CCD-B14B103K501Y05D
CCD-B14B103K501Y05D
    TRIGON(三弦)
    Radial
    贴片电容(MLCC) 径向 10µF ±10% 500V X5P
CCD-B14B103K501Y05D 数据手册
CCD Series Ceramic Disc Capacitors TRIGON COMPONENTS Configuration Capacitor FEATURES Class I: Temperature Compensation • Linear Temp. coeff. Of capacitance. • High stability of capacitance. • Low loss at wide range of frequency. • RoHS Compliant Class II: High Dielectric Constant • Non linear temp. coeff. Of capacitance. • Large capacitance in small size. --- : High Voltage • High Insulation Resistance. • RoHS Compliant Class III: Semi Conductive. • Stable Temperature Characteristics. • Ultra Large Capacitance in Small Size. • High Volumetric Efficiency. • RoHS Compliant ORDERING CODE CCD - C 05 E 104 M 500 L 5 1 D H (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (1) Ceramic Disc Capacitor. (2) Class. (3) Diameter Code. (4) Temp. Characteristics. (5) Capacitance Code. (6) Tolerance Code. (7) Rated Voltage Code. (8) Lead Style. (9) Lead Spacing Code. (10) Package & Lead Length. (11) Coating. (12) High Voltage Type Option ※Please refer to complete Ordering Code document (CCDOrd) for more ordering options. Rev. B0 Sheet 1 of 17 CCD Series Ceramic Disc Capacitors TRIGON COMPONENTS Class I: Temperature Compensation Type. WV Lead Spacing ‘F’ (mm) ±1.0 Temp. Char. (ppm/ºC) 0±60 1KV 2KV 2.5mm, 5.0mm 5.0mm 5.0mm, 7.5mm 5.0mm, 7.5mm P/R (PH/PR) 150±60 -220±60 U (UJ) S (SL) C S C S C S -750±120 +350±1000 0±60 +350±1000 0±60 +350±1000 0±60 +350±1000 05 08 05 05 05 05 05 05 06 05 05 09 06 06 06 07 10 07 06 07 06 08 07 08 07 08 09 08 09 10 09 06 08 09 07 10 11 06 07 06 11 12 13 14 10 11 11 12 14 12 14 09 10 12 08 08 10 07 = Diameter Code Rev. B0 500V (250V) Capacitor Cap. pF 0.5 1.0 1.5 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0 10 12 15 18 20 22 24 27 30 33 39 43 47 56 68 82 100 120 150 180 200 220 240 270 300 330 390 470 560 680 820 1000 ‘T’ (mm) Max C (CH/NPO) 50V (100V) 13 09 14 10 15 16 09 08 10 11 12 09 10 4mm 5mm Sheet 2 of 17 CCD Series Ceramic Disc Capacitors TRIGON COMPONENTS Class II: High Dielectric Constant Type. WV 50V(100V) Lead Spacing ‘F’ (mm) ±1.0 Temp. Char. (%) E Y5U) U (Z5U) +22,-56 F (Y5V) V (Z5V) +22,-82 1KV 5.0mm, 7.5mm 5.0mm, 7.5mm, 10mm B (Y5P) ±10 E (Y5U) U (Z5U) +22,-56 F (Y5V) V (Z5V) +22,-82 B (Y5P) ±10 E (Y5U) U (Z5U) +22,-56 2KV F (Y5V) V (Z5V) +22,-82 5.0mm, 7.5mm, 10mm B (Y5P) ±10 E (Y5U) +22,-56 F (Y5V) +22,-82 07 Capacitor Cap. pF 100 120 150 180 200 220 270 300 330 390 470 500 560 680 820 1000 1200 1500 1800 2000 2200 2700 