BZT55C2V4 thru BZT55C75
Taiwan Semiconductor
Small Signal Product
5% Tolerance SMD Zener Diode
FEATURES
- Wide zener voltage range selection: 2.4V to 75V
- VZ Tolerance Selection of ±5%
- Moisture sensitivity level 1
- Matte Tin(Sn) lead finish with Nickel(Ni) underplate
- Pb free and RoHS compliant
- All external surfaces are corrosion resistant a
leads are readily solderable
QUADRO Mini-MELF (LS34)
Hermetically Sealed Glass
MECHANICAL DATA
- Case: QUADRO Mini-MELF Package (JEDEC DO-213)
- High temperature soldering guaranteed: 270oC/10s
- Polarity: Indicated by cathode band
- Weight: 29 ± 2.5mg
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
Power Dissipation
Forward Voltage
IF = 10 mA
Thermal Resistance (Junction to Ambient)
Junction and Storage Temperature Range
(Note 1)
SYMBO
VALUE
UNIT
PD
500
mW
VF
1
RθJA
500
TJ, TSTG
- 65 to +175
V
o
C/W
o
C
Note1: Valid provided that electrodes are kept at ambient temperature
Zener I vs. V Characteristics
Document Number: DS_S1408007
VBR
: Voltage at IZK
IZK
: Test current for voltage VBR
ZZK
: Dynamic impedance at IZK
IZT
: Test current for voltage VZ
VZ
: Voltage at current IZT
ZZT
: Dynamic impedance at IZT
IZM
: Maximum steady state current
VZM
: Voltage at IZM
Version: F14
Small Signal
ELECTRICAL CHARACTERISTICS ( TA= 25oC unless otherwise noted )
VZ
@ IZT
(Volt)
Nom
Min
Max
IZT
(mA)
BZT55C2V4
2.4
2.28
2.56
5
85
1
600
50
1
BZT55C2V7
2.7
2.51
2.89
5
85
1
600
10
1
BZT55C3V0
3.0
2.8
3.2
5
85
1
600
4
1
BZT55C3V3
3.3
3.1
3.5
5
85
1
600
2
1
BZT55C3V6
3.6
3.4
3.8
5
85
1
600
2
1
BZT55C3V9
3.9
3.7
4.1
5
85
1
600
2
1
BZT55C4V3
4.3
4.0
4.6
5
75
1
600
1
1
BZT55C4V7
4.7
4.4
5.0
5
60
1
600
0.5
1
BZT55C5V1
5.1
4.8
5.4
5
35
1
550
0.1
1
BZT55C5V6
5.6
5.2
6.0
5
25
1
450
0.1
1
BZT55C6V2
6.2
5.8
6.6
5
10
1
200
0.1
2
BZT55C6V8
6.8
6.4
7.2
5
8
1
150
0.1
3
BZT55C7V5
7.5
7.0
7.9
5
7
1
50
0.1
5
BZT55C8V2
8.2
7.7
8.7
5
7
1
50
0.1
6.2
BZT55C9V1
9.1
8.5
9.6
5
10
1
50
0.1
6.8
BZT55C10
10
9.4
10.6
5
15
1
70
0.1
7.5
BZT55C11
11
10.4
11.6
5
70
0.1
8.2
BZT55C12
12
11.4
12.7
5
90
0.1
9.1
BZT55C13
13
12.4
14.1
5
26
1
110
0.1
10
BZT55C15
15
13.8
15.6
5
30
1
110
0.1
11
BZT55C16
16
15.3
17.1
5
40
1
170
0.1
12
BZT55C18
18
16.8
19.1
5
50
1
170
0.1
13
BZT55C20
21.1
5
55
1
220
0.1
15
BZT55C22
22
20.8
23.3
5
55
1
220
0.1
16
BZT55C24
24
22.8
25.6
5
80
1
220
0.1
18
BZT55C27
27
25.1
28.9
5
80
1
220
0.1
BZT55C30
30
28
32
5
80
1
220
0.1
22
BZT55C33
33
31
35
5
80
1
220
0.1
24
BZT55C36
36
34
38
5
80
1
220
0.1
27
BZT55C39
39
37
41
2.5
90
0.5
500
0.1
28
BZT55C43
43
40
46
2.5
90
0.5
600
0.1
32
BZT55C47
47
44
50
2.5
110
0.5
700
0.1
35
BZT55C51
51
48
54
2.5
125
0.5
700
0.1
38
BZT55C56
56
52
60
2.5
135
0.5
1,000
0.1
42
BZT55C62
62
58
66
2.5
150
0.5
1,000
0.1
47
BZT55C68
68
64
72
2.5
160
0.5
1,000
0.1
51
BZT55C75
75
70
79
2.5
170
0.5
1,000
0.1
56
Part Number
ZZT @ IZT (Ω)
Max
IZK
(mA)
ZZK @ IZK (Ω)
Max
IR @ VR(μA)
Max
VR
(V)
Notes: 1. The Zener Voltage (VZ) is tested under pulse condition of 10ms.
