BZD17C11P – BZD17C220P
Taiwan Semiconductor
0.8W, 11V - 220V Zener Diode
FEATURES
KEY PARAMETERS
Silicon zener diodes
Low profile surface-mount package
Zener and surge current specification
Low leakage current
Excellent stability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
11 - 220
V
Test current IZT
4 - 50
mA
Ptot
0.8
W
TJ MAX
175
°C
Package
Sub SMA
Configuration
Single die
APPLICATIONS
● Voltage regulating
● Reference voltage
● Protection circuit
MECHANICAL DATA
Case: Sub SMA
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.019g (approximately)
Sub SMA
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
VF
1.2
V
2.3
W
0.8
W
PZSM
300
W
Junction temperature
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
Forward voltage @ IF = 0.2A
TL = 80°C
Power dissipation
TA = 25°C
Non-repetitive peak pulse power dissipation
100μs square pulse
(2)
(1)
Ptot
Notes:
1. Mounted on Cu-Pad size 5mm x 5mm
2. TJ = 25°C prior to surge
1
Version: L2103
THERMAL PERFORMANCE
PARAMETER
Junction-to-lead thermal resistance
Junction-to-ambient thermal resistance
(1)
SYMBOL
TYP
UNIT
RӨJL
30
°C/W
RӨJA
180
°C/W
Notes:
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
BZD17CxP
Sub SMA
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 11V(BZD17C11P) to 220V(BZD17C220P)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Working
Voltage
Part
number
Marking
code
VZ @ IZT
Differential
Resistance
Temperature
Coefficient
Test
Current
rdif @ IZ
αZ @ IZ
IZT
IR
VR
mA
μA
V
(1)
o
Ω
V
%/ C
Min
Max
Typ
Max
Min
Max
Reverse Current@
Reverse Voltage
Max
BZD17C11P
J2
10.4
11.6
4
7
0.05
0.10
50
4.0
8.2
BZD17C12P
J3
11.4
12.7
4
7
0.05
0.10
50
3.0
9.1
BZD17C13P
J4
12.4
14.1
5
10
0.05
0.10
50
2.0
10
BZD17C15P
J5
13.8
15.6
5
10
0.05
0.10
25
1.0
11
BZD17C16P
J6
15.3
17.1
6
15
0.06
0.11
25
1.0
12
BZD17C18P
J7
16.8
19.1
6
15
0.06
0.11
25
1.0
13
BZD17C24P
K0
22.8
25.6
7
15
0.06
0.11
25
1.0
18
BZD17C27P
K1
25.1
28.9
7
15
0.06
0.11
25
1.0
BZD17C33P
K3
31
35
8
15
0.06
0.11
25
1.0
24
BZD17C36P
K4
34
38
21
40
0.06
0.11
10
1.0
27
BZD17C39P
K5
37
41
21
40
0.06
0.11
10
1.0
30
BZD17C43P
K6
40
46
24
45
0.07
0.12
10
1.0
33
BZD17C47P
K7
44
50
24
45
0.07
0.12
10
1.0
36
BZD17C51P
K8
48
54
25
60
0.07
0.12
10
1.0
39
BZD17C62P
L0
58
66
25
80
0.08
0.13
10
1.0
47
BZD17C68P
L1
64
72
25
80
0.08
0.13
10
1.0
51
BZD17C75P
L2
70
79
30
100
0.08
0.13
10
1.0
56
BZD17C100P
L5
94
106
60
200
0.09
0.13
4
1.0
75
BZD17C120P
L7
114
127
150
300
0.09
0.13
4
1.0
91
BZD17C180P
M1
168
191
280
450
0.09
0.13
4
1.0
130
BZD17C200P
M2
188
212
350
750
0.09
0.13
4
1.0
150
BZD17C220P
M3
208
233
430
900
0.09
0.13
4
1.0
160
Notes:
1.
Pulse test: tp ≦5ms.
2
Version: L2103
CHARACTERISTICS CURVES
Fig.1 Power Dissipation vs. Ambient Temperature
Fig.2 Typical Junction Capacitance
1000
TL
2.0
C12P
CAPACITANCE (pF)
POWER DISSIPATION(W)
2.4
1.6
1.2
TA
0.8
100
C27P
0.4
C200P
0.0
25
55
85
115
145
10
175
TEMPERATURE (°C)
1
2
3
REVERSE VOLTAGE (V)
1010
1
UF1DLW
TJ=125°C
TJ=25°C
10.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
Fig.3 Typical Forward Characteristics
0.01
0.1
0.001
0.7
0.3
Pulse width
0.4
0.8
0.5
0.9
0.6
0.7
1.0
0.8
0.9
1.1
1
1.1
1.2
FORWARD VOLTAGE (V)
3
Version: L2103
PACKAGE OUTLINE DIMENSIONS
Sub SMA
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: L2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: L2103
很抱歉,暂时无法提供与“BZD17C12P R3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+3.065252+0.37155
- 10+2.6236410+0.31802
- 100+1.79917100+0.21808
- 500+1.48745500+0.18030
- 1800+1.253661800+0.15196
- 3600+0.810543600+0.09825
- 5400+0.780745400+0.09464
- 9000+0.714349000+0.08659
- 23400+0.7032723400+0.08525
- 45000+0.6922045000+0.08391
