SIT3373AC-4E3-25NU307.695484
    SITIME
    SMD7050_6P_EP
    有源晶振 2.5V 307.695484MHz SMD-6
SIT3373AC-4E3-25NU307.695484 数据手册
SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Description Features The SiT3373 is a 220.000001 MHz to 725 MHz differential MEMS VCXO engineered for low-jitter applications. Utilizing SiTime’s unique DualMEMS® temperature sensing and TurboCompensation® technology, the SiT3373 delivers exceptional dynamic performance by providing resistance to airflow, thermal gradients, shock and vibration. This device also integrates multiple on-chip regulators to filter power supply noise, eliminating the need for a dedicated external LDO. ◼ The SiT3373 can be factory programmed for any combination of frequency, stability, voltage, output signaling, and pull range. Programmability enables designers to optimize clock configurations while eliminating long lead times and customization costs associated with quartz devices where each frequency is custom built. The wide frequency range and programmability makes this device ideal for telecom, networking, and industrial applications that require a variety of pullable frequencies and operate in noisy environments. ◼ ◼ ◼ ◼ ◼ Any frequency between 220.000001 MHz and 725 MHz accurate to 6 decimal places (For frequencies 1 MHz to 220 MHz, refer to SiT3372) Widest pull range options: ±25, ±50, ±80, ±100, ±150, ±200, ±400, ±800, ±1600, ±3200 ppm 0.225 ps RMS phase jitter (typ) over 12 kHz to 20 MHz bandwidth Frequency stability as low as ±15 ppm Wide temperature range support from -40°C to 105°C Industry-standard packages: 7.0 x 5.0 mm, 5.0 x 3.2 mm, 3.2 x 2.5 mm packages Applications ◼ ◼ ◼ Cable Modem Termination System (CMTS), Video, Broadcasting System, Audio, Industrial Sensors, Remote Radio Head (RRH) SATA, SAS, 10/40/100/400 Gbps Ethernet, Fibre Channel, PCI-Express Optical Transport Network (OTN) Refer to Manufacturing Notes for proper reflow profile, tape and reel dimension, and other manufacturing related information. Block Diagram 3.2 x 2.5 mm Package Pinout Figure 1. SiT3373 Block Diagram Rev 1.07 VIN 1 6 VDD NC 2 5 OUT- GND 3 4 OUT+ Figure 2. Pin Assignments (Top view) (Refer to Table 6 for Pin Descriptions) 20 July 2021 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Ordering Information SiT3373AC -1B2-33NH 220.123456T Part Family Packaging “SiT3373” “T”, “Y”, “D” or “E” Refer to table below for packing method Leave Blank for Bulk[1] Revision Letter “A” is the revision of Silicon Frequency 220.000001 MHz to 725.000000 MHz Temperature Range “C”: Extended Commercial, -20 to 70°C “ I ” : Industrial, -40 to 85°C “B”: -40 to 95°C “E”: Extended Industrial, -40 to 105°C Pull Range Options[2] “M”: ±25 ppm “B”: ±50 ppm “C”: ±80 ppm “E”: ±100 ppm “G”: ±150 ppm “H”: ±200 ppm “X”: ±400 ppm “Y”: ±800 ppm “Z”: ±1600 ppm “U”: ±3200 ppm Signalling Type “1”: LVPECL “2”: LVDS “4”: HCSL Package Size “B”: 3.2 x 2.5 mm “C”: 5.0 x 3.2 mm with center pad “E”: 7.0 x 5.0 mm with center pad [3] Feature Pin “N”: No Connect “E”: Output Enable Frequency Stability “H”: “2”: “9”: “3”: Voltage Supply ±15 ppm ±25 ppm ±35 ppm ±50 ppm “25”: 2.5 V ±10% “28”: 2.8 V ±10% “30”: 3.0 V ±10% “33”: 3.3 V ±10% Notes: 1. Bulk is available for sampling only. 2. Contact SiTime for custom pull range options. 3. “E”: Output Enable function is only available in 7.0 x 5.0 mm and 5.0 x 3.2 mm packages. Table 1. Ordering Codes for Supported Tape & Reel Packing Method Device Size (mm x mm) 8 mm T&R (3ku) 8 mm T&R (1ku) 7.0 x 5.0 – – 5.0 x 3.2 – – 3.2 x 2.5 D E T Rev 1.07 12 mm T&R (3ku) 12 mm T&R (1ku) 16 mm T&R (3ku) 16 mm T&R (1ku) – – T Y T Y – – Y – – Page 2 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO TABLE OF CONTENTS Description....................................................................................................................................................................................1 Features .......................................................................................................................................................................................1 Applications ..................................................................................................................................................................................1 Block Diagram ..............................................................................................................................................................................1 Ordering Information .....................................................................................................................................................................2 Electrical Characteristics ..............................................................................................................................................................4 Waveform Diagrams ...................................................................................................................................................................10 Timing Diagrams ........................................................................................................................................................................11 Termination Diagrams ................................................................................................................................................................12 LVPECL ...............................................................................................................................................................................12 LVDS ...................................................................................................................................................................................13 HCSL ...................................................................................................................................................................................13 Dimensions and Patterns ― 3.2 x 2.5 mm .................................................................................................................................14 Dimensions and Patterns ― 5.0 x 3.2 mm .................................................................................................................................14 Dimensions and Patterns ― 7.0 x 5.0 mm .................................................................................................................................15 Additional Information .................................................................................................................................................................16 Revision History ..........................................................................................................................................................................17 Rev 1.07 Page 3 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Electrical Characteristics Table 2. Electrical Characteristics – Common to LVPECL, LVDS and HCSL All Min and Max limits in the Electrical Characteristics tables are specified over temperature and rated operating voltage with standard output termination shown in the termination diagrams. Typical values are at 25°C and nominal supply voltage. Parameter Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f 220.000001 – 725 MHz Accurate to 6 decimal places Frequency Stability Frequency Stability F_stab -15 – +15 ppm -25 – +25 ppm -35 – +35 ppm -50 – +50 ppm Inclusive of initial tolerance, operating temperature, rated power supply voltage, load variations, and first year aging at 25°C, with VIN voltage at Vdd/2. ±15 ppm is only guaranteed for pull range up to ±100 ppm. Temperature Range Operating Temperature Range T_use -20 – +70 °C Extended Commercial -40 – +85 °C Industrial -40 – +95 °C -40 – +105 °C Extended Industrial Supply Voltage Supply Voltage Vdd 2.97 3.30 3.63 V 2.70 3.00 3.30 V 2.52 2.80 3.08 