2. The device numbers listed have a standard tolerance on the nomial zener voltage of ±5%.
3. For detailed information on price, availability and delivery of nominal zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative.
4. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an
RMS value equal to 10% of the dc zener current(IZT or IZK) is superimposed to IZT or IZK.
Version: F14
RATINGS AND CHARACTERISTICS CURVES
Fig. 2 Zener Breakdown Characteristics
Fig. 1 Typical Forward Characteristics
300
1000
Zener Current (mA)
Forward Current (mA)
TA=25oC
250
TA=25oC
100
10
200
150
100
50
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
1
2
3
4
6
7
8
9
10
11
12
Zener Voltage (V)
Forward Voltage (V)
Fig. 4 Admissible Power Dissipation Curve
Fig. 3 Zener Breakdown Characteristics
600
Power Dissipation (mW)
100
10
Zener Current (mA)
5
1
0.1
500
400
300
200
100
15
25
35
45
55
65
75
50
100
Ambient Temperature
Zener Voltage (V)
Fig. 5 Typical Capacitance
150
200
(oC)
Fig. 6 Effect of Zener Voltage on Impedence
1000
1000
Dynamic Impedence(Ohm)
Capacitance (pF)
IZ=1mA
1V Bias
100
10
Bias at 50% of VZ (Nom)
1
100
10
IZ=5mA
IZ=20mA
1
1
10
Zener Voltage (V)
100
1
10
100
Zener Voltage (V)
Version: F14
ORDERING INFORMATION
PART NO.
MANUFACTURE
CODE
BZT55Cxxx
(Note1)
PACKING CODE
GREEN COMPOUND
L0
(Note 2)
PACKAGE
PACKING
Quadro Mini-MELF (Glass Seal)
10K / 13" Reel
2.5K / 7" Reel
CODE
G
L1
Note 1: "xxx" defines voltage from 2.4V (BZT55C2V4) to 75V (BZT55C75)
Note 2: Manufacture special control, if empty means no special control requirement.
EXAMPLE
PREFERRED P/N
PART NO.
BZT55C75 L0G
BZT55C75
BZT55C75-L0 L0G
BZT55C75
BZT55C75-B0 L0G
BZT55C75
MANUFACTURE
CODE
PACKING CODE
GREEN COMPOUND
CODE
DESCRIPTION
L0
G
Green compound
L0
L0
G
Green compound
B0
L0
G
Green compound
PACKAGE OUTLINE DIMENSION
C
DIM.
B
D
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
3.30
3.70
0.130
0.146
B
1.40
1.60
0.055
0.063
C
0.20
0.45
0.008
0.018
1.8 TYP.
0.071 TYP.
Unit (mm)
Unit (inch)
Typ.
Typ.
A
1.25
0.049
B
2.00
0.079
C
2.50
0.098
D
5.00
0.197
D
A
SUGGEST PAD LAYOUT
DIM.
Version: F14
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied,to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or seling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: F14
很抱歉,暂时无法提供与“BZT55C30 L0”相匹配的价格&库存,您可以联系我们找货
