LRLI-27-250-R-00-20-A
    ALLIANCESENSORS(联盟传感器)
    Cylinder
    SENSOR LINEAR 254MM CABLE
LRLI-27-250-R-00-20-A 数据手册
For use in: Packaging Machinery Chute/Gate Position Factory Automation Automotive Testing LRL-27 Series Linear Position Sensor for Extended Ranges Long Lasting, Contactless, Inductive Sensors Alliance Sensor Group’s LRL-27 series LVIT (Linear Variable Inductance Transducers) contactless position sensors complement the LR series with extended ranges up to 18 inches (450 mm) in a compact package. These sensors are designed for use in factory automation systems and a wide variety of industrial and commercial applications. Cost effective with high-end performance and excellent stroke-to-length ratios make these sensors ideal choices for many industrial application. LRL-27 sensors are offered in 6 nominal ranges from 8 to 18 inches (200 to 450 mm). Operated from a variety of DC voltages. These sensors offer the end-user a choice of four analog outputs along with ASG’s proprietary SenSet™ field adjustable range scaling feature. LRL-27 sensors are available with an axial cable or connector terminations, or with a radial exiting cable and two swivel rod eye ends for easy installation. Besides the LRL-27 series sensors, ASG also offers the LR-27 series for shorter stroke applications and the smaller size LR-19 series for lighter duty applications. Features:     LVIT Technology™ (Linear Variable Inductance Transducer) Contactless operation Excellent stroke-to-length ratio Proprietary SenSet™ field adjustable range scaling Specifications: Analog I/Os: 0-5 V or 0.5—4.5 V output with 8-30 V input, 35 mA max. 0-10 V output with 12-30 V input, 35 mA max. 4-20 mA (3-wire) output with 18-30 V input, 60 mA max (75 C max). Measuring Ranges: 200 mm to 450 mm (8 to 18 inches) full scale (nominal) Linearity Error:
LRLI-27-250-R-00-20-A 价格&库存
很抱歉,暂时无法提供与“LRLI-27-250-R-00-20-A”相匹配的价格&库存,您可以联系我们找货
