BLF8G22LS-140
Power LDMOS transistor
Rev. 3 — 1 September 2015
Product data sheet
1. Product profile
1.1 General description
140 W LDMOS power transistor for base station applications at frequencies from
2000 MHz to 2200 MHz.
Table 1.
Typical performance
Typical RF performance at Tcase = 25 C in a common source class-AB production test circuit.
Test signal
2-carrier W-CDMA
[1]
f
IDq
VDS
PL(AV)
Gp
D
ACPR
(MHz)
(mA)
(V)
(W)
(dB)
(dBc)
2110 to 2170
900
28
33
18.5
32.5
31[1]
Test signal: 3GPP test model 1; 64 DPCH; PAR = 8.4 dB at 0.01 % probability on CCDF;
carrier spacing 5 MHz.
1.2 Features and benefits
Excellent ruggedness
High efficiency
Low Rth providing excellent thermal stability
Designed for broadband operation (2000 MHz to 2200 MHz)
Lower output capacitance for improved performance in Doherty applications
Designed for low memory effects providing excellent digital pre-distortion capability
Internally matched for ease of use
Integrated ESD protection
Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances
(RoHS)
1.3 Applications
RF power amplifiers for W-CDMA base stations and multi carrier applications in the
2000 MHz to 2200 MHz frequency range
BLF8G22LS-140
2. Pinning information
Table 2.
Pinning
Pin
Description
1
drain
2
gate
3
source
Simplified outline
Graphic symbol
1
1
3
[1]
2
2
3
sym112
[1]
Connected to flange.
3. Ordering information
Table 3.
Type number
Package
BLF8G22LS-140
Name Description
Version
SOT502B
earless flanged ceramic package; 2 leads
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Min
Max
Unit
VDS
drain-source voltage
65
V
VGS
gate-source voltage
0.5
+13
V
Tstg
storage temperature
65
+150
C
225
C
Unit
[1]
junction temperature
Tj
[1]
Conditions
Continuous use at maximum temperature will affect the reliability.
5. Thermal characteristics
Table 5.
BLF8G22LS-140#3
Product data sheet
Symbol
Parameter
Conditions
Typ
Rth(j-c)
thermal resistance from junction to case
Tcase = 80 C; PL = 33 W
0.265 K/W
All information provided in this document is subject to legal disclaimers.
© Ampleon The Netherlands B.V. 2015. All rights reserved.
2 of 12
BLF8G22LS-140
6. Characteristics
Table 6.
DC characteristics
Tj = 25 C unless otherwise specified.
Symbol
Parameter
Conditions
Min Typ
V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.53 mA
Max
Unit
65
V
VGS(th)
gate-source threshold voltage
VDS = 10 V; ID = 153 mA
1.5
1.9
2.3
V
VGSq
gate-source quiescent voltage
VDS = 28 V; ID = 900 mA
1.7
2.0
2.5
V
IDSS
drain leakage current
VGS = 0 V; VDS = 28 V
4.2
A
IDSX
drain cut-off current
VGS = VGS(th) + 3.75 V;
VDS = 10 V
29.1 -
A
IGSS
gate leakage current
VGS = 11 V; VDS = 0 V
420
nA
gfs
forward transconductance
1.3
S
RDS(on)
drain-source on-state resistance VGS = VGS(th) + 3.75 V;
ID = 5.355 A
0.1
Table 7.
RF characteristics
Test signal: 2-carrier W-CDMA; PAR = 8.4 dB at 0.01 % probability on the CCDF; carrier spacing
5 MHz; 3GPP test model 1; 1 - 64 DPCH; f1 = 2112.5 MHz; f2 = 2117.5 MHz; RF performance at
VDS = 28 V; IDq = 900 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test
circuit.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Gp
D
power gain
PL(AV) = 33 W
17.3
18.5
dB
drain efficiency
PL(AV) = 33 W
29
32.5
RLin
input return loss
PL(AV) = 33 W
10
6
dB
ACPR
adjacent channel power ratio
PL(AV) = 33 W
31
27
dBc
7. Test information
7.1 Ruggedness in class-AB operation
The BLF8G22LS-140 is capable of withstanding a load mismatch corresponding to
VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V;
IDq = 900 mA; PL = 140 W (CW); f = 2110 MHz.
7.2 Impedance information
Table 8.
Typical impedance
Measured load-pull data; IDq = 900 mA; VDS = 28 V.
f
ZS[1]
ZL[1]
(MHz)
2210
1.66 j4.54
1.50 j3.12
2140
1.87 j4.70
1.50 j3.12
2170
2.61 j5.48
1.50 j3.12
[1]
BLF8G22LS-140#3
Product data sheet
ZS and ZL defined in Figure 1.
3 of 12
BLF8G22LS-140
drain
ZL
gate
ZS
001aaf059
Fig 1.
