KD S-M12-5A-P1-100
KD S-M12-5A-P1-100
    LEUZE(劳易测)
    CONNECTION CABLE
KD S-M12-5A-P1-100 数据手册
Technical data sheet Connection cable Part no.: 50133861 KD S-M12-5A-P1-100 Contents - Technical data - Electrical connection - Circuit diagrams Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-08 1/3 Connection cable • Part no.: 50133861 • KD S-M12-5A-P1-100 Technical data Electrical data Mechanical data Performance data Max. 125 V AC/DC Operating voltage Width across flats 13 mm Bending cycles 5,000,000 Piece(s) Bending radius, flexible laying, min. Min. 10 x cable diameter Bending radius, stationary laying, min. Min. 5 x cable diameter Connection Environmental data Connection 1 Ambient temperature, operation, flexible use -25 ... 80 °C Ambient temperature, operation, stationary use -40 ... 80 °C Type of connection Connector Thread size M12 Type Female Handle body material PUR No. of pins 5 -pin Certifications Encoding A-coded Degree of protection Version Axial Lock Screw fitting, nickel-plated diecast zinc, recommended torque 0.6 Nm, selflocking IP 67 Connection 2 Open end Type of connection IP 65 Cable properties c UL US Certifications Classification Customs tariff number 85444290 eCl@ss 5.1.4 27279201 eCl@ss 8.0 27279218 eCl@ss 9.0 27060311 Number of conductors 5 Piece(s) eCl@ss 10.0 27060311 Wire cross section 0.34 mm² eCl@ss 11.0 27060311 AWG 22 ETIM 5.0 EC001855 Sheathing color Black ETIM 6.0 EC001855 Shielded Yes ETIM 7.0 EC001855 Silicone-free Yes Cable design Connection cable (open on one end) Cable diameter (external) 5.6 mm Cable length 10,000 mm Sheathing material PUR Wire insulation PUR Traverse rate Max. 3.3 m/s with horiz. traverse path of 5m and and max. acceleration of 5m/s² Suitability for drag chains Yes Properties of the outer sheathing Free of CFC, cadmium, silicone, halogen and lead, matt, low-adhesion, abrasionresistant, easily machine-processable Resistance of the outer sheathing Hydrolysis and microbe resistant, good oil, gasoline and chemical resistance in accordance with VDE 0472 part 803 test B, flame retardant in accordance with UL 1581 VW1 / CSA FT1 / IEC 60332-1, IEC 60332-2-2 Torsion suitability ±30° / m (max. 2 mio. cycles with 35 cycles / min) Electrical connection Connection 1 Type of connection Connector Thread size M12 Type Female Handle body material PUR No. of pins 5 -pin Encoding A-coded Version Axial Lock Screw fitting, nickel-plated diecast zinc, recommended torque 0.6 Nm, self-locking Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-08 2/3 Connection cable • Part no.: 50133861 • KD S-M12-5A-P1-100 Electrical connection Pin Conductor color 1 Brown 2 White 3 Blue 4 Black 5 Gray 2 1 3 FE 5 4 Connection 2 Open end Type of connection Circuit diagrams Wiring schematic 1 D 2 a Brown wire b White wire c Black wire d Blue wire e Gray wire E 4 F 3 G 5 H Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-08 3/3
KD S-M12-5A-P1-100 价格&库存
很抱歉,暂时无法提供与“KD S-M12-5A-P1-100”相匹配的价格&库存,您可以联系我们找货
