SL3732H Series
1. Features of SL3732H Series:
Ferrite based SMD inductor with lower core loss.
Inductance range: 100.0 nH to 470.0 nH , custom values are welcomed.
High current output chokes,up to 95.0 Amp with approx. 20% roll off.
Low Profile 7.80/7.90/8.00mm typical height.
9.60 x 6.40 mm Foot Print.
Ideal for Buck Converter, VRM & High Density Board Design.
Operating frequency of up to 5.0MHz.
Operating temperature range of -55°C to + 130°C. RoHS & HF compliant.
T & R Qty’s: 650pcs, 13'' Reel.
2. Electrical Characteristics of SL3732H Series:
ITG Part Number
SL3732H-R10KHF
OCL 1
(nH)
L @ Isat1 2
(nH)
DCR 3
(mΩ)
Isat1 4
(A)
Isat2 4
(A)
Irms 5
(A)
Dim. C
(mm)
± 10% or 15%
Min.
± 5.0%
@25℃
@100℃
@25℃
± 0.20
100.00, 10%
72.00
0.29
95.00
85.00
51.00
8.00
SL3732H-R12KHF
120.00, 10%
86.40
0.29
81.00
70.00
51.00
7.90
SL3732H-R15KHF
150.00, 10%
108.00
0.29
66.00
56.00
51.00
7.80
SL3732H-R18KHF
180.00, 10%
129.60
0.29
55.00
49.00
51.00
7.80
SL3732H-R22KHF
220.00, 10%
158.40
0.29
45.00
41.00
51.00
7.80
SL3732H-R28KHF
280.00, 10%
201.60
0.29
35.00
32.00
51.00
7.80
SL3732H-R30KHF
300.00, 10%
216.00
0.29
33.00
30.00
51.00
7.80
SL3732H-R33LHF
330.00, 15%
237.60
0.29
26.00
22.00
51.00
7.80
SL3732H-R39LHF
390.00, 15%
280.80
0.29
22.00
19.00
51.00
7.80
SL3732H-R47LHF
470.00, 15%
338.40
0.29
18.00
15.00
51.00
7.80
3. Mechanical Dimension of SL3732H Series:
A
B
C
D
E
F
S RxxH
ITGYYWW
G
D
B
± 0.20 (Max.) ± 0.20 ± 0.20 (Ref.) ± 0.20 ± 0.30
6.20
9.50
See
table
above
9.40
4.40
2.20
A
10.40
C
2.50
a
Notes:
Glue
E
2.54
3.20
b
G
F
Suggested Pad Layout
Part Marking:
S RxxH: S is part size code,
Rxx is inductance value in uH(R:decimal point),
H is special code.
ITGYYWW: ITG is Company name , YYWW is date code.
1. Open Circuit Inductance (OCL) test condition: 100KHz,1.0Vrms,0Adc at 25Ԩ.
2. L @ Isat and L @ Irms Test condition: 100KHz,1.0Vrms (Ta=25Ԩ).
3. The nominal DCR is measured from point "a" to point"b",as shown above on the mechanical drawing (Ta=25Ԩ).
4. Isat1 & Isat2 : DC current that will cause inductance to drop approximately by 20%.
5. Irms: DC current for an approximate temperature rise of 40Ԩ without core loss. Derating is necessary for AC currents. PCB
pad layout,trace thickness and width,air-flow and proximity of other heat generating components will affect the temperature rise.
6. It is recommended the part temperature not exceed 130°C under worst case operating conditions as verified in the end application.
● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275
Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767
● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision C: July 06 , 2016
*Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
SL3732H Series
L (nH)
4. Inductance Characteristics of SL3732H Series (Inductance vs Current):
SL3732H-R10KHF
112.5
100.0
87.5
75.0
62.5
50.0
37.5
25.0
12.5
0.0
25Ԩ
100Ԩ
L (nH)
0.0 20.0 40.0 60.0 70.0 80.0 84.0 86.0 88.0 90.0 92.0 94.0 96.0 98.0 100.0106.0108.0110.0112.0
Direct Current (A)
SL3732H-R12KHF
135.0
120.0
105.0
90.0
75.0
60.0
45.0
30.0
15.0
0.0
25Ԩ
100Ԩ
0.0
10.0 20.0 30.0 40.0 50.0 60.0 70.0 72.0 74.0 76.0 78.0 80.0 82.0 84.0 86.0 88.0
Direct Current (A)
SL3732H-R15KHF
180.0
150.0
L (nH)
120.0
25Ԩ
90.0
100Ԩ
60.0
30.0
0.0
0.0 10.0 20.0 30.0 40.0 50.0 52.0 54.0 56.0 58.0 60.0 62.0 63.0 64.0 65.0 66.0 67.0 68.0 69.0 70.0
Direct Current (A)
SL3732H-R18KHF
216.0
180.0
25Ԩ
L (nH)
144.0
108.0
100Ԩ
72.0
36.0
0.0
0.0
10.0 20.0 30.0 35.0 40.0 45.0 49.0 50.0 51.0 52.0 53.0 54.0 55.0 56.0 58.0 60.0 62.0
Direct Current (A)
SL3732H Series
L (nH)
SL3732H-R22KHF
240.0
216.0
192.0
168.0
144.0
120.0
96.0
72.0
48.0
24.0
0.0
25Ԩ
100Ԩ
L (nH)
0.0 10.0 20.0 25.0 30.0 35.0 38.0 40.0 41.0 42.0 43.0 44.0 45.0 46.0 47.0 48.0 49.0 50.0 51.0
Direct Current (A)
SL3732H-R28KHF
315.0
280.0
245.0
210.0
175.0
140.0
105.0
70.0
35.0
0.0
25Ԩ
100Ԩ
0.0
5.0
10.0 15.0 20.0 25.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 41.0
Direct Current (A)
SL3732H-R30KHF
350.0
300.0
L (nH)
250.0
25Ԩ
200.0
150.0
100Ԩ
100.0
50.0
0.0
0.0
10.0
20.0
22.0
24.0
26.0
28.0 30.0 31.0
Direct Current (A)
32.0
33.0
34.0
35.0
36.0
38.0
SL3732H-R33LHF
385.0
330.0
L (nH)
275.0
25Ԩ
220.0
165.0
100Ԩ
110.0
55.0
0.0
0.0
5.0
10.0
15.0
20.0
18.0
21.0
22.0
23.0
Direct Current (A)
24.0
25.0
26.0
28.0
30.0
SL3732H Series
L (nH)
SL3732H-R39LHF
430.0
387.0
344.0
301.0
258.0
215.0
172.0
129.0
86.0
43.0
0.0
25Ԩ
100Ԩ
L (nH)
0.0
4.0
8.0
10.0
12.0
14.0
16.0
18.0
20.0
Direct Current (A)
22.0
24.0
26.0
28.0
30.0
SL3732H-R47LHF
517.0
470.0
423.0
376.0
329.0
282.0
235.0
188.0
141.0
94.0
47.0
0.0
25Ԩ
100Ԩ
0.0
2.0
4.0
8.0
10.0
12.0
14.0
15.0
16.0
Direct Current (A)
17.0
18.0
20.0
22.0
24.0
5. Core Loss:
SL3732H-XXX Core Loss
1000
1500
2000
2500
3000
3500
4000
1300.0
1200.0
1100.0
Core Loss (mW)
1000.0
900.0
1MHz
800.0
500KHz
700.0
300KHz
600.0
200KHz
500.0
100KHz
400.0
300.0
200.0
100.0
0.0
△B(Guass)
Where △B=0.40*L(nH)*△I
很抱歉,暂时无法提供与“SL3732H-R33LHF”相匹配的价格&库存,您可以联系我们找货
