CCD
Series
Safety Standard Recognized Ceramic Capacitors
TRIGON
COMPONENTS
Configuration
Capacitor
FEATURES
• Complying with IEC60384-14 4th Edition
• Class X1Y1 and Class X1Y2
• Dielectric Strength: AC2600V (r.m.s) for
X1Y2 and AC4000V (r.m.s) for X1Y1
• High Reliability
• Coated With Flame-Retardant Epoxy Resin
(Conforming to UL94V-0 Standard)
• RoHS Compliant
APPLICATIONS
• Ideal for use as X/Y capacitor for AC
Line Filter and Primary/Secondary
Coupling on Switching Power Supplies
and AC adapters
• Across-The-Line
• Antenna-Coupling
• Line-By-Pass
ORDERING CODE
CCD - 1 09 B 101 K H 7 2
(1)
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(2)
(3)
(4)
(5)
(6) (7) (8)
(9)
Ceramic Disc Capacitor
Class Type
Diameter Code
Ceramic Dielectric
Capacitance Code
Tolerance Code
Lead Style
Lead Spacing
Lead Length or Taping
※ Please refer to Ordering Code
document CCD_Safety–Order for more
ordering options.
Approval Standard and Recognized Number
Approval
Agency
VDE/ENEC10
CSA
UL
Rev. B4
Number
40040454
40046396
40040445
40046520
222903
E197459
X1/Y1
CCD-1
CCD-1
CCD-1
X1/Y2
CCD-2
CCD-2
CCD-2
Sheet 1 of 12
CCD
Series
TRIGON
COMPONENTS
Specification
Characteristics
Class X1, Y1
Class X1, Y2
100pF to 4700pF
5.1pF to 10000pF
Operating Temperature Range
-40°C to 125°C
Y5P, Y5V, Y5U: -40°C to 125°C
COG, X7R: -55°C to 125°C
SL: +40°C to +125°C
Rated Voltage
X1: 760/400VAC, Y1: 500/250VAC
X1: 440/400VAC, Y2: 300/250VAC
Dielectric Withstanding Voltage
4000VAC for 1 minute
2600VAC for 1 minute
Within the specified tolerance
Y5P, Y5U, Y5V, X7R measured at 1KHz ± 20%
COG measured at 1MHz ± 20%
Both are 1 Vrms, 25°C
Capacitance
Tanδ ≦ 2.5% for char.
Both are 1 Vrms, 25°C, Quality Factor ≧ 600 for char.
Dissipation Factor (tan δ)
10,000 M min. at 500VDC
Insulation Resistance
Class X1, Y1
Part Number
Temp.
Char.
Cap.(pF)
Cap. Tol.
D
(Max. mm)
CCD-107S100J□□□
10
7.0
CCD-107S150J□□□
15
7.0
CCD-107S200J□□□
CCD-107S220J□□□
S
(SL)
22
± 5%
7.0
CCD-107S330J□□□
33
7.0
CCD-108S470J□□□
47
8.0
CCD-109S680J□□□
68
9.0
CCD-109B101KK0□
100
CCD-109B151KK0□
150
CCD-109B221KK0□
220
CCD-109B331KK0□
CCD-109B471KK0□
CCD-109B561K□□□
B
(Y5P)
± 10%
10
5
Φd
(mm)
9.0
± 10%
8
10
560
CCD-110B821K□□□
820
CCD-110B681KK0□
680
CCD-111B102K□□□
1000
Rev. B4
T
(Max. mm)
0.55±0.1
330
470
F
(mm)
10.0
5
11.0
Sheet 2 of 12
Capacitor
Capacitance Range
CCD
Series
TRIGON
COMPONENTS
Part Number
E
(Y5U)
+ 20%
-55%
Y5V
Cap.(p
F)
1000
1500
2200
3300
3900
4700
1000
1500
2200
3300
4700
Cap. Tol.
± 20%
± 20%
D
(Max. mm)
F
(mm)
9.0
11.0
12.0
14.0
15.0
16.0
7.0
8.0
9.0
10.0
12.0
10
D
(Max. mm)
F
(mm)
T
(Max. mm)
Φd
(mm)
8
0.55±0.1
Capacitor
CCD-109E102MK0□
CCD-111E152MK0□
CCD-112E222MK0□
CCD-114E332MK0□
CCD115E392MK0□
CCD-116E472MK0□
CCD-107F102K□□□
CCD-108F152K□□□
CCD-109F222K□□□
CCD-110F332K□□□
CCD-112F472K□□□
Temp.
Char.
5.5
Class X1, Y2
Part Number
CCD-208C100JK□□
CCD-208B5R1CK□□
CCD-208B100KK□□
CCD-208B150KK□□
CCD-208B180KK□□
CCD-208B220KK□□
CCD-208B101K□□□
CCD-208B151K□□□
CCD-208B221K□□□
CCD-208B331K□□□
CCD-208B471K□□□
CCD-209B561K□□□
CCD-209B681K□□□
CCD-209B821K□□□
CCD-210B102K□□□
CCD-207S150J□□□
CCD-207S200J□□□
CCD-207S220J□□□
CCD-207S330J□□□
CCD-207S470J□□□
CCD-208S680J□□□
CCD-208E102M□□□
CCD-209E152M□□□
CCD-210E222M□□□
CCD-211E252M□□□
CCD-212E332M□□□
CCD-213E392M□□□
CCD-214E472M□□□
CCD-208F102M□□□
CCD-208F152M□□□
CCD-209F222M□□□
CCD-210F332M□□□
CCD-211F392M□□□
CCD-212F472M□□□
CCD-216F103M□□□
Rev. B4
Temp.
