SMAJ Series
TRANSIENT VOLTAGE SUPPRESSOR
FEATURE
Plastic package.
Glass passivated chip junction in SMA Package
Excellent clamping capability.
Low zener impedance.
400W peak pulse power capability on 10/1000μs waveform.
Typical IR less than 1μA above 13V.
Fast response time: typically less than 1.0ps from 0 Volts to BV min.
High temperature soldering guaranteed: 265℃/10 seconds
MECHANICAL DATE
Case: JEDEC SMA Molded Plastic.
Terminals: Axial leads, solderable per MIL-STD-750, Method 2026.
Polarity: Color band denoted cathode except bidirectional.
Mounting Position: Any.
MAXIMUM RATINGS AND CHRACTERISTICS
Ratings at 25ć ambient temperature unless otherwise specified.
RATING
SYMBOL
VALUE
UNITS
Peak Pulse Power Dissipation on 10/1000us waveform
(Note1, Fig.1).
PPPM
Minimum 400
Watts
Peak Pulse Current of on 10/1000us waveform.(Note1,Fig.3)
IPPM
See Table
Amps
Steady State Power Dissipation at TL =75℃,Lead lengths.375",
(9.5mm) (Fig.5).
PM(AV)
3.3
Watts
Peak Forward Surge Current,8.3ms Single Half Sine-Wave
Superimposed on Rated Load, (JEDEC Method) (Note 2,Fig.6).
IFSM
40
Amps
Operating junction and Storage Temperature Range.
TJ , TSTG
-55 to +150
Notes:
1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig. 2.
2. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per
minutes maximum.
1/4
SMAJ Series
Item
A
B
C
D
E
F
G
H
I
J
K
L
Millimeters
Min.
Max.
1.25
1.65
3.99
4.5
2.54
2.79
1.98
2.29
0.78
1.52
0.203
4.93
5.28
0.152
0.305
1.8
2.1
2.3
2.1
Inches
Min.
Max.
0.049
0.065
0.157
0.177
0.1
0.11
0.078
0.09
0.03
0.06
0.008
0.194
0.208
0.006
0.012
0.07
0.082
0.09
0.082
ELECTRICAL CHARACTERISTICS
Part Number
Marking
Reverse
Breakdown
Breakdown
Reverse
Test
Peak
Maximum
Stand-Off
Voltage
Voltage
Leakage
Current
Pulse
Voltage
NIN.@IT
MAX.@IT
@VRWM
Clamping
Voltage
@IPP
Current
UNT
BI
UNT
BI
VR(V)
VBL(V)
VBH(V)
IR(uA)
IT(mA)
IPP(A)
VCH(V)
SMAJ5.0A
SMAJ5.0CA
AE
WE
5.0
6.40
7.00
800
10
43.5
9.2
SMAJ6.0A
SMAJ6.0CA
AG
WG
6.0
6.67
7.37
800
10
38.8
10.3
SMAJ6.5A
SMAJ6.5CA
AK
WK
6.5
7.22
7.98
500
10
35.7
11.2
SMAJ7.0A
SMAJ7.0CA
AM
WM
7.0
7.78
8.60
200
10
33.3
12.0
SMAJ7.5A
SMAJ7.5CA
AP
WP
7.5
8.33
9.21
100
1
31.0
12.9
SMAJ8.0A
SMAJ8.0CA
AR
WR
8.0
8.89
9.83
50
1
29.4
13.6
SMAJ8.5A
SMAJ8.5CA
AT
WT
8.5
9.44
10.40
27.8
14.4
SMAJ9.0A
SMAJ9.0CA
AV
WV
9.0
10.00
11.10
10
1
26.0
15.4
SMAJ10A
SMAJ10CA
AX
WX
10
11.10
12.30
5
1
23.5
17.0
SMAJ11A
SMAJ11CA
AZ
WZ
11
12.20
13.50
1
1
22.0
18.2
SMAJ12A
SMAJ12CA
BE
XE
12
13.30
14.70
1
1
20.1
19.9
SMAJ13A
SMAJ13CA
BG
XG
13
14.40
15.90
1
1
18.6
21.5
2/4
SMAJ Series
Part Number
Breakdown
Breakdown
Reverse
Test
Peak
Maximum
Stand-Off
Voltage
Voltage
Leakage
Current
Pulse
Voltage
NIN.@IT
MAX.@IT
@VRWM
Current
Clamping
Voltage
@IPP
BI
VR(V)
VBL(V)
VBH(V)
IR(uA)
IT(mA)
IPP(A)
VCH(V)
SMAJ14A
SMAJ14CA
BK
XK
14
15.60
17.20
1
1
17.2
23.2
SMAJ15A
SMAJ15CA
BM
XM
15
16.70
