KD U-M124W-T2104-020 数据手册
Technical data sheet
Connection cable
Part no.: 50140464
Contents
- Technical data
- Electrical connection
- Circuit diagrams
Figure can vary
Leuze electronic GmbH + Co. KG
info@leuze.com • www.leuze.com
We reserve the right to make technical changes
In der Braike 1, 73277 Owen
Phone: +49 7021 573-0 • Fax: +49 7021 573-199
eng • 2021-01-13
1/3
Connection cable • Part no.: 50140464 • KD U-M124W-T2104-020
Technical data
Electrical data
Mechanical data
Performance data
Operating voltage
Width across flats
14.5 mm
Bending cycles
1,000,000 Piece(s)
Max. 250 V AC/DC
Operation and display
Connection
Environmental data
Connection 1
Type of connection
Connector
Thread size
M12
Type
Female
Handle body material
TPU
No. of pins
4 -pin
Encoding
A-coded
Version
Angled
Lock
Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking
-15 ... 90 °C
Ambient temperature, operation,
stationary use
-35 ... 105 °C
Certifications
IP 65
Degree of protection
IP 67
NEMA 6P
Classification
Connection 2
Type of connection
flexible use
Open end
Cable properties
Customs tariff number
85444290
eCl@ss 5.1.4
27279201
eCl@ss 8.0
27279218
Number of conductors
4 Piece(s)
eCl@ss 9.0
27060311
Wire cross section
0.82 mm²
eCl@ss 10.0
27060311
AWG
18
eCl@ss 11.0
27060311
Sheathing color
Yellow
ETIM 5.0
EC001855
Shielded
No
ETIM 6.0
EC001855
Silicone-free
Yes
ETIM 7.0
EC001855
Cable design
Connection cable (open on one end)
Cable length
2,000 mm
Sheathing material
TPE
Wire insulation
PVC
Suitability for drag chains
Yes
Traverse rate
Max. 3.3 m/s with horiz. traverse path of
5m and and max. acceleration of 5m/s²
Connection 1
Type of connection
Connector
Thread size
M12
Type
Female
TPU
No. of pins
4 -pin
Encoding
A-coded
Version
Angled
Lock
Connection 2
Open end
Type of connection
eng • 2021-01-13
2/3
Circuit diagrams
Wiring schematic
1
D
2
E
4
a
Brown wire
b
White wire
c
Black wire
d
Blue wire
F
3
G
eng • 2021-01-13
3/3
KD U-M124W-T2104-020 价格&库存
很抱歉,暂时无法提供与“KD U-M124W-T2104-020”相匹配的价格&库存,您可以联系我们找货
