PSMN038-100K
N-channel TrenchMOS SiliconMAX standard level FET
Rev. 02 — 25 November 2009
Product data sheet
1. Product profile
1.1 General description
SiliconMAX standard level N-channel enhancement mode Field-Effect Transistor (FET) in
a plastic package using TrenchMOS technology. This product is designed and qualified for
use in computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Low conduction losses due to low
on-state resistance
Suitable for high frequency
applications due to fast switching
characteristics
1.3 Applications
Computer motherboards
Switched-mode power supplies
DC-to-DC convertors
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C
100
V
ID
drain current
Tsp = 80 °C;
see Figure 1 and 3
6.3
A
Ptot
total power
dissipation
Tsp = 80 °C;
see Figure 2
3.5
W
VGS = 10 V; ID = 6.3 A;
VDS = 50 V; Tj = 25 °C;
see Figure 11
16
21.5
nC
VGS = 10 V; ID = 5.2 A;
Tj = 25 °C;
see Figure 9 and 10
33
38
mΩ
Dynamic characteristics
QGD
gate-drain charge
Static characteristics
RDSon
drain-source
on-state resistance
PSMN038-100K
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
1
S
source
2
S
source
3
S
source
4
G
gate
5
D
drain
6
D
drain
7
D
drain
8
D
drain
Simplified outline
8
Graphic symbol
D
5
G
1
mbb076
4
S
SOT96-1 (SO8)
3. Ordering information
Table 3.
Type number
PSMN038-100K
Package
Name
Description
Version
SO8
plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
100
V
VGS
gate-source voltage
-20
V
ID
drain current
Tsp = 80 °C; see Figure 1 and 3
6.3
A
IDM
peak drain current
Tsp = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3
50
A
Ptot
total power dissipation
Tsp = 80 °C; see Figure 2
3.5
W
Tstg
storage temperature
-55
150
°C
Tj
junction temperature
-55
150
°C
Source-drain diode
IS
source current
Tsp = 80 °C
3.1
A
ISM
peak source current
50
A
PSMN038-100K_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 12
PSMN038-100K
Nexperia
03aa25
120
03aa17
120
Ider
Pder
80
80
40
40
100
150
200
100
150
Tsp (°C)
Fig 1.
200
Tsp (°C)
Fig 2.
Normalized continuous drain current as a
function of solder point temperature
Normalized total power dissipation as a
03ad97
102
RDSon = VDS/ID
ID
(A)
tp = 10 µs
10
100 µs
1 ms
10 ms
1
δ=
P
tp
100 ms
D.C.
T
10−1
t
tp
10−2
10-1
T
1
10
102
103
VDS (V)
Fig 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PSMN038-100K_2
Product data sheet
3 of 12
PSMN038-100K
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Rth(j-sp)
thermal resistance from mounted on a metal clad substrate;see
junction to solder point Figure 4
Min
Typ
Max
Unit
K/W
03ad96
102
Zth(j-sp)
(K/W)
10
δ = 0.5
0.2
0.1
1
0.05
0.02
δ=
P
10−1
tp
T
single pulse
t
tp
10−2
10−4
T
10−3
10−2
10−1
1
102
10
tp (s)
Fig 4.
Transient thermal impedance from junction to solder point as a function of pulse duration
PSMN038-100K_2
Product data sheet
4 of 12
PSMN038-100K
Nexperia
6. Characteristics
Table 6.
