SensorLex® 8BIsolated
IsolatedAnalog
AnalogSignal
SignalConditioning
ConditioningProducts
Products
S C 8MB 5 B
8B39
Current Output Modules
Description
8B modules are an optimal solution for monitoring real-world process
signals and providing high-level signals to a data acquisition system.
Each 8B39 module accepts an input signal from a non-isolated source,
then isolates, filters, and converts the signal to an analog process current
output (Figure 1).
Signal filtering is accomplished with a pole filter optimi ed for time and
frequency response which provides 60dB per decade of normal-mode
re ection above
H . One pole of this filter is on the system side and the
other two are on the isolated field side.
A special output circuit in the 8B39 module provides protection against
accidental connection of power-line voltages up to 40VAC continuous.
Clamp circuits on the I/O and power terminals protect against harmful
transients.
The modules are designed for installation in Class I, Division 2 hazardous
locations and have a high level of immunity to environmental noise.
Features
• Accepts High-Level Voltage or Process Current
Input
• Process Current Output
• 1500Vrms Isolation
• ANSI/IEEE C37.90.1 Transient Protection
• Output Protection to 40VAC Continuous
• 110dB CMR
• 100Hz Signal Bandwidth
• ± 0.05% Accuracy
• ± 0.02% Linearity
Low Drift with Ambient Temperature
• C-UL-US Listed
• CE Compliant
• ATEX Compliance Pending
• Mix and Match Module Types on Backpanel
LPF
Iso-Chopper™
Amplifier
Pat. Pending
LPF
6
Protection
7
–EXC
1
NC
CJCn
Jn (1)
+EXC
COM
4
3
2
+V
–V
Rload
Computer-Side
Power
Backpanel
Terminal Block
5
(1) CJC Enable Jumper.
Remains Installed for 8B39.
F i g u r e 1 : 8 B 3 9 B l o ck
Power
Oscillator
D ia g r a m
1 2 0
©1995-2017 Dataforth Corporation, All Rights Reserved
For information call 800-444-7644
ISO9001:2008-Registered QMS
7
+5VDC
COM
SensorLex® 8B Isolated Analog Signal Conditioning Products
Typical❇ at TA
and
Ordering Information
D power
Module
8B39-01,-02,-03,-04
8B39-07
Input Voltage Range
Input Voltage Maximum
Input Resistance
± 5V or 0V to +5V
± 20V (no damage)
± 5V
0 to 20mA or 4 to 20mA
10%
± 20mA
15VDC
to
26mA
± 12VDC
to
± 26mA
40VAC
ANSI/IEEE C37.90.1
1500Vrms max
ANSI/IEEE C37.90.1
110dB
dB per Decade above
H
Output Current Range
Over Range apability
Output Compliance Voltage
(Open Circuit)
Load Resistance Range
Output I Under Fault, max
Output Protection
Continuous
Transient
CMV, Output to Input
Transient, Output to Input
CMR (50Hz or 60Hz)
NMR (– 3dB at 100Hz)
Accuracy
Linearity
Stability
Offset
Gain
Noise
Output, 100kHz
Bandwidth, – 3dB
Rise Time, 10 to 90% Span
± 0.05% Span
± 0.02% Span
Power Supply Voltage
Power Supply Current
Power Supply Sensitivity
+5VDC ± 5%
100mA
± 100ppm/%
(1)
Mechanical Dimensions
(h)(w)(d)
Environmental
Operating Temperature Range
Storage Temperature Range
Relative Humidity
Emissions EN61000-6-4
Radiated, Conducted
Immunity EN61000-6-2
RF
ESD, EFT
ppm
ppm
Model
8B39-01
8B39-02
8B39-03
8B39-04
8B39-07
Input Range
Output Range
0V to +5V
– 5V to +5V
0V to +5V
– 5V to +5V
– 5V to +5V
4mA to 20mA
4mA to 20mA
0mA to 20mA
0mA to 20mA
– 20mA to +20mA
8 B
Specifications
8 B
ppm
Arms
100Hz
5ms
1.11” x 1.65” x 0.40”
(28.1mm x 41.9mm x 10.2mm)
to
to
0 to 95% Noncondensing
ISM, Group 1
Class A
ISM, Group 1
Performance A ± 0.5% Span Error
Performance B
NOTES:
ontact factory or your local Dataforth sales office for maximum values.
Same specification as , , ,
models.
Includes linearity, hysteresis and repeatability.
Installation Notes:
. This uipment is Suitable for se in lass I, Division , Groups A, B, , D,
or Non-Hazardous Locations Only.
ARNING xplosion Ha ard Substitution of Any omponents ay Impair
Suitability for lass I, Division .
3.) WARNING - Explosion Hazard - Do Not Disconnect Equipment Unless
Power Has Been Switched Off or The Area is nown to be Non Ha ardous.
Visit our website www.dataforth.com
1 2 1
很抱歉,暂时无法提供与“8B39-03”相匹配的价格&库存,您可以联系我们找货