18.50
1
1
16.4
24.4
SMAJ16A
SMAJ16CA
BP
XP
16
17.80
19.70
1
1
15.4
26.0
SMAJ17A
SMAJ17CA
BR
XR
17
18.90
20.90
1
1
14.5
27.6
SMAJ18A
SMAJ18CA
BT
XT
18
20.00
22.10
1
1
13.7
29.2
SMAJ20A
SMAJ20CA
BV
XV
24.50
1
1
12.3
32.4
SMAJ22A
SMAJ22CA
BX
XX
22
24.40
26.90
1
1
11.3
35.5
SMAJ24A
SMAJ24CA
BZ
XZ
24
26.70
29.50
1
1
10.3
38.9
SMAJ26A
SMAJ26CA
CE
YE
26
28.90
31.90
1
1
9.5
42.1
SMAJ28A
SMAJ28CA
CG
YG
28
31.10
34.40
1
1
8.8
45.4
SMAJ30A
SMAJ30CA
CK
YK
30
33.30
36.80
1
1
8.3
48.4
SMAJ33A
SMAJ33CA
CM
YM
33
40.00
44.20
1
1
6.9
58.1
SMAJ36A
SMAJ36CA
CP
YP
36
36.70
40.60
1
1
7.5
53.3
SMAJ40A
SMAJ40CA
CR
YR
40
44.40
49.10
1
1
6.2
64.5
SMAJ43A
SMAJ43CA
CT
YT
43
47.80
52.80
1
1
5.8
69.4
SMAJ45A
SMAJ45CA
CV
YV
45
50.00
55.30
1
1
5.5
72.7
SMAJ48A
SMAJ48CA
CX
YX
48
53.30
58.90
1
1
5.2
77.4
SMAJ51A
SMAJ51CA
CZ
YZ
51
56.70
62.70
1
1
4.9
82.4
SMAJ54A
SMAJ54CA
RE
ZE
54
60.00
66.30
1
1
4.6
87.1
SMAJ58A
SMAJ58CA
RG
ZG
58
64.40
71.20
1
1
4.3
93.6
SMAJ60A
SMAJ60CA
RK
ZK
60
66.70
73.70
1
1
4.1
96.8
SMAJ64A
SMAJ64CA
RM
ZM
64
71.10
78.60
1
1
3.9
103
SMAJ70A
SMAJ70CA
RP
ZP
70
77.80
86.00
1
1
3.5
113
SMAJ75A
SMAJ75CA
RR
ZR
75
83.30
92.10
1
1
3.3
121
SMAJ78A
SMAJ78CA
RT
ZT
78
86.70
95.80
1
1
3.2
126
SMAJ85A
SMAJ85CA
RV
ZV
85
94.4
104.0
1
1
2.9
137
SMAJ90A
SMAJ90CA
RX
ZX
90
100.0
111.0
1
1
2.7
146
SMAJ100A
SMAJ100CA
RZ
ZZ
100
111.0
123.0
1
1
2.5
162
SMAJ110A
SMAJ110CA
SE
VE
110
122.0
135.0
1
1
2.3
177
SMAJ120A
SMAJ120CA
SG
VG
120
133.0
147.0
1
1
2.1
193
SMAJ130A
SMAJ130CA
SK
VK
130
144.0
159.0
1
1
1.9
209
SMAJ150A
SMAJ150CA
SM
VM
150
167.0
185.0
1
1
1.6
243
SMAJ160A
SMAJ160CA
SP
VP
160
178.0
197.0
1
1
1.5
259
SMAJ170A
SMAJ170CA
SR
VR
170
189.0
209.0
1
1
1.5
275
SMAJ180A
SMAJ180CA
ST
VT
180
201.0
222.0
1
1
1.4
292
SMAJ190A
SMAJ190CA
SU
YU
190
209.0
243.0
1
1
1.3
308
SMAJ200A
SMAJ200CA
SW
YW
200
224.0
247.0
1
1
1.2
324
SMAJ220A
SMAJ220CA
GE
VX
220
246.0
272.0
1
1
1.1
356
SMAJ250A
SMAJ250CA
SZ
VZ
250
279.0
309.0
1
1
1.0
405
SMAJ300A
SMAJ300CA
TE
UE
300
335.0
371.0
1
1
0.8
486
SMAJ350A
SMAJ350CA
TG
UG
350
391.0
432.0
1
1
0.7
567
SMAJ400A
SMAJ400CA
TK
UK
400
447.0
494.0
1
1
0.6
648
SMAJ440A
SMAJ440CA
TM
UM
440
492.0
543.0
1
1
0.6
713
UNT
BI
Marking
Reverse
UNT
Notes: For bidirectional type having VRWM of 10 volts and less, the IR limit is double.
3/4
SMAJ Series
RATINGS AND CHARACTERISTIC CURVES (TA=25℃ unless otherwise noted)
Figure 1 - Peak Pulse Power Rating Curve
Figure 2 - Pulse Derating Curve
Figure 3 - Pulse Waveform
Figure 4 - Typical Junction Capacitance
Uni-Directional
Figure 5 - Steady State Power Dissipation
Derating Curve
Figure 6 - Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
4/4
很抱歉,暂时无法提供与“SMAJ15CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.10530
- 10+0.10140
- 100+0.09204
- 500+0.08736
- 国内价格
- 20+0.18031
- 200+0.14429
- 600+0.12429
- 5000+0.10804
- 10000+0.09764
- 20000+0.09203
