Isolated Analog Signal Conditioning Products
S C M 5 B
SCM5B33
Isolated True RMS Input Modules
Description
Each SCM5B33 True RMS input module provides a single channel of
A input which is converted to its True R S D value, filtered, isolated,
amplified, and converted to a standard process voltage or current output
(Figure 1).
Features
The SCM5B modules are designed with a completely isolated computer
side circuit which can be oated to
from Power ommon, pin .
This complete isolation means that no connection is re uired between I O
Common and Power Common for proper operation of the output switch.
If desired, the output switch can be turned on continuously by simply
connecting pin , the Read nable pin, to I O ommon, pin .
• Designed for Standard Operation with Frequecies
of 45Hz to 1000Hz (Extended Range to 20kHz)
The field voltage or current input signal is processed through a
pre amplifier and R S converter on the field side of the isolation
barrier. The converted D signal is then chopped by a proprietary chopper
circuit and transferred across the transformer isolation barrier,
suppressing transmission of common mode spikes and surges. The
computer side circuitry reconstructs, filters and converts the signal to
industry standard outputs. Modules are powered from +5VDC, ± 5%.
For current output models, in addition to the 5VDC module power, an
external loop supply of 4.2V to 26V is required. The loop supply
connection, with series load, is between pin
and pin
Due to circuit limitations, SCM5B33-04x and -05x are not ATEX compliant.
WARNING: The SCM5B33 interfaces to
ompatible with Standard urrent and Potential
Transformers
• Industry Standard Output of Either 0-1mA,
0-20mA, 4-20mA, 0-5V or 0-10VDC
Factory alibrated Accuracy
(Accuracy Class 0.2)
• 1500Vrms Continuous Transformer Isolation
• Input Overload Protected to 480V Max
(Peak AC & DC) or 10A RMS Continuous
• ANSI/IEEE C37.90.1 Transient Protection
SA
S ertified
• CE Compliant
• ATEX Compliant (all models except
SCM5B33-04x, -05x)
• Mix and Match SCM5B Types on Backpanel
ha ardous voltages and should only be wired by
ualified personnel or licensed electricians.
F i g u r e 1 : S C M 5 B 3 3 B l o ck
• Interfaces RMS Voltage (0 – 300V) or RMS
Current (0 – 5A)
D ia g r a m
1 0
©1995-2017 Dataforth Corporation, All Rights Reserved
For information call 800-444-7644
ISO9001:2008-Registered QMS
Specifications
Typical❇ at TA
and
SCM5B33
Input
Signal Range
Standard Frequency Range
Extended Frequency Range
Impedance
100mV to 300Vrms, 0 to 5Arms
45Hz to 1000Hz
1kHz to 20kHz
shunted by
pF
thru
AC
Coupling
Protection(1)
Continuous (-01 thru -05)
Continuous (-06 thru -07)
Transient (-01 thru -05)
Transient (-06 thru -07)
Output
Signal Range
Current Limit
Voltage Limit
Resistance
Protection
Ripple and Noise (100kHz)
Ordering Information
D power
Module
0-5V or 0-10V or 0-1mA or 0-20mA or 4-20mA
1.4mA (0-1mA models), 30mA (0/4-20mA models),
8mA (0-5, 0-10V models)
± 18V (0-5, 0-10V models)
models
Continuous Short to Ground
0.025% Span rms
± 0.25% Span
± 0.25% Reading Additional Error
± 0.75% Reading Additional Error
± 0.05%
± 0.15%
± 0.30%
± 0.40%
Isolation (Common Mode)
Input to Output, Input to Power
Continuous
Transient
Output to Power
Continuous
ppm
1500Vrms max
ANSI/IEEE C37.90.1
50VDC max
Rejection (50-60Hz Common Mode)
100dB
Response Time (0 to 99%)
很抱歉,暂时无法提供与“SCM5B33-02B”相匹配的价格&库存,您可以联系我们找货