V 2.25 2.50 2.75 V Voltage Control Characteristics Pull Range PR ±25, ±50, ±80, ±100, ±150, ±200, ±400, ±800, ±1600, ±3200 ppm See the APR (Absolute Pull Range) Table 11. Contact SiTime for custom pull range options Upper Control Voltage VC_U 90% – – Vdd Voltage at which maximum frequency deviation is guaranteed Lower Control Voltage VC_L – – 10% Vdd Voltage at which minimum frequency deviation is guaranteed Control Voltage Input Impedance VC_z – 10 – MΩ Control Voltage Input Bandwidth V_c – 10 – kHz Pull Range Linearity Lin – – 1.0 % Frequency Change Polarity – Contact SiTime for other input bandwidth options – Positive Slope Input Characteristics Input Voltage High VIH 70% – – Vdd Pin 2, OE Input Voltage Low VIL – – 30% Vdd Pin 2, OE Input Pull-up Impedance Z_in – 100 - kΩ Pin 2, OE logic high or logic low Output Characteristics Duty Cycle DC 45 – 55 % Startup and OE Timing Start-up Time OE Enable/Disable Time Rev 1.07 T_start – – 3.0 ms Measured from the time Vdd reaches its rated minimum value. T_oe – – 3.8 µs f = 322.265625 MHz. Measured from the time OE pin reaches rated VIH and VIL to the time clock pins reach 90% of swing and high-Z. See Figure 9 and Figure 10 Page 4 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Table 3. Electrical Characteristics – LVPECL Specific Parameter Symbol Min. Typ. Max. Unit Condition Current Consumption Idd – – 97 mA Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V OE Disable Supply Current I_OE – – 63 mA OE = Low Output Disable Leakage Current I_leak – 0.15 – A OE = Low I_driver – – 32 mA Maximum average current drawn from OUT+ or OUT- Current Consumption Maximum Output Current Output Characteristics Output High Voltage VOH Vdd-1.15 – Vdd-0.7 V See Figure 5 Output Low Voltage VOL Vdd-1.9 – Vdd-1.5 V See Figure 5 V_Swing 1.2 1.6 2.0 V See Figure 6 – 225 290 ps 20% to 80%, see Figure 6 Output Differential Voltage Swing Rise/Fall Time Tr, Tf Jitter – 7.0 x 5.0 mm Package RMS Period Jitter[4] T_jitt RMS Phase Jitter (random) T_phj – 1.0 1.6 ps f = 322.265625 MHz, Vdd = 3.3 V or 2.5 V – 0.220 0.270 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.220 0.300 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 156.25 or 322.265625 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, all Vdd levels Jitter – 5.0 x 3.2 mm and 3.2 x 2.5 mm Packages RMS Period Jitter[4] T_jitt RMS Phase Jitter (random) T_phj – 1.0 1.6 ps f = 322.265625 MHz, Vdd = 3.3 V or 2.5 V – 0.225 0.282 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.225 0.315 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 322.265625 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, all Vdd levels Notes: 4. Measured according to JESD65B. Rev 1.07 Page 5 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Table 4. Electrical Characteristics – LVDS Specific Parameter Symbol Min. Typ. Max. Unit Condition Current Consumption Current Consumption Idd – – 89 mA Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V OE Disable Supply Current I_OE – – 67 mA OE = Low Output Disable Leakage Current I_leak – 0.15 – A OE = Low Output Characteristics 250 – 450 mV See Figure 7 – – 50 mV See Figure 7 1.125 – 1.375 V See Figure 7 ΔVOS – – 50 mV See Figure 7 Rise/Fall Time Tr, Tf – 370 470 ps Measured with 2 pF capacitive loading to GND, 20% to 80%, see Figure 8 RMS Period Jitter[5] T_jitt – 0.92 1.6 ps f = 322.265625 MHz, Vdd = 3.3V or 2.5V RMS Phase Jitter (random) T_phj – 0.215 0.265 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.215 0.280 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 322.265625 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Differential Output Voltage VOD Delta VOD ΔVOD Offset Voltage VOS Delta VOS Jitter – 7.0 x 5.0 mm package Jitter – 5.0 x 3.2 mm and 3.2 x 2.5 mm packages RMS Period Jitter[5] T_jitt – 0.92 1.6 ps f = 322.265625 MHz, Vdd = 3.3 V or 2.5 V RMS Phase Jitter (random) T_phj – 0.235 0.282 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.235 0.310 