Definition of transistor impedance
7.3 Test circuit
50 mm
50 mm
C13
C9
C7
C2
C4
C11
R1
70 mm
C1
C6
BLF8G22-140_INPUT
BLF8G22-140_OUTPUT
R2
C8
C5
C3
C12
C10
aaa-006927
Printed-Circuit Board (PCB): Rogers 4350B; r = 3.66; thickness = 0.765 mm;
thickness copper plating = 35 m.
See Table 9 for a list of components.
Fig 2.
Component layout for class-AB production test circuit
Table 9.
List of components
For test circuit see Figure 2.
BLF8G22LS-140#3
Product data sheet
Component
Description
C1, C2, C3, C4, C5, C6
multilayer ceramic chip capacitor 9.7 pF
Value
[1]
ATC800B
C7, C8, C9, C10
multilayer ceramic chip capacitor 1 F
[2]
Murata
C11, C12
multilayer ceramic chip capacitor 10 F
[2]
Murata
C13
electrolytic capacitor
470 F, 63 V
R1, R2
chip resistor
6.2
[1]
American Technical Ceramics type 800B or capacitor of same quality.
[2]
Murata or capacitor of same quality.
Remarks
Vishay Dale
SMD 0805
4 of 12
BLF8G22LS-140
7.4 Graphical data
7.4.1 1-Tone CW
aaa-006928
22
70
Gp
(dB)
ηD
Gp
18
50
(1)
(1)
(2)
(2)
(3)
(3)
16
40
14
30
ηD
12
10
80
120
160
PL (W)
10
200
VDS = 28 V; IDq = 900 mA.
(1) f = 2110 MHz
(2) f = 2140 MHz
(3) f = 2170 MHz
Fig 3.
Power gain and drain efficiency as function of output power; typical values
7.4.2 CW pulsed
aaa-006929
22
70
Gp
(dB)
ηD
Gp
18
50
(1)
(1)
(2)
(2)
(3)
(3)
16
40
14
30
ηD
12
10
80
120
160
PL (W)
10
200
VDS = 28 V; IDq = 900 mA; tp = 100 s; = 10 %.
(1) f = 2110 MHz
(2) f = 2140 MHz
(3) f = 2170 MHz
Fig 4.
BLF8G22LS-140#3
Product data sheet
5 of 12
BLF8G22LS-140
7.4.3 1-Carrier W-CDMA
aaa-006930
Gp
(dB)
18
50
Gp
(1)
(1)
(2)
(2)
(3)
(3)
16
aaa-006931
ACPR5M
(dBc)
-10
ηD
-20
40
(3)
(2)
(1)
-30
14
30
-40
ηD
12
10
60
80
PL (W)
-50
10
100
-60
80
PL (W)
100
(1) f = 2110 MHz
(1) f = 2110 MHz
(2) f = 2140 MHz
(2) f = 2140 MHz
(3) f = 2170 MHz
(3) f = 2170 MHz
Fig 5.
40
Fig 6.
Adjacent channel power ratio (5MHz) as a
aaa-006932
8
PAR
(dB)
7
(1)
(2)
(3)
6
5
4
60
80
PL (W)
100
(1) f = 2110 MHz
(2) f = 2140 MHz
(3) f = 2170 MHz
Fig 7.
Peak-to-average power ratio as a function of output power; typical values
BLF8G22LS-140#3
Product data sheet
6 of 12
BLF8G22LS-140
7.4.4 2-Carrier W-CDMA
aaa-006933
22
50
Gp
(db)
ηD
Gp
(1)
(2)
(3)
-20
18
30
(1)
(1)
(2)
(2)
(3)
(3)
-30
16
ηD
14
12
aaa-006934
ACPR5M
(dBc)
-10
10
40
50
PL (W)
60
-50
(1) f = 2110 MHz
(2) f = 2140 MHz
(2) f = 2140 MHz
(3) f = 2170 MHz
(3) f = 2170 MHz
BLF8G22LS-140#3
Product data sheet
30
40
50
PL (W)
60
(1) f = 2110 MHz
Fig 8.
Fig 9.
7 of 12
BLF8G22LS-140
8. Package outline
Earless flanged ceramic package; 2 leads
SOT502B
D
A
F
3
D
D1
c
U1
1
L
H
E1
U2
E
2
w2 M D M
b
Q
10 mm
scale
DIMENSIONS (millimetre dimensions are derived from the original inch dimensions)
UNIT
A
b
c
mm
4.72
3.43
12.83
12.57
0.15
0.08
inches
0.186
0.135
0.505 0.006
0.495 0.003
OUTLINE
VERSION
D
E
E1
F
H
L
Q
U1
U2
w2
20.02 19.96
19.61 19.66
9.50
9.30
9.53
9.25
1.14
0.89
19.94
18.92
5.33
4.32
1.70
1.45
20.70
20.45
9.91
9.65
0.25
0.788 0.786
0.772 0.774
0.374 0.375
0.366 0.364
0.045 0.785
0.035 0.745
0.210
0.170
0.067 0.815
0.057 0.805
D1
REFERENCES
IEC
JEDEC
JEITA
0.390
0.010
0.380
EUROPEAN
PROJECTION
ISSUE DATE
07-05-09
12-05-02
SOT502B
Fig 10. Package outline SOT502B
BLF8G22LS-140#3
Product data sheet
8 of 12
BLF8G22LS-140
9. Handling information
CAUTION
This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling
electrostatic sensitive devices.
Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or
equivalent standards.
10. Abbreviations
Table 10.
Abbreviations
Acronym
Description
3GPP
3rd Generation Partnership Project
CCDF
Complementary Cumulative Distribution Function
CW
Continuous Wave
DPCH
Dedicated Physical CHannel
ESD
LDMOS
Laterally Diffused Metal Oxide Semiconductor
PAR
Peak-to-Average Ratio
SMD
Surface Mounted Device
VSWR
Voltage Standing Wave Ratio
W-CDMA
Wideband Code Division Multiple Access
11. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
BLF8G22LS-140#3
20150901
Product data sheet
Modifications:
Change notice
Supersedes
BLF8G22LS-140 v.2
The format of this document has been redesigned to comply with the new
identity guidelines of Ampleon.
Legal texts have been adapted to the new company name where appropriate.
BLF8G22LS-140 v.2
20130410
Product data sheet
BLF8G22LS-140 v.1
BLF8G22LS-140 v.1
20120925
Objective data sheet
BLF8G22LS-140#3
Product data sheet
9 of 12
BLF8G22LS-140
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.ampleon.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Ampleon does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Ampleon sales office. In
case of any inconsistency or conflict with the short data sheet, the full data
sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Ampleon and its customer, unless Ampleon and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be valid
in which the Ampleon product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Ampleon does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Ampleon takes no responsibility for
the content in this document if provided by an information source outside of
Ampleon.
In no event shall Ampleon be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost profits,
lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Ampleon’ aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Ampleon.
Right to make changes — Ampleon reserves the right to make changes to
information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Ampleon products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction of an
BLF8G22LS-140#3
Product data sheet
Ampleon product can reasonably be expected to result in personal injury,
death or severe property or environmental damage. Ampleon and its
suppliers accept no liability for inclusion and/or use of Ampleon products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Ampleon makes no representation
or warranty that such applications will be suitable for the specified use without
further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Ampleon products, and Ampleon accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Ampleon product is suitable and
fit for the customer’s applications and products planned, as well as for the
planned application and use of customer’s third party customer(s). Customers
should provide appropriate design and operating safeguards to minimize the
risks associated with their applications and products.
Ampleon does not accept any liability related to any default, damage, costs or
problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Ampleon products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Ampleon does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Ampleon products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.ampleon.com/terms, unless otherwise agreed in a valid written
individual agreement. In case an individual agreement is concluded only the
terms and conditions of the respective agreement shall apply. Ampleon
hereby expressly objects to applying the customer’s general terms and
conditions with regard to the purchase of Ampleon products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
10 of 12
BLF8G22LS-140
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Ampleon product is automotive qualified, the product
is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Ampleon
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Ampleon’ warranty of the product for such
automotive applications, use and specifications, and (b) whenever customer
uses the product for automotive applications beyond Ampleon’ specifications
such use shall be solely at customer’s own risk, and (c) customer fully
indemnifies Ampleon for any liability, damages or failed product claims
resulting from customer design and use of the product for automotive
applications beyond Ampleon’ standard warranty and Ampleon’ product
specifications.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Any reference or use of any ‘NXP’ trademark in this document or in or on the
surface of Ampleon products does not result in any claim, liability or
entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of
the NXP group of companies and any reference to or use of the ‘NXP’
trademarks will be replaced by reference to or use of Ampleon’s own Any
trademarks.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
13. Contact information
For more information, please visit:
BLF8G22LS-140#3
Product data sheet
For sales office addresses, please visit:
http://www.ampleon.com/sales
11 of 12
BLF8G22LS-140
14. Contents
1
1.1
1.2
1.3
2
3
4
5
6
7
7.1
7.2
7.3
7.4
7.4.1
7.4.2
7.4.3
7.4.4
8
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 2
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3
Ruggedness in class-AB operation . . . . . . . . . 3
Impedance information . . . . . . . . . . . . . . . . . . . 3
Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 5
1-Tone CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
CW pulsed . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
1-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 6
2-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Handling information. . . . . . . . . . . . . . . . . . . . . 9
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
For more information, please visit: http://www.ampleon.com
For sales office addresses, please visit: http://www.ampleon.com/sales
Date of release: 1 September 2015
Document identifier: BLF8G22LS-140#3
