8BPT
8BPT
    DATAFORTH(Dataforth)
    8B PASS-THROUGH VOUT=VIN, NO ISO
8BPT 数据手册
SensorLex® 8B Isolated Analog Signal Conditioning Products 8B SCMXRAIL1-XX, SCMXRAIL2-XX, SCMXRAIL3-XX DIN Rail Description Three styles of DIN rail are available. Specify length (-xx) in meters when ordering, -01 for 1 meter or -02 for 2 meter. Figure 14: DIN Rail Styles Figure 15: 8BPxx-2, 8BPxx-3 Backpanel DIN Rail Mounting Option 8B-PROTO 8BXCJC Breadboard Kit Cold Junction Compensation Sensor Description Description The 8B-PROTO breadboard kit was designed to allow users to incorporate their own module functions using an 8B format. The kit includes a PC board with pins designed for breadboard circuits, a module case, header and mounting screw. Contact the factory for additional information. Packaged for use in customer designed mounting boards. This part has an initial tolerance of ±0.25% and comes in a standard 1206 resistor format. 8BPT Pass-Through Module Description The 8BPT is a pass-through module used to establish a direct connection between an input signal and the 8B series backplane analog bus. It has unity gain and no isolation. It accepts up to ± 10V input and provides up to ± 10V output. 146 For information call 800-444-7644 ©1995-2011 Dataforth Corporation, All Rights Reserved ISO9001:2008-Registered QMS
很抱歉,暂时无法提供与“8BPT”相匹配的价格&库存,您可以联系我们找货