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 322.265625 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Notes: 5. Measured according to JESD65B. Rev 1.07 Page 6 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Table 5. Electrical Characteristics – HCSL Specific Parameter Symbol Min. Typ. Max. Unit Condition Current Consumption Idd – – 102 mA Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V OE Disable Supply Current I_OE – – 67 mA OE = Low Output Disable Leakage Current I_leak – 0.15 – A OE = Low Current Consumption Output Characteristics Output High Voltage VOH 0.6 – 0.90 V See Figure 5 Output Low Voltage VOL -0.05 – 0.08 V See Figure 5 V_Swing 1.2 1.4 1.8 V See Figure 6 Rise/Fall Time Tr, Tf – 360 470 ps Measured with 2 pF capacitive loading to GND, 20% to 80%, see Figure 6 RMS Period Jitter[6] T_jitt – 1.0 1.6 ps f = 322.265625 MHz, Vdd = 3.3 V or 2.5 V RMS Phase Jitter (random) T_phj – 0.215 0.265 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, Pull Range = ±100 ppm – 0.215 0.282 ps f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.1 – ps f = 322.265625 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Output Differential Voltage Swing Jitter – 7.0 x 5.0 mm package Jitter – 5.0 x 3.2 mm and 3.2 x 2.5 mm packages RMS Period Jitter[6] T_jitt – 1.0 1.6 ps RMS Phase Jitter (random) T_phj – 0.235 0.282 0.215 f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.235 0.305 0.215 f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – 0.1 f = 322.265625 MHz, Vdd = 3.3 V or 2.5 V f = 322.265625 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Notes: 6. Measured according to JESD65B. Rev 1.07 Page 7 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Table 6. Pin Description Pin Symbol 1 VIN Functionality Input No Connect (NC) 2 NC/OE Output Enable (OE) Control Voltage No Connect: Leave floating or connect to GND for better heat dissipation. NC for all 3.2 x 2.5 mm package options. H[7,8]: specified frequency output L: output is high impedance. Only output driver is disabled. OE function only available on 7050 and 5032 packages. Pin 2 on 3225 package is NC. 3 GND Power Vdd Power Supply Ground 4 OUT+ Output Oscillator output 5 OUT- Output Complementary oscillator output 6 VDD Power Power supply voltage [9] Top View Top View VIN 1 6 VDD VIN 1 6 VDD NC/OE [1] 2 5 OUT- NC [2] 2 5 OUT- GND 3 4 OUT+ GND 3 4 OUT+ Figure 3. Pin Assignments (7.0 x 5.0 mm and 5.0 x 3.2 mm packages) Figure 4. Pin Assignments (3.2 x 2.5 mm package) Notes: 7. A pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. 8. OE mode is only available in the 7050 and 5032 packages. 3225 package is NC. 9. A capacitor of value 0.1 µF or higher between VDD and GND is required. An additional 10 µF capacitor between VDD and GND is required for the best phase jitter performance. Rev 1.07 Page 8 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Table 7. Absolute Maximum Ratings Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Parameter Min. Continuous Power Supply Voltage Range (Vdd) -0.5 Max. Unit 4.0 V Vdd + 0.3V V 150 °C Maximum Junction Temperature 145 °C Soldering Temperature (follow standard Pb-free soldering guidelines) 260 °C Input Voltage, Maximum (any input pin) Input Voltage, Minimum (any input pin) -0.3 Storage Temperature -65 V Table 8. Thermal Considerations[10] Package JA, 4 Layer Board (°C/W) JC, Bottom (°C/W) 3225, 6-pin 80 30 5032, 6-pin 53[11] 20 7050, 6-pin 52[11] 19 Notes: 10. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table. 11. Value for JA assumes the center pad is soldered down. Table 9. Maximum Operating Junction Temperature[12] Max Operating Temperature (ambient) Maximum Operating Junction Temperature: 3225 Package Maximum Operating Junction Temperature: 5032, 7050 Packages 70°C 105°C 95°C 85°C 130°C 110°C 95°C 130°C 120°C 105°C 145°C 130°C Notes: 12. