TPSM-ROOF-MOUNT
DATA SHEET
Asphalt Roof Mount Kit
Features
Low Cost
Includes All Parts Required to
Mount Qty 2 72Cell Solar Panels to
an Asphalt Shingled Roof
Expandable: 1 Kit for Every 2 Solar
Panels
Applications
Residential / Commercial Solar
Remote Cabins
Utility Sheds
*Picture shows with short rail
section for convenience
Description
Tycon Solar® TPSM-ROOF-MOUNT solar panel mounting system contains all components
necessary to mount quantity 2 (250-360W) solar panels to an asphalt shingled roof. The extra
strength aluminum brackets with flashing and the rail systems can accommodate many different
size solar panels, providing greater flexibility. The kit is expandable and linkable in order add
additional panels. This requires purchase of 1 kit for every 2 solar panels to be mounted.
Specifications
Ref Drawing 5200022
Aluminum Anchor Plate x 4
Extruded Aluminum Rail x 4
Standoff From Roof
Solar Panels Supported
Tycon Solar Panel Compatibility
Achievable Tilt
Max wind speed
Shipping Dimensions
Shipping Weight
Warranty
TPSM-ROOF-MOUNT
300 x 226 x 2.2mm (11.8 x 8.9 x 0.087”) Painted (Black)
1080 x 59 x 30mm (42.5 x 2.3 x 1.18”) Clear Anodize
51mm (2”) Max, 12.7mm (0.5”) Min
2 Max (~720W Total), 35-50MM (1.38-2”) Thickness
TPS-24-360W (24V 360W 72 Cell)
~1.5 degrees (in addition to roof tilt)
100mph
1100 x 240 x 100mm (44 x 9.5 x 4”)
5.4kg (12lbs)
3 years
System Ordering:
TPSM-ROOF-MOUNT Asphalt Shingle Roof Mount Kit for two 250-360W Solar Panels
For further information contact:
Tyconsystems.com
TPSM-ROOF-MOUNT Spec Sheet
Rev 1 27-Jan-22
Specifications Subject to Change Without Notice
14641 S 800 W
Bluffdale, UT 84065
PH: 801-432-0003
FAX: 801-618-4220
很抱歉,暂时无法提供与“TPSM-ROOF-MOUNT”相匹配的价格&库存,您可以联系我们找货
