SMCJ33A
SMCJ33A
    MDD(辰达半导体)
    SMC
    辰达行 SMC 1500W 33V
SMCJ33A 数据手册
PART CODE: SMCJ33A000SGFM SPECIFICATION SHEET SPECIFICATION SHEET NO. N0828-SMCJ33A000SGFM DATE Aug. 28, 2021 REVISION A0 DESCRIPITION SMD Transient Voltage Suppressor (TVs) Diodes, SMC/DO-214AB series, SMCJ33A Type, 2 Pads, Unidirectional Type Stand-off Voltage 33V Max. Power Dissipation: 1500 Watts. Operating Temp. Range -65°C ~+150°C Package in Tape/Reel, 3000pcs/Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER MDD SMCJ33A PART CODE SMCJ33A000SGFM VENDOR APPROVE Issued/Checked/Approved DATE: Aug. 28, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMCJ33A000SGFM SMD TRANSIENT VOLTAGE SUPPRESSORS DIODES SMC SERIES MAIN FEATURE • The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 • Low profile package • Built-in strain relief • High temperature soldering guaranteed: 260℃/ 10 seconds at terminals • Glass passivated chip junction • Low inductance , • Excellent clamping capability • 600W peak pulse power capability at 10/1000μs waveform • Repetition rate (duty cycle): 0.01% • Fast response time • Repetition rate (duty cycle): 0.01% • Typical IR less than 1μA above 10V APPLICATION • I/O interface • AC/DC power supply • Low frequency signal transmission line (RS232, RS485, etc.) RFQ PART CODE GUIDE Request For Quotation SMC J33A000 S GFM 1 2 3 4 1) SMC: SMD Transient Voltage Suppressor (TVs) Diodes, SMC /DO-214AB series, 2) J33A000: Type code for original part number SMCJ33A 3) S: Package code, Tape/reel, 3000pcs/reel. 4) GFM: Marking code for “GFM” on the case surface, Different Marking for different specification. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMCJ33A000SGFM SMD TRANSIENT VOLTAGE SUPPRESSORS DIODES SMC SERIES MORE ITEMS AVAILABLE- Unidirectional Type SMCJ050A00SGDE SMCJ060A00SGDG SMCJ065A00SGDK SMCJ070A00SGDM SMCJ075A00SGDP SMCJ080A00SGDR SMCJ085A00SGDT SMCJ090A00SGDV SMCJ10A000SGDX SMCJ11A000SGDZ SMCJ12A000SGEE SMCJ13A000SGEG SMCJ14A000SGEK SMCJ15A000SGEM SMCJ16A000SGEP SMCJ17A000SGER SMCJ18A000SGET SMCJ20A000SGEV SMCJ22A000SGEX SMCJ24A000SGEZ SMCJ26A000SGFE SMCJ28A000SGFG , SMCJ30A000SGFK SMCJ33A000SGFM SMCJ36A000SGFP SMCJ40A000SGFR SMCJ43A000SGFT SMCJ45A000SGFV SMCJ48A000SGFX SMCJ51A000SGFZ SMCJ54A000SGGE SMCJ58A000SGGG SMCJ60A000SGGK SMCJ64A000SGGM SMCJ70A000SGGP SMCJ75A000SGGR SMCJ78A000SGGT SMCJ85A000SGGV SMCJ90A000SGGX SMCJ100A00SGGZ SMCJ110A00SGHE SMCJ120A00SGHE SMCJ130A00SGHK SMCJ150A00SGHM SMCJ160A00SGHP SMCJ170A00SGHR SMCJ180A00SGHT SMCJ190A00SGHJ SMCJ200A00SGHV SMCJ210A00SGHW SMCJ220A00SGHX SMCJ250A00SGHZ SMCJ300A00SGJE SMCJ350A00SGJG SMCJ400A00SGJK SMCJ440A00SGJM MORE ITEMS AVAILABLE- Bidirectional Type SMCJ050CA0SBDE SMCJ060CA0SBDG SMCJ065CA0SBDK SMCJ070CA0SBDM SMCJ075CA0SBDP SMCJ080CA0SBDR SMCJ085CA0SBDT SMCJ090CA0SBDV SMCJ10CA00SBDX SMCJ11CA00SBDZ SMCJ12CA00SBEE SMCJ13A000SBEG SMCJ14CA00SBEK SMCJ15CA00SBEM SMCJ16CA00SBEP SMCJ17CA00SBER SMCJ18CA00SBET SMCJ20CA00SBEV SMCJ22CA00SBEX SMCJ24CA00SBEZ SMCJ26CA00SBFE SMCJ28CA00SBFG