Isolated Digital I/O Products
S C M D
SCMD-MOAC/MODC
Miniature Digital Output Modules
Description
The SCMD digital output modules are used for switching AC and DC loads
such as relays, solenoids, motor starters, or indicator lamps. All models
provide up to
rms of optical isolation between the field device
and the control logic. The AC output modules incorporate zero voltage
switching and an R snubber circuit which allows switching heavy
inductive loads. Functionality is denoted by case color A modules are
blac , and D modules are red.
Six bac panels are available for mounting S
modules. See “Accessories” section.
D
digital output
Features
• AC Modules have High Current Thyristor with
Amp Surge apability
ero or Random Turn On Available in A
Modules
• Plug into Backpanels for Miniature or Full-Sized
Modules
rms Optical Isolation except L suffix
rms Optical Isolation with L suffix
• Industry Standard Pinout and Footprint
• 3.5 Amp AC Modules Provide Extra Switching
apability
. Amp D
odules Available
Operating Temperature
to
L Listed, SA ertified,
ompliant
Ordering Information
F ig u r e 1 : S C M D - M O A C /M O D C
P h ysi
ca
l D i m e n si o n s
i ita ut ut o u es o e o u fi es enti in
tiona eatures
u fi
Feature
A
High voltage versions (280VAC for AC modules, 200VDC for DC modules).
B
High voltage version (280VAC for AC modules)
with low leakage output current.
ML
FET output version of DC module, 5.0A, 50VDC.
F ig u r e 2 : S C M D - M O A C /M O D C
C i r cu
Model
Output Range
Supply Voltage
SCMD-MOAC5
SCMD-MOAC5A
SCMD-MOAC5B
SCMD-MOAC24
SCMD-MOAC24A
SCMD-MODC5
SCMD-MODC5A
SCMD-MODC5ML
SCMD-MODC24
12 to 140VAC
24 to 280VAC
24 to 280VAC
12 to 140VAC
24 to 280VAC
3.0 to 60VDC
5.0 to 200VDC
0 to 50VDC
3.0 to 60VDC
5V
5V
5V
24V
24V
5V
5V
5V
24V
it D ia g r a m s
1 9 8
©1995-2017 Dataforth Corporation, All Rights Reserved
For information call 800-444-7644
ISO9001:2008-Registered QMS
很抱歉,暂时无法提供与“SCMD-MOAC5A”相匹配的价格&库存,您可以联系我们找货