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 10. Environmental Compliance Value Unit Mechanical Shock Resistance MIL-STD-883F, Method 2002 10,000 g Mechanical Vibration Resistance MIL-STD-883F, Method 2007 70 g Soldering Temperature (follow standard Pb free soldering guidelines) MIL-STD-883F, Method 2003 260 °C Moisture Sensitivity Level MSL1 @ 260°C Electrostatic Discharge (HBM) HBM, JESD22-A114 2,000 V Charge-Device Model ESD Protection JESD220C101 750 V Parameter Test Conditions JESD78 Compliant Latch-up Tolerance Rev 1.07 Page 9 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Waveform Diagrams OUT- VOH OUT+ VOL GND Figure 5. LVPECL, HCSL Voltage Levels per Differential Pin (i.e. OUT+, or OUT-) V 80% 80% V_ Swing 0V t 20% 20% Tr Tf Figure 6. LVPECL, HCSL Voltage Levels across Differential Pair (i.e. OUT+ minus OUT-) Rev 1.07 Page 10 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Waveform Diagrams (continued) OUT- VOD OUT+ VOS GND Figure 7. LVDS Voltage Levels per Differential Pin (i.e. OUT+, or OUT-) V 80% 80% 0V t 20% 20% Tr Tf Figure 8. LVDS Differential Waveform (i.e. OUT+ minus OUT-) Timing Diagrams Vdd OE Voltage Vdd VIH VIL T_oe_hw OE Voltage T_oe_hw OUT- OUT- 90% HZ HZ OUT+ OUT+ GND GND Figure 9. Hardware OE Enable Timing Rev 1.07 Figure 10. Hardware OE Disable Timing Page 11 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Termination Diagrams LVPECL OUT+ Shunt Bias Termination network 0.1μF Zo = 50Ω D+ OUT- Zo = 50Ω D- LVPECL 0.1μF RB RB VDD 50 Ω 50 Ω RB 3.3 V 100 Ω VT 2.5 V 48.7 Ω Figure 11. LVPECL with AC-coupled termination VDD Thevenin-equivalent Termination network R1 LVPECL R1 OUT+ Zo = 50Ω D+ OUT- Zo = 50Ω D- VDD R1 R2 R2 3.3 V 127 Ω 82.5 Ω 2.5 V 250 Ω 62.5 Ω R2 Figure 12. LVPECL DC-coupled load termination with Thevenin equivalent network Y-Bias Termination network LVPECL OUT+ Zo = 50Ω D+ OUT- Zo = 50Ω D- R1 VDD R1 R2 R3 3.3 V 50 Ω 50 Ω 50 Ω 2.5 V 50 Ω 50 Ω 18 Ω C1 0.1μF R2 R3 Figure 13. LVPECL with Y-Bias termination OUT+ Shunt Bias Termination network Zo = 50Ω D+ OUT- Zo = 50Ω D- LVPECL 50 Ω 50 Ω VT=VDD-2V Figure 14. LVPECL with DC-coupled parallel shunt load termination Rev 1.07 Page 12 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Termination Diagrams (continued) LVDS LVDS Zo = 50Ω OUT+ OUT+ 100 Ω Zo = 50Ω OUT- OUT- Figure 15. LVDS single DC termination at the load LVDS 0.1μF Zo = 50Ω OUT+ OUT+ 100 Ω 100 Ω 0.1μF Zo = 50Ω OUT- OUT- Figure 16. LVDS double AC termination with capacitor close to the load LVDS Zo = 50Ω OUT+ OUT+ 100 Ω 100 Ω Zo = 50Ω OUT- OUT- Figure 17. LVDS double DC termination HCSL R1 OUT+ OUT- Zo = 50Ω D+ Zo = 50Ω D- R2 50Ω 50Ω R1 = R2 = 33 Ω Figure 18. HCSL interface termination Rev 1.07 Page 13 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Dimensions and Patterns ― 3.2 x 2.5 mm Package Size – Dimensions (Unit: mm)[13] 3.2 x 2.5 x 0.85 mm Recommended Land Pattern (Unit: mm)[14] 3.2 x 2.5 x 0.85 mm 1.00 1.6 2.25 0.65 1.05 Dimensions and Patterns ― 5.0 x 3.2 mm Package Size – Dimensions (Unit: mm)[13] 5.0 x 3.2 x 0.85 mm[15] Recommended Land Pattern (Unit: mm)[14] 5.0 x 3.2 x 0.85 mm[15] Notes: 13. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the assembly location of the device. 14. A capacitor of value 0.1 µF or higher between VDD and GND is required. An additional 10 µF capacitor between VDD and GND is required for the best phase jitter performance. 15. The center pad is internally connected to the GND pin. Soldering down the center pad to the GND is recommended for best thermal dissipation, but is optional. Rev 1.07 Page 14 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Dimensions and Patterns ― 7.0 x 5.0 mm Package Size – Dimensions (Unit: mm)[16] 7.0 x 5.0 x 0.85 mm[18] Recommended Land Pattern (Unit: mm)[17] 7.0 x 5.0 x 0.85 mm[18] Notes: 16. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the assembly location of the device. 17. A capacitor of value 0.1 µF or higher between VDD and GND is required. An additional 10 µF capacitor between VDD and GND is required for the best phase jitter performance. 