SMCJ30CA00SBFK SMCJ33CA00SBFM SMCJ36CA00SBFP SMCJ40CA00SBFR SMCJ43CA00SBFT SMCJ45CA00SBFV SMCJ48CA00SBFX SMCJ51CA00SBFZ SMCJ54CA00SBGE SMCJ58CA00SBGG SMCJ60CA00SBGK SMCJ64CA00SBGM SMCJ70CA00SBGP SMCJ75CA00SBGR SMCJ78CA00SBGT SMCJ85CA00SBGV SMCJ90CA00SBGX SMCJ100CA0SBGZ SMCJ110CA0SBHE SMCJ120CA0SBHE SMCJ130CA0SBHK SMCJ150CA0SBHM SMCJ160CA0SBHP SMCJ170CA0SBHR SMCJ180CA0SBHT SMCJ190CA0SBHJ SMCJ200CA0SBHV SMCJ210CA0SBHW SMCJ220CA0SBHX SMCJ250CA0SBHZ SMCJ300CA0SBJE SMCJ350CA0SBJG SMCJ400CA0SBJK SMCJ440CA0SBJM NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMCJ33A000SGFM SMD TRANSIENT VOLTAGE SUPPRESSORS DIODES SMC SERIES DIMENSION (Unit: Inch/mm) Image for reference Marking: GFM SMC/DO-214AB Recommend Pad Layout NextGen Components, Inc. sales@NextGenComponent.com Symbol Unit (inch) Unit (mm) A 0.170 4.30 B 0.160 4.10 C 0.311 7.90 D 0.150 3.80 E 0.472 12.0 www.NextGenComponent.com SMCJ33A000SGFM PART CODE: SMD TRANSIENT VOLTAGE SMD SUPPRESSORS SCHOTTKY SMDDIODES GENERAL BARRIER SMC RECTIFER RECTIFER SERIES MECHANICAL DATA Case Terminals Polarity Mounting Position Weight per piece JEDEC SMC/DO-214AB molded plastic body Solder plated, Solderable per MIL-STD-750, Method 2026 Polarity symbol marking on case Any 0.0070 Ounce, 0.2180 grams MAX. RATING & CHARACTERISTICS - Ratings at 25℃ ambient temperature unless otherwise specified. Parameter SYMBOLS VALUE Min. Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) P ppm Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) I ppm Steady state power dissipation at TA=50℃ (Fig.5) UNITS Typical Max. 1500 P M(AV) W 28.20 6.5 A W I FSM 200 A Thermal resistance junction to lead R QJL 15 °C/W Thermal resistance junction to ambient R QJA 75 °C/W Operating junction temperature range TJ -65 +150 °C T STG -65 +150 °C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) (Note3, Fig.6) Storage temperature range Note 1. Non-repetitive current pulse, per Fig 3 and derated above TA=25 °C per Fig 2 2. Mounted on 5.0*5.0mm(Thickness 0.03mm) copper pads to each terminal 3. 8.3ms single half sine – wave or equivalent square wave, duty cycle – 4 pulsed per minute Max ELECTRICALCHARACTERISTICS - Ratings at 25℃ Parameter SYMBOLS VALUE UNITS V RWM 33 V V BR 36.70~40.60 V Test Current IT 1 mA Maximum Clamping Voltage @I PP VC 53.30 V Peak Pulse Current I PP 28.20 A Reverse Leakage @V RWM IR 1 µA NextGen Components, Inc. sales@NextGenComponent.com Reverse Stand-Off Voltage Breakdown Voltage @I T www.NextGenComponent.com PART CODE: SMCJ33A000SGFM SMD TRANSIENT VOLTAGE SUPPRESSORS DIODES SMC SERIES RELIABILITY Number Experiment Items Experiment Method And Conditions Reference Documents 1 Solder Resistance Test Test 260°C± 5°C for 10 ± 2 sec. Immerse body into solder 1/16” ± 1/32" MIL-STD-750D METHOD-2031.2 2 Solderability Test 230°C ±5°C for 5 sec. MIL-STD-750D METHOD-2026.1 0 3 Pull Test 1 kg in axial lead direction for 10 sec. MIL-STD-750D METHOD-2036.4 4 Bend Test 0.5Kg Weight Applied To Each Lead, Bending Arcs 90 °C ± 5 °C For 3 Times