FGD-WSG30
FGD-WSG30
    SENSAPHONE(Sensaphone)
    SENSAPHONE WSG30
FGD-WSG30 数据手册
Sensaphone WSG30 Web Based Monitoring with Wireless Sensors ASSURANCE COUNTLESS INDUSTRIES DEPEND ON SENSAPHONE FOR THE MOST COMPREHENSIVE REMOTE MONITORING SOLUTIONS AVAILABLE. WHEN YOU NEED TO BE ABSOLUTELY SURE A REMOTE SITE IS STABLE, SECURE AND MONITORED AROUND THE CLOCK, THERE’S NO SUBSTITUTE FOR CERTAINTY. Easy to use – everyday We’ve got a sensor for that Your business is our business The Sensaphone WSG30 is so easy to use just about anyone can figure it out. If not, we offer free tech support to walk you through it. Sensaphone has a sensor for monitoring everything from climate conditions to security and more. With over 350,000 systems installed worldwide, we’ve put Sensaphone to the test in just about every application imaginable. Suggested Applications Industrial & Manufacturing Know that the temperature, humidity, or other conditions in your shop or factory are okay while you’re away. Data Center Use your WSG30 to monitor temperature, power failure and other conditions that are critical in many data center applications. Vaccine & Medical Storage Don’t wait until the morning to find out your freezer has stopped running. The WSG30 will e–mail as soon as the temperature rises above a temperature you set. Sensaphone WSG30 Features and Specifications Powerful Wireless Sensors Battery Backup Accept thirty different wireless sensors from distances of up to 300’ away (or farther if there is a line of site or are other sensors in between). A list of popular sensors and accessories is below. Rest easy knowing that even if the power goes out, the WSG30 will keep monitoring. LCD Display For a quick local check of the sensor’s status. WSG Keypad Wireless Use to scroll through the LCD display. Ethernet Power Receive an e–mail or text message when an alarm has been detected. Or check the status on the WSG30’s web page. Comes with a plug in power supply that also monitors for power failures. Web Services Industrial Automation Program, adjust and monitor the status of the sensors on a webpage the WSG30 creates. Communicate with an existing automation system using the Modbus protocol. Compatible Sensors & Accessories Temperature Sensor . . . . . . . . . . . . . . . .FGD-WSG30-TMP Dry Contact Interface. . . . . . . . . . . . . . . .FGD-WSG30-DRY Temperature Sensor w/ External Probe . . . . . . . . . . . . . . . . . . . FGD-WSG30-TEX Power Failure Sensor . . . . . . . . . . . . . . . FGD-WSG30-PWR WSG Wireless Humidity Sensor . . . . FGD-WSG30-HUM SENSAPHONE® 901 TRYENS ROAD ASTON, PA 19014 PH: 877-373-2700 F: 610-558-0222 WWW.SENSAPHONE.COM 4-20mA Interface . . . . . . . . . . . . . . . . . . . FGD-WSG30-4-20 Spot Water Detection Sensor . . . . . . FGD-WSG30-SPOT Zone Water Detection Sensor . . . . . FGD-WSG30-ZONE Distributed By: LIT-1020 © SENSAPHONE 12/2013 Ultra Low Temperature Sensor w/ External Probe . . . . . . . . . . . . . . . . .FGD-WSG30-TEX85
FGD-WSG30 价格&库存
很抱歉,暂时无法提供与“FGD-WSG30”相匹配的价格&库存,您可以联系我们找货
