SCD-1200-4GATCD
SCD-1200-4GATCD
    SENSAPHONE(Sensaphone)
    SENSAPHONE SENTINEL CELLULAR
SCD-1200-4GATCD 数据手册
Sentinel Technical Specifications ALARM NOTIFICATION METHODS: BATTERY BACKUP: E-Mail, Text Messages, Voice Phone Calls 4.8V 2000mAHr NiMh Battery pack (included) Programmable alarm escalation levels Provides 8 hours of backup Comprehensive scheduling per input, profile, and alarm destination LOCAL INDICATORS: Unlimited number of User Profiles 12 Alarm Status LEDs Multiple contact types per user • Power LED • Online LED INPUTS: 12 Universal Inputs • Standby LED • Ethernet link and Activity LEDs POWER REQUIREMENTS: • Normally Open / Normally Closed Dry Contact Comes with 12VDC plug-in power supply. • 2.8K / 10K Thermistor (International power options available). • 4-20mA Current Loop • Pulse Count • 12 Bit Resolution TEMPERATURE SENSING RANGE: -109° to 168°F | -85° to 76°C RELAY OUTPUT: Programmable. Rated for 1A 30VAC/ 1A 30VDC DATA LOGGING: Unlimited samples securely stored on the Sentinel servers Programmable sampling interval - 1 min to 24 hrs User programmable channel selection COMMUNICATION PORTS: Ethernet 10/100Base–T ENVIRONMENTAL: Operating Humidity: 0-90% RH, non–condensing Operating Temperature: 32° to 122°F | 0° to 50°C PHYSICAL: In metal enclosure: 5.5 x 6.3 x 1.5” | 140 x 160 x 38mm 1 lb. | .45kg With Weatherproof Enclosure: 12.17 x 10.25 x 3.5” | 309 x 260 x 89mm 3.7 lb. | 1.67 kg ENCLOSURE: Durable powder coated metal housing suitable for wall or panel installation or weatherproof NEMA 4X rated fiberglass enclosure. STANDARDS: FCC Part 15 – Class A Compliant 901 Tryens Road • Aston, PA 19014 • PH: 877-373-2700 • F: 610-558-0222 • www.sensaphone.com
SCD-1200-4GATCD 价格&库存
很抱歉,暂时无法提供与“SCD-1200-4GATCD”相匹配的价格&库存,您可以联系我们找货
