1N5391G – 1N5399G
Taiwan Semiconductor
1.5A, 50V - 1000V Standard Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High efficiency, Low VF
High current capability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1.5
A
VRRM
50 - 1000
V
IFSM
50
A
TJ MAX
150
°C
Package
DO-204AC (DO-15)
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● General purpose
MECHANICAL DATA
Case: DO-204AC (DO-15)
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.400g (approximately)
DO-204AC (DO-15)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward
current, 8.3ms single half
sine wave superimposed
on rated load
Junction temperature
Storage temperature
SYMBOL
1N
1N
1N
1N
1N
1N
1N
UNIT
5391G 5392G 5393G 5395G 5397G 5398G 5399G
1N
1N
1N
1N
1N
1N
1N
VRRM
50
100
200
400
600
800
1000
V
VR(RMS)
35
70
140
280
420
560
700
V
IF
1.5
A
IFSM
50
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: F2105
1N5391G – 1N5399G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
65
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
Reverse current @ rated VR
(2)
CONDITIONS
1N5391G
1N5392G
1N5393G
1N5395G IF = 1.5A, TJ = 25°C
1N5397G
1N5398G
1N5399G
TJ = 25°C
Junction capacitance
TJ = 125°C
1MHz, VR = 4.0V
SYMBOL
TYP
MAX
UNIT
1.1
V
1.0
V
5
µA
100
µA
15
pF
VF
IR
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
1N539xG
DO-204AC (DO-15)
3,500 / Tape & Reel
1N539xG A0G
DO-204AC (DO-15)
1,500 / Ammo box
1N539xGH
DO-204AC (DO-15)
3,500 / Tape & Reel
1N539xGHA0G
DO-204AC (DO-15)
1,500 / Ammo box
Notes:
1. "x" defines voltage from 50V (1N5391G) to 1000V (1N5399G)
2. “H” means AEC-Q101 qualified
2
Version: F2105
1N5391G – 1N5399G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
1.5
CAPACITANCE (pF)
1
0.5
10
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
0.1
150
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
TJ=75°C
0.1
TJ=25°C
0.01
10
40
50
60
70
80
90
100
1010
UF1DLW
1N5393G-1N5399G
1
TJ=125°C
TJ=25°C
10.1
1N5391G-1N5392G
0.01
0.1
0.001
0.70.3
Pulse
Pulse width
width 300μs
300μs
1% duty cycle
Pulse width
0.8
0.4
0.9
0.5
0.6 1 0.7 1.10.8
1.2
0.9
11.3
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
60
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.4 Typical Forward Characteristics
100
1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
2
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: F2105
1.2
1N5391G – 1N5399G
PACKAGE OUTLINE DIMENSIONS
DO-204AC (DO-15)
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: F2105
1N5391G – 1N5399G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: F2105
很抱歉,暂时无法提供与“1N5393GHA0G”相匹配的价格&库存,您可以联系我们找货
