Serial No. : 2017-0838
DATE : 2017/10/03
HONHEVER(HK)LIMITED
CRYSTAL OSCILLATOR
ITEM :
DSB211SDN
TYPE :
38.400MHz
NOMINAL FREQUENCY :
1XXD38400MLC
SPEC No. :
If there is a change in this specifications,
the specification number may be changed.
RECEIPT
DATE
RECEIVED
(signature)
(name)
General Manufacture of Quartz Devices
1389 Shinzaike, Hiraoka-cho, Kakogawa, Hyogo
675-0194 Japan
Phone (81)79-425-3141 Fax (81)79-425-1134
http://www.kds.info/index_en.htm
C.ENG.
ENG.
Serial No.2017-0838
1. Device Name
TCXO
2. Model Name
DSB211SDN
3. Nominal Frequency
38.400 MHz
4. Mass
0.015g max.
5. Absolute Maximum Ratings
1
2
Item
Supply Voltage
Storage Temperature Range
Symbol
VCC
T_STG
Rating
-0.3~+4.6
-55~+125
unit
V
C
6. Recommended Operating Conditions
1
2
3
Item
Supply Voltage
Load Impedance (resistance part)
(parallel capacitance)
Operating Temperature Range
Symbol
VCC
LOAD_R
LOAD_C
T_OPR
min.
+2.75
9
9
-40
typ.
+2.8
10
10
max.
+2.85
11
11
+85
unit
V
kΩ
pF
C
7. Electrical Characteristics
(TA=-40~+85C, LOAD_R//C=10kΩ//10pF, VCC=+2.8V, unless otherwise noted)
Item
1
2
3
4
5
Current Consumption
Output Level
Symmetry
Harmonics
Frequency Stability
1.Tolerance
2.vs Temperature
3.vs Slope
4.vs Supply Voltage
5.vs Load Variation
6.vs Aging
6
Frequency drift rate
7
8
Start Up Time
SSB Phase Noise
Conditions
GND level (DC cut)
After 2 times reflow
Ref. to nominal frequency
TA=-40~+85C
Ref. to frequency (TA=+25C)
TA=-40~+85C
VCC=+2.8V±0.05V
LOAD_R//C=(10kΩ//10pF)±10%
TA=Room ambient
TA=Room ambient
From 0.1s to 0.5s
From 0.5s to 1.5s
From 1.5s onwards
@90% of final Vout level
Relative to f0 level offset 1kHz
Relative to f0 level offset 10kHz
Relative to f0 level offset 100kHz
Relative to f0 level offset 1MHz
min.
0.8
40/60
Limits
typ
50
max.
+2.0
60/40
-10
mA
VP-P
dBc
±2.0
ppm
±0.5
ppm
unit
Notes
1
2,3
±0.1
ppm/C
±0.2
ppm
±0.2
ppm
±1.0 ppm/year
±3.0 ppm/10years
±0.10
ppm/s
±0.015
ppm/s
±0.005
ppm/s
2.0
ms
-135
dBc/Hz
-149
dBc/Hz
-156
dBc/Hz
-156
dBc/Hz
Notes
1. Clipped sine wave (DC-coupled)
2. TA=+25C
3. Please leave after reflow in 2h or more at room ambient.
TITLE
Remark
DSB211SDN TYPE SPECIFICATION
Date
2017/10/03
Spec. No.
Rev.
1XXD38400MLC
DAISHINKU CORP.
Page
1/13
DM-Z0002: Style-010 Ver.1
Serial No.2017-0838
8. Outline, Pin Connections
Outline
Pin Connections
Pin No.
#1
#2
#3
#4
Connection
GND
GND
Output
VCC
Marking
#1 Index
(1) Model code
BN
(2) Frequency
38.4 (MHz, 3digits)
(3) Logo
D
(4) Date code
Year (1digit) +Week (2digits)
701
e.g.2017/1/1
unit: mm
Dimensional Tolerance: ±0.1
(Unless otherwise noted)
INDEX)
9. Measurement Circuit
1000pF
T.P.
mA
Power
Supply
#3
#4
10000pF
TCXO
V
Output
Vcc
GND
#1
GND
LOAD_R
#2
LOAD_C
LOAD_R=10kΩ
LOAD_C=10pF (Include Jig stray capacitance)
TITLE
Remark
Date
2017/10/03
Spec. No.
Rev.
1XXD38400MLC
DAISHINKU CORP.
Page
2/13
Serial No.2017-0838
10. Mechanical Characteristics
All test is performed after 3times reflow (Clause.13) except 10.10 (Resistance to soldering heat)
Item
1
2
3
4
5
Drop
Vibration
Shock
PCB bend
strength
Adherence nature
6
Package strength
7
Gross leak
8
Fine leak
9
Solderability
10
Resistance to
soldering heat
Description
Requirements
Natural drop (On concrete)
Mounting on the set or test fixture.(Total weight 100g)
Height : 150cm
Direction : X,Y,Z, 6directions
Test cycle : 3cycles
Reference specification : EIAJ-ED-4702A Method5
Sweep range : 10~500Hz
Sweep speed : 11min/cycle
Amplitude : 1.5mm (10~55Hz)
2
Acceleration : 200m/s (55~500Hz)
Direction : X,Y,Z, 3directions
Test cycle : 10cycles
Reference specification : IEC 60068-2-6
2
Acceleration : 1000m/s
Duration : 6ms
Test cycle : 3cycles/each directions
Reference specification : IEC 60068-2-27
PWB : t=1.6mm
Pressure speed : 1.0mm/s
Bend width : 1 2 3mm
Duration : 10±1s
Reference specification : IEC 60068-2-21 Ue1
PWB : t=1.6mm
Direction : X,Y, 2directions
Pressure : 10N
Duration : 10±1s
Reference specification : IEC 60068-2-21 Ue3
Pressure : 10N
Duration : 10±1s
Reference specification : IEC 60068-2-77
It is immersed for 3min into +125±5C
Chlorofluorocarbon (CFCs) liquid.
Reference specification : IEC 60068-2-17
It shall be measured by the helium leak detector
after pressurization for 60min by the pressure
5
of (3.92±0.49) x10 Pa in a helium gas atmosphere.
Solder bath temperature : +245±5C
Duration : 3±0.3s
Reference specification : IEC 60068-2-58
1) Solder iron method
Bit size : B(φ3) Bit temperature : +350±10C
Duration : 3+1/-0s /each terminal
It shall be measured after 2h at room temperature,
humidity. Reference specification : IEC 60068-2-20
2) Reflow
In refer to temperature profile shown in clause13.
humidity. Reference specification : IEC 60068-2-58
TITLE
df/f=
很抱歉,暂时无法提供与“1XXD38400MLC”相匹配的价格&库存,您可以联系我们找货
