CLE1K
CLE1K
    CARLOGAVAZZI
    ELECTRODE 1000 MM BASIC
CLE1K 数据手册
Conductive Sensors Level Probes Types CLH • • • • • Flexible conductive level probe 1 to 5 electrodes User defined electrode length Isolated or unisolated electrodes 1 1/2” pipe thread according to ISO 228/1-G11/2A Product Description Ordering Key A compact and flexible level probe for measuring the level of conductive liquids, i.e overfill, dry run protection or pump control. A total measurements system consist of a multiple probe- Type Head mounting Number of electrodes head, 1-5 electrodes and a control unit. The electrode length can be freely defined be means of electrode extention units with or without isolation. CLH 5 Type Selection - Probe Pipe thread Housing Material Ordering no. for 3 electrodes Ordering no. for 5 electrodes 1 1/2” PP CLH3 CLH5 Type Selection - Electrode Type Ordering no. 1000 mm Basic Thread in one end Ordering no. 2000 mm Extended Ordering no. Extension 1000 mm Thread in both ends Electrode without isolation Electrode with isolation, Kynar (PVDF) Electrode with isolation, Polyolefine (FR) CLE1 CLE1K CLE1P CLE2 CLE2K CLE2P CLE1X CLE1KX CLE1PX Description 1000 mm Basic electrode for no further extension 1000 mm Basic electrode for extension 1000 mm extension electrode 1 extension joint 1 isolation tube (not CLE2) 1000 mm extension electrode 1 extension joint 1 isolation tube (not CLE1X) Specifications Probe Head Material No of electrodes CLH3 CLH5 Electrode connection Tightening torque Cable connection Electrodes Material Length CLE1 CLE2 PP (Polypropylen) 3 5 M4 2.7 Nm by hand -K & -P Screw terminals Stainless steel AISI316/DIN1.4401 1000 mm 2000 mm Specifications are subject to change without notice (08.04.2011) Diameter Isolation CLE.K. CLE.P. Environment Overvoltage category Degree of protection Housing Electrode connections Pollution degree Operating temperature Storage temperature Pressure Ø 4 mm Kynar (PVDF) Polyolefine (FR) III (IEC 60664) IP 65 IP 68 2(IEC 60664/60664A, 60947-1) -20° to +90ºC (-4º to +194ºF) -40º to +100ºC (-40º to +212ºF) 5 bar at 60°C 1 Specifications (cont.) Weight Probe Head Electrodes CE marking 260 g 107 g IEC 529 Mode of Operation Electrodes Cut or extend the electrodes not to damage the isolation material of the isolated electrodes. Example Probe HiHi Y1 Hi Y3 Lo 12 Y5 Y2 Y4 REF Control Unit LoLo Functionality - example The diagram shows the level control system connected as max. and min control, i.e. registration of 2 levels + 2 alarm levels. The relays react to the low alternating current created when the electrodes is in contact with the liquid. The reference (Ref) must be connected to the container or if the container are made of a nonconductive material, to an additional electrode. In the diagram this electrode is shown by the dotted line. 24 14 Pump on/off A1 Alarm on/off A2 11 21 Power Supply to the desirable length. If using extended electrodes, place the enclosed isolation tube over the extension joint, Dimensions and heat it with a heat gun. Mount the electrodes in the probehead by means of the M4 screw inserts. Take care Connection cable 2, 3, 4 or 5 conductor PVC cable, normally screened. Cable length: max. 100 m. The resistance between the cores and the ground must be at last 200k. In normal cases it is recommended to use screened cable between probe and controller, e.g. where the cable is placed in parallel to the load cables (mains). The screen has to be connected to Y5 (reference). Accessories Extension joint Ø4 60 mm Kynar for isolation 60 mm Polyolefine for isolation M12 Cable Gland M20 Cable Gland M12 x 1.5 VD VDK VDP M12 Cable Gland M20 Cable Gland Delivery Contents Probe Head M20 Cable Gland M12 Blind flange Installation Instruction M20 x 1.5 2 Specifications are subject to change without notice (08.04.2011)
CLE1K 价格&库存
很抱歉,暂时无法提供与“CLE1K”相匹配的价格&库存,您可以联系我们找货
CLE1K
    • 1+642.97332
    CLE1K
      • 1+482.08036
