SFF1602G C0G
SFF1602G C0G
    TAIWANSEMICONDUCTOR(台半)
    TO220-3
    DIODE GEN PURP 100V 16A ITO220AB
SFF1602G C0G 数据手册
SFF1601G – SFF1608G Taiwan Semiconductor 16A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High reliability High surge current capability Low power loss UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 16 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C Package ITO-220AB Configuration Dual dies APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL SFF Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SFF SFF SFF SFF SFF SFF SFF SFF 1601G 1602G 1603G 1604G 1605G 1606G 1607G 1608G SFF SFF SFF SFF SFF SFF UNIT SFF 1601G 1602G 1603G 1604G 1605G 1606G 1607G 1608G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V IF 16 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: I2105 SFF1601G – SFF1608G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1.5 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 10 µA - 400 µA 80 - pF 50 - pF - 35 ns SFF1601G SFF1602G SFF1603G Forward voltage per diode (1) SFF1604G SFF1605G IF = 8A,TJ = 25°C VF SFF1606G SFF1607G SFF1608G Reverse current @ rated VR per diode (2) TJ = 25°C TJ = 125°C IR SFF1601G SFF1602G SFF1603G Junction capacitance per diode SFF1604G SFF1605G 1MHz, VR = 4.0V CJ SFF1606G SFF1607G SFF1608G Reverse recovery time IF = 0.5A, IR = 1.0A Irr = 0.25A trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SFF16xG ITO-220AB 50 / Tube SFF16xGH ITO-220AB 50 / Tube Notes: 1. “x” defines voltage from 50V(SFF1601G) to 600V(SFF1608G) 2. “H” means AEC-Q101 qualified 2 Version: I2105 SFF1601G – SFF1608G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 90 16 CAPACITANCE (pF) 12 8 4 SFF1601G-1604G 80 70 SFF1605G-1608G 60 f=1.0MHz Vsig=50mVp-p 50 0 40 25 50 75 100 125 150 1 10 CASE TEMPERATURE (°C) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=100°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 100 10 SFF1601G-1604G 10 1 UF1DLW SFF1605G-1606G TJ=125°C TJ=25°C 0.1 1 SFF1607G-1608G 0.01 0.1 0.001 0.4 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.6 0.8 0.4 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.0 0.6 1.2 0.7 1.4 0.8 1.6 0.9 1 1.8 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 20 125 8.3ms single half sine wave 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2105 1.2 SFF1601G – SFF1608G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: I2105 SFF1601G – SFF1608G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: I2105 SFF1601G – SFF1608G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2105
SFF1602G C0G 价格&库存
很抱歉,暂时无法提供与“SFF1602G C0G”相匹配的价格&库存,您可以联系我们找货
