GBL005 – GBL10
Taiwan Semiconductor
4A, 50V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
Ideal for printed circuit board
High case dielectric strength
Typical IR less than 0.1μA
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
4
A
VRRM
50 - 1000
V
IFSM
150
A
TJ MAX
150
°C
Package
GBL
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: GBL
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 2.00g (approximately)
GBL
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
GBL
005
GBL
01
GBL
02
GBL
04
GBL
06
GBL
08
GBL
10
UNIT
GBL005 GBL01 GBL02 GBL04 GBL06 GBL08 GBL10
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
700
V
4
A
3
A
IFSM
150
A
It
2
93
As
Junction temperature
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
Forward current
TC = 50°C
TA = 40°C
Surge peak forward current,
8.3ms single half sine-wave
superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“GBL10HD2G”相匹配的价格&库存,您可以联系我们找货