3300 3900 4700 5600 6800 8200 10000 12000 15000 18000 20000 22000 27000 33000 39000 40000 47000 56000 68000 82000 100000 ‘T’ (mm) Max 2.5mm, 5.0mm B (Y5P) ±10 500V(250V) 05 05 05 05 08 05 05 07 09 05 06 05 06 10 08 07 11 07 08 08 06 09 06 07 10 07 12 07 08 14 15 17 09 12 08 14 08 09 06 07 08 09 14 06 08 10 09 12 09 10 08 09 06 09 10 12 08 19 10 21 10 16 11 10 13 15 16 17 11 13 12 19 14 07 14 12 17 21 23 16 19 12 08 09 16 20 20 4mm 5mm = Diameter Code Rev. B0 Sheet 3 of 17 CCD Series Ceramic Disc Capacitors TRIGON COMPONENTS Class I: High Voltage Type. WV 2KV 3KV 6KV Lead Spacing ‘F’ (mm) ±1.0 5.0mm, 7.5mm 7.5mm 10mm Temp. Char. (ppm/ºC) ‘T’ (mm) Max C (NPO) S (SL) C (NPO) S (SL) C (NPO) Cap. Tol. 05 05 05 05 05 05 C,D,J,K 06 08 Capacitor Cap. pF 1.0 1.5 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0 10 12 15 18 20 22 24 27 30 33 39 43 47 56 68 82 100 120 150 180 200 220 240 270 300 330 390 470 S (SL) CG 07 05 HH 05 08 07 09 FF HH 06 08 08 10 FF II JJ 06 06 09 08 09 11 12 GG KK LL MM OO PP 07 10 11 12 15 16 09 12 HH II JJ 08 09 10 KK 11 LL 12 NN 14 OO PP QQ 15 16 17 5mm 6mm J,K 7mm 8mm = Diameter Code Rev. B0 Sheet 4 of 17 CCD Series Ceramic Disc Capacitors TRIGON COMPONENTS Class II: High Voltage Type. WV Lead Spacing ‘F’ (mm) ±1.0 Temp. Char. (%) ‘T’ (mm) Max ±10 +22, -56 +22, -82 B ±10 3KV 6KV 8KV 7.5mm, 10mm 10mm 10mm E F +22, -56 +22, -82 B ±10 E F +22, -56 +22, -82 B ±10 10KV 10mm E F +22, -56 +22, -82 B ±10 06 06 09 JJ KK 06 06 09 JJ KK 06 06 09 KK KK 06 06 09 KK 11 07 07 10 12 MM 07 07 07 08 10 11 MM NN 13 14 E F +22, -56 +22, -82 Capacitor Cap. pF 100 120 150 180 200 220 270 300 330 390 470 500 560 680 820 1000 1200 1500 1800 2000 2200 2700 3300 3900 4700 5600 6800 8200 10000 2KV 5.0mm, 7.5mm, 10mm E F B 09 07 06 09 07 06 13 JJ II PP 11 JJ QQ 12 KK 09 08 07 11 08 07 16 11 JJ SS 13 11 UU 14 LL 10 08 07 12 09 07 MM KK 15 MM QQ NN 10 10 08 15 11 09 15 13 17 OO UU PP 10 12 13 13 09 10 11 19 13 14 15 10 12 12 PP SS 20 14 PP 17 UU QQ SS TT 22 SS TT VV 14 12 17 14 5mm 6.5mm UU 8mm 9mm 10mm = Diameter Code General Specification: 1. Capacitance (C ): 100pF~10000pF measured at 25ºC with 1±0.1KHz and 3Vrms max. 2. Dissipation Factor (DF): 25ºC with 1±0.1KHz and 3Vrms max. 3. Insulation Resistance (IR): 10000MOhm Min. measured with DC500±50V within 60V5 s of charging. 4. Dielectric Strength: Apply DC Test Voltage W.V.(2~3KV is 200%, 5KV >= W.V. >=3KV is 175%, W.V.>5KV is 150%) for 1~5 sec (Charge/Discharge current
CCD-B14B103K501Y05D 价格&库存
很抱歉,暂时无法提供与“CCD-B14B103K501Y05D”相匹配的价格&库存,您可以联系我们找货
