您可以联系我们找货
