Technical data sheet
Reflector
Part no.: 50022816
TKS 100X100
Contents
- Technical data
- Dimensioned drawings
Figure can vary
Leuze electronic GmbH + Co. KG
info@leuze.com • www.leuze.com
We reserve the right to make technical changes
In der Braike 1, 73277 Owen
Phone: +49 7021 573-0 • Fax: +49 7021 573-199
eng • 2021-03-25
1/2
Reflector • Part no.: 50022816 • TKS 100X100
Technical data
Mechanical data
Environmental data
Design
Rectangular
Triple reflector size
4 mm
Mounting dimension, width
103 mm
Certifications
Mounting dimension, height
125 mm
Degree of protection
Mounting dimension, thickness
8.7 mm
Reflection surface height
96 mm
Reflection surface width
96 mm
Reflector material
Plastic
Material of base material
Plastic
Polarization-changing
Yes
Chemical designation, reflector material
PMMA8N
Structure, active surface
Net weight
Type of fastening
Triple
70 g
Adhesive
Through-hole mounting
Ambient temperature, operation
-40 ... 65 °C
IP 67
Classification
Customs tariff number
90029000
eCl@ss 5.1.4
27279203
eCl@ss 8.0
27279203
eCl@ss 9.0
27273601
eCl@ss 10.0
27273601
eCl@ss 11.0
27273601
ETIM 5.0
EC002467
ETIM 6.0
EC002467
ETIM 7.0
EC002467
All dimensions in millimeters
eng • 2021-03-25
2/2
很抱歉,暂时无法提供与“TKS 100X100”相匹配的价格&库存,您可以联系我们找货