Symbol
Characteristics
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
100
130
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS= VGS; Tj = 150 °C;
see Figure 8
1.2
V
ID = 1 mA; VDS= VGS; Tj = -55 °C;
see Figure 8
6
V
ID = 1 mA; VDS= VGS; Tj = 25 °C;
see Figure 8
2
4
V
VDS = 100 V; VGS = 0 V; Tj = 150 °C
0.5
mA
VDS = 80 V; VGS = 0 V; Tj = 25 °C
1
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = 10 V; ID = 5.2 A; Tj = 150 °C;
see Figure 9 and 10
76
88
mΩ
VGS = 10 V; ID = 5.2 A; Tj = 25 °C;
see Figure 9 and 10
33
38
mΩ
ID = 6.3 A; VDS = 50 V; VGS = 10 V;
Tj = 25 °C; see Figure 11
43
nC
6.5
nC
16
21.5
nC
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
drain-source on-state
resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
VDS = 25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 12
1740
pF
220
pF
135
pF
15
30
ns
13
25
ns
turn-off delay time
50
80
ns
tf
fall time
25
40
ns
gfs
transfer conductance
VDS = 15 V; ID = 6.3 A; see Figure 13
S
0.7
1.1
V
VDS = 50 V; RL = 50 Ω; VGS = 10 V;
RG(ext) = 6 Ω; Tj = 25 °C; ID = 1 A
Source-drain diode
VSD
source-drain voltage
IS = 2.3 A; VGS = 0 V; Tj = 25 °C;
see Figure 14
trr
reverse recovery time
Qr
recovered charge
IS = 6.3 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 25 V; Tj = 25 °C
85
ns
0.3
µC
PSMN038-100K_2
Product data sheet
5 of 12
PSMN038-100K
Nexperia
03ad98
50
VGS = 10 V 7 V
ID
(A)
03ae00
50
VDS > I D X R DSon
ID
(A)
6V
40
40
30
30
5V
10
25 °C
Tj = 150 °C
10
4.5 V
2
3
4
VDS (V)
Fig 5.
Output characteristics: drain current as a
function of drain-source voltage; typical values
Fig 6.
03aa35
10−1
ID
(A)
4
6
VGS (V)
8
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
03aa32
5
VGS(th)
(V)
min
10−2
typ
max
4
10−3
3
10−4
2
10−5
1
10−6
4
−60
6
VGS (V)
Fig 7.
2
Sub-threshold drain current as a function of
gate-source voltage
Fig 8.
typ
min
120
180
Tj (°C)
Gate-source threshold voltage as a function of
PSMN038-100K_2
Product data sheet
max
6 of 12
PSMN038-100K
Nexperia
03ad99
0.1
R DSon
(Ω)
0.09
4.5 V
5V
03aa29
3
VGS = 6 V
a
0.08
2
0.07
0.06
1
7V
0.05
10 V
0.04
Tj = 25 °C
0.03
40
50
I D (A)
Fig 9.
Drain-source on-state resistance as a function
of drain current; typical values
03ae04
10
VGS
I D = 6.3 A
(V)
T j = 25 °C
120
Tj (°C)
180
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
03ae03
104
Ciss,
Coss,
Crss
(pF)
8
VDD = 20 V 50 V 80 V
6
Ciss
103
4
2
Coss
30
Q G (nC)
45
Fig 11. Gate-source voltage as a function of gate
charge; typical values
102
10−1
10
VDS (V)
102
Fig 12. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
PSMN038-100K_2
Product data sheet
Crss
1
7 of 12
PSMN038-100K
Nexperia
03ae01
40
VDS> ID X RDSon
g fs
(S)
03ae02
50
VGS = 0 V
IS
(A)
Tj = 25 °C
40
150 °C
30
30
150 °C
10
40
ID (A)
50
Fig 13. Forward transconductance as a function of
0.8
VSD (V)
1.2
Fig 14. Source current as a function of source-drain
PSMN038-100K_2
Product data sheet
Tj = 25 °C
8 of 12
PSMN038-100K
Nexperia
7. Package outline
SO8: plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
D
E
A
X
c
y
HE
v M A
Z
5
8
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
5.0
4.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100
0.014 0.0075
0.20
0.19
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT96-1
076E03
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
Fig 15. Package outline SOT96-1 (SO8)
PSMN038-100K_2
Product data sheet
9 of 12
PSMN038-100K
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PSMN038-100K_2
20091125
Product data sheet
PSMN038-100K-01
Modifications:
PSMN038-100K-01
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20010116
Product specification
PSMN038-100K_2
Product data sheet
10 of 12
PSMN038-100K
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft— The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet— A short data sheet is an extract from a full data sheet with
the same product type number(s) and title. A short data sheet is intended for
quick reference only and should not be relied upon to contain detailed and full
information. For detailed and full information see the relevant full data sheet,
which is available on request via the local Nexperia sales office.
In case of any inconsistency or conflict with the short data sheet, the full data
sheet shall prevail.
9.3
Disclaimers
General— Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes— Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use— Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications— Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data— The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values— Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale— Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license— Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control— This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit:http://www.nexperia.com
For sales office addresses, please send an email to:salesaddresses@nexperia.com
PSMN038-100K_2
Product data sheet
11 of 12
Nexperia
PSMN038-100K
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 25 November 2009
很抱歉,暂时无法提供与“PSMN038-100K,518”相匹配的价格&库存,您可以联系我们找货
