SensorLex® 8BIsolated
IsolatedAnalog
AnalogSignal
SignalConditioning
ConditioningProducts
Products
S C 8MB 5 B
8B35
Linearized 4-Wire RTD Input Modules
Description
8B modules are an optimal solution for monitoring real-world process
signals and providing high-level signals to a data acquisition system.
ach B input module isolates, filters, amplifies, and lineari es a
single channel of temperature input from an RTD and provides an analog
voltage output (Figure 1).
Features
Interfaces to
Platinum RTDs
• True 4-Wire Input
• Linearizes RTD Signal
RTD excitation is provided from the module using a precision current
source. xcitation current does not ow in the input signal leads, which
allows RTD measurements to be made independently of lead resistance.
The excitation currents are small (0.25mA) which minimizes self-heating
of the RTD.
• High-Level Voltage Outputs
• 1500Vrms Isolation
• ANSI/IEEE C37.90.1 Transient Protection
• Input Protection to 240VAC Continuous
Signal filtering is accomplished with a pole filter optimi ed for time and
frequency response which provides 70dB of normal-mode rejection at
H . One pole of this filter is on the field side of the isolation barrier for
anti-aliasing, and the other two are on the system side.
• 120dB CMR
• 70dB NMR at 60Hz
Low Drift with Ambient Temperature
A special input circuit on the 8B35 module provides protection against
accidental connection of power-line voltages up to 240VAC. Clamp
circuits on the I/O and power terminals protect against harmful transients.
• C-UL-US Listed
The modules are designed for installation in Class I, Division 2 hazardous
locations and have a high level of immunity to environmental noise.
• ATEX Compliance Pending
• CE Compliant
• Mix and Match Module Types on Backpanel
Isolation Barrier
–EXC
LPF
1
CJCn
Jn (1)
+EXC
Iso-Chopper™
Amplifier
Pat. Pending
3
Surge
Suppression
and
Protection
+V
RTD
–V´
(1) CJC Enable Jumper.
Remove for 8B35.
5
Isolated
Field-Side
Power
D ia g r a m
1 1 2
©1995-2017 Dataforth Corporation, All Rights Reserved
–V
–V´
+V´
F i g u r e 1 : 8 B 3 5 B l o ck
COM
Computer-Side
Power
4
Backpanel
Terminal Block
VOUT
7
2
6
Linearizer
LPF
For information call 800-444-7644
ISO9001:2008-Registered QMS
Power
Oscillator
7
+5VDC
COM
8 B
SensorLex® 8B Isolated Analog Signal Conditioning Products
Typical❇ at TA
and
Module
to
8B35
Input Range Limits
Input Resistance
Normal
Power Off
Overload
Input Protection
Continuous(1)
Transient
240VAC
ANSI/IEEE C37.90.1
Sensor Excitation Current
Lead Resistance Effect
CMV, Input to Output
Transient, Input to Output
CMR (50 or 60Hz)
NMR
0.25mA
(2)
1500Vrms max
ANSI/IEEE C37.90.1
120dB
70dB at 60Hz
Accuracy
Stability
Offset
Gain
Noise
Output, 100kHz
Bandwidth, – 3dB
Response Time, 90% Span
Output Range
Output Protection
Transient
Open Input Response
+EXC, – EXC lead
– IN lead
+IN lead
Power Supply Voltage
Power Supply Current
Power Supply Sensitivity
Mechanical Dimensions
(h)(w)(d)
Environmental
Operating Temperature Range
Storage Temperature Range
Relative Humidity
Emissions EN61000-6-4
Radiated, Conducted
Immunity EN61000-6-2
RF
ESD, EFT
Ordering Information
D power
Model
Pt
Input Range
Pt
8B35-01
See Ordering Information
to
F to
F
8B35-02
to
F to
F
8B35-03
to
F to
F
8B35-04
to
F to
F
Accuracy(3)
0V to +5V
0V to +5V
0V to +5V
0V to +5V
RTD Standards
Type
ppm
ppm
Output Range
8 B
Specifications
A
Pt
a Coe ficient
0.00385
DIN
JIS
IEC
DIN 43760
JIS C 1604-1989
IEC 751
rms
3Hz
150ms
Continuous Short to Ground
ANSI/IEEE C37.90.1
Downscale, 1s
Downscale, 40s
Upscale, 40s
+5VDC ± 5%
25mA
± 75ppm/%
1.11” x 1.65” x 0.40”
(28.1mm x 41.9mm x 10.2mm)
to
to
0 to 95% Noncondensing
ISM, Group 1
Class A
ISM, Group 1
Performance A ± 0.5% Span Error
Performance B
NOTES :
ontact factory or your local Dataforth sales office for maximum values.
A between Input terminal and Input,
, or
terminals.
A between Input and
or
terminals.
A between
and
terminals.
refers to the resistance in one lead.
Includes conformity, hysteresis and repeatability.
Installation Notes:
. This uipment is Suitable for se in lass I, Division , Groups A, B, , D,
or Non-Hazardous Locations Only.
ARNING xplosion Ha ard Substitution of Any omponents ay Impair
Suitability for lass I, Division .
3.) WARNING - Explosion Hazard - Do Not Disconnect Equipment Unless
Power Has Been Switched Off or The Area is nown to be Non Ha ardous.
Visit our website www.dataforth.com
1 1 3
很抱歉,暂时无法提供与“8B35-04”相匹配的价格&库存,您可以联系我们找货