Char.
Cap.
(pF)
C(COG)
10
5.1
10
15
18
22
100
150
220
330
470
560
680
820
1000
15
33
47
68
1000
1500
2200
2500
3300
3900
4700
1000
1500
2200
3300
3900
4700
10000
B
(Y5P)
±10%
S
(SL)
E
(Y5U)
+20%
-55%
F
(Y5V)
+30%
-80%
Cap. Tol.
T
(Max. mm)
Φd
(mm)
±5%
7
8.0
7.5
±0.25pF
±10%
8
9.0
10.0
±5%
±20%
7.0
8.0
8.0
9.0
10.0
11.0
12.0
13.0
14.0
8.0
5.0 / 7.5
7.5
5
8
7.5
5
7.5
0.55±0.1
8
9.0
±20%
10.0
11.0
12.0
16.0
10
Sheet 3 of 12
CCD
Series
TRIGON
COMPONENTS
Typical characteristic curves £ º
Z(Impedance) vs. frequency
SL,Y5P,Y5U,Y5V
100
SL
SL
Y5P
Inpedance(%)
-10
Y5P
-20
-30
-40
Y5U
-50
Y5U
10
Capacitor
Cap.Change (%)
100pF(B)
220pF(B)
470pF(B)
1000pF(E)
2200pF(E)
47000pF(E)
10000pF(F)
-60
-70
-80
Y5V
Y5V
-90
0.1
-100
-40
-20
60
80
100
1
10
100
1000
Frequency (MHz)
Temp.(¡ã
C)
Note: Above data are just for reference not asurred ones.
Leakage current characteristics (Type X1 Y 1: 0~4000Vac):
X1 Y1
X1 Y1
AC Valtage:60Hz
Temp.:25¡ã
C
AC Valtage:60Hz
Temp.:25¡ã
C
1000pF(B)
2.2
6.0
680pF(B)
1.8
1.6
1.4
1.2
1.0
470pF(B)
330pF(B)
0.8
0.6
0.4
0.2
220pF(B)
150pF(B)
100pF(B)
500 1000 1500 2000 2500 3000 3500 4000
Voltage(Vrms)
4700pF(E)
5.0
560pF(B)
Current (mA)
Current (mA)
2.0
4.0
3300pF(E)
3.0
2200pF(E)
2.0
1500pF(E)
1000pF(E)
1.0
Voltage(Vrms)
Rev. B4
Sheet 4 of 12
CCD
Series
TRIGON
COMPONENTS
SL,Y5P,Y5U,Y5V
100
SL
Cap.Change (%)
Y5P
-20
-30
-40
Y5U
Y5U
-50
10
Capacitor
-10
Inpedance(%)
SL
Y5P
1
100pF(B)
220pF(B)
470pF(B)
1000pF(E)
2200pF(E)
47000pF(E)
10000pF(F)
-60
-70
-80
Y5V
Y5V
-90
-100
-40
0.1
-20
60
80
10
1
100
1000
100
Frequency (MHz)
Temp.(¡ã
C)
Leakage current characteristics (Type X1 Y2: 0~2600Vac):
X1 Y2
X1 Y2
AC Valtage:60Hz
Temp.:25¡ã
C
AC Valtage:60Hz
Temp.:25¡ã
C
10000pF(E)
6.0
5.0
2.0
1.8
1.6
1.4
1.2
1.0
1000pF(B)
820pF(B)
680pF(B)
560pF(B)
470pF(B)
0.8
330pF(B)
0.6
0.4
0.2
Current (mA)
Current (mA)
2.2
4700pF(E)
4.0
3.0
3300pF(E)
2.0
2200pF(E)
1500pF(E)
220pF(B)
150pF(B)
100pF(B)
Voltage(Vrms)
1.0
1000pF(E)
Voltage(Vrms)
Rev. B4
Sheet 5 of 12
CCD
Series
TRIGON
COMPONENTS
Packing Information
Capacitor
Straight
Inside Kink
Item
Symbol
Pitch of component
Feed hole pitch
Lead to lead distance
Feed hole center to lead
Hold center to component center
Body diameter
Body thickness
Lead-wire diameter
Component alignment F-R
Tape width
Hold-down tape width
Hold position
Hold-down tape position
Height of component from tape center
Lead wire clinch
Component height
Lead wire protrusion
Feed hole diameter
Total tape thickness
Maximum thickness of tape and wire
P
P0
F
P1
P2
D
T
D
h
W
W0
W1
W2
H
H0
H1
D0
T1
T2
Specification (mm)
5T1/5R1
12.7
12.7
5+0.8/-0.2
3.85
6.35
11Max.
5.0
0.6
7T1/7R1
12.7
12.7
7.5±1.0
8.95
11Max.
7T5/7R5
15
15
7.5±1.0
3.75
11
很抱歉,暂时无法提供与“CCD-115E392MK02”相匹配的价格&库存,您可以联系我们找货