MIL-STD-750D METHOD-2036.4 5 High Temperature Reverse Bias Test TA=100°C for 1000 Hours at VR=80% Rated VR MIL-STD-750D METHOD-1038.4 6 Forward Operation Life Test TA=25°C Rated Average Rectified Current MIL-STD-750D METHOD-1027.3 7 Intermittent Operation Life Test On state: 5 min with rated IRMS Power Off state: 5 min with Cool Forced Air. On and off for 1000 cycles. MIL-STD-750D METHOD-1036.3 8 Pressure Cooker Test 15 PSIG, TA=121°C, 4 hours MIL-S-19500 APPENOIXC 9 Temperature Cycling Test -55°C~+125°C; 30 Minutes For Dwelled Time 5 minutes for transferred time. Total: 10 cycles. MIL-STD-750D METHOD-1051.7 10 Thermal Shock Test 0°C for 5 minutes., 100°C for 5minutes, Total: 10 cycles MIL-STD-750D METHOD-1056.7 11 Forward Surge Test 8.3ms Single Sale Sine-wave One Surge. MIL-STD-750D METHOD-4066.4 12 Humidity Test TA=65°C, RH=98% for 1000 hours. MIL-STD-750D METHOD-1021.3 13 High Temperature Storage life Test 150°C for 1000 Hours MIL-STD-750D METHOD-1031.5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMCJ33A000SGFM SMD TRANSIENT VOLTAGE SUPPRESSORS DIODES SMC SERIES SUGGESTED REFLOW PROFILE (For Reference Only) Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 150℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 260 ℃ Time within 5℃ of actual Peak Temperature (tp) 20~40 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 8 minutes Max. Suggest reflow times 3 Times Max. 7 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMCJ33A000SGFM SMD TRANSIENT VOLTAGE SUPPRESSORS DIODES SMC SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) Figure 2. Pulse Derating Curve Figure 1. Peak Pulse Power Rating Curve Figure 4. Typical Junction Capacitance Figure 3. Pulse Waveform Figure 5. Steady State Power Dissipation Derating curve NextGen Components, Inc. Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMCJ33A000SGFM SMD TRANSIENT VOLTAGE SUPPRESSORS DIODES SMC SERIES TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-A and specifications. Item Symbol Tolerance SMC/DO-214AB Carrier width A 0.1 6.15 Carrier Length B 0.1 8.41 Carrier Depth C 0.1 2.42 Sprocket hole d 0.05 1.50 13”Reel outside diameter D 2.0 330.00 13”Reel inner diameter D1 Min. 50.00 7”Reel outside diameter - - - 7”Reel inner diameter - - - Feed hole diameter D2 0.5 13.00 Sprocket hole position E 0.1 1.75 Punch hole position F 0.1 7.50 Punch hole pitch P 0.1 8.00 Sprocket hole pitch P0 0.1 4.00 Embossment center P1 0.1 2.00 Overall tape thickness T 0.1 0.25 Tape width W 0.3 16.00 Reel width W1 1.0 16.50 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMCJ33A000SGFM SMD TRANSIENT VOLTAGE SUPPRESSORS DIODES SMC SERIES PACKAGE Case Code Reel Size MPQ (pcs) SMC 13” 3,000 Component Spacing (mm) Qty. Per Box (pcs) Inner Box L*W*H (mm) Reel Size (mm) Carton size L*W*H (mm) Qty. Per Carton (pcs) G. W 3,000 190*190*41 330 380*380*380 42,000 15.5 (kg) DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
SMCJ33A 价格&库存
很抱歉,暂时无法提供与“SMCJ33A”相匹配的价格&库存,您可以联系我们找货
SMCJ33A
    • 3000+6.25361