18. The center pad is internally connected to the GND pin. Soldering down the center pad to the GND is recommended for best thermal dissipation, but is optional. Rev 1.07 Page 15 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Table 11. APR Table Absolute pull range (APR) = Nominal pull range (PR) - frequency stability (F_stab) - aging[19] Frequency Stability Nominal Pull Range ±15 ±25 ±35 ±50 — APR (ppm) ±25 ±5 — — ±50 ±30 ±20 ±10 — ±80 ±60 ±50 ±40 ±25 ±100 ±80 ±70 ±60 ±45 ±150 — ±120 ±110 ±95 ±200 — ±170 ±160 ±145 ±400 — ±370 ±360 ±345 ±800 — ±770 ±760 ±745 ±1600 — ±1570 ±1560 ±1545 ±3200 — ±3170 ±3160 ±3145 Note: 19. Aging includes solder down shift and 20-year aging. Additional Information Table 12. Additional Information Document Description Download Link ECCN #: EAR99 Five character designation used on the commerce Control List (CCL) to identify dual use items for export control purposes. — HTS Classification Code: 8542.39.0000 A Harmonized Tariff Schedule (HTS) code developed by the World Customs Organization to classify/define internationally traded goods. — Part number Generator Tool used to create the part number based on desired features. https://www.sitime.com/part-number-generator Time Machine II MEMS oscillator programmer http://www.sitime.com/support/time-machine-oscillator-programmer Manufacturing Notes Tape & Reel dimension, reflow profile and other manufacturing related info https://www.sitime.com/sites/default/files/gated/Manufacturing-Notesfor-SiTime-Products.pdf Qualification Reports RoHS report, reliability reports, composition reports http://www.sitime.com/support/quality-and-reliability Performance Reports Additional performance data such as phase noise, current consumption, and jitter for selected frequencies http://www.sitime.com/support/performance-measurement-report Termination Techniques AN10029Termination design recommendations http://www.sitime.com/support/application-notes Layout Techniques AN10006 Layout recommendations http://www.sitime.com/support/application-notes Evaluation Boards SiT6085EB, SiT6086EB and SiT6097EB for Differential Oscillators https://www.sitime.com/support/user-guides Rev 1.07 Page 16 of 17 www.sitime.com SiT3373 220 MHz to 725 MHz Ultra-low Jitter Differential VCXO Revision History Table 13. Revision History Revision 1.0 1.01 Release Date 13-Oct-2017 2-Feb-2018 1.03 1.04 1.05 10-May-2018 29-Oct-2018 7-Jun-2020 1.06 17-Mar-2021 1.07 20-Jul-2021 Change Summary Initial release Corrected ppm ordering codes. Corrected minor formatting errors. Added Additional Information table. Added Extended Industrial temperature range (-40°C – 95°C and -40°C – 105°C ) Updated the Part Ordering info with added 5.0 x 3.2 mm package ±15 ppm option Formatting updates Corrected typos Updated package Dimensions Drawings Updated Table 8 Thermal Considerations for 5032 package Added Evaluation Boards SiT6085EB reference in Additional Information Rearranged layout, added Description, Block Diagram and TOC Added HTS classification code Clarified ±15 ppm pull range up to ±100 ppm Modified maximum junction temperatures Removed I_driver HCSL specification as not applicable Updated L1 and Dimple Width package dimensions for 3.2 x 2.5 mm package Updated trademarks and changed rev table date format Updated pin direction in package dimensions for 3.2 x 2.5 mm package SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439 © SiTime Corporation 2017-2021. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liabi lity for any loss, damage or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or (iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress. Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below. CRITICAL USE EXCLUSION POLICY BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE. SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly prohibited. Rev 1.07 Page 17 of 17 www.sitime.com
SIT3373AC-4E3-25NU307.695484 价格&库存
很抱歉,暂时无法提供与“SIT3373AC-4E3-25NU307.695484”相匹配的价格&库存,您可以联系我们找货
