TAI-TECH
P1
SMD Power Choke Coil
TMPC0502HP-Series(MG)-D
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
14/10/15
新 發 行
楊祥忠
詹偉特
林宜蕰
備
註
TAI-TECH
P2
1. Features
1. Carbonyl powder inductor.
2. Compact design.
Halogen
Pb
Halogen-free
Pb-free
3. High current,low DCR,high efficiency.
4. Very low acoustic noise and very low leakage flux noise.
5. High reliability.
6. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
2. Applications
Note PC power system,incl. IMVP-6
Recommend PC Board Pattern
DC/DC converter.
3. Dimensions
L
Dr. MOS application
C
D
H
A
E
B
2R2
1R0
1151
1150
G
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
L(mm)
G(mm)
H(mm)
TMPC0502HP
5.7±0.3
5.2±0.2
1.8±0.2
1.1±0.3
2.5±0.3
6.2
2.2
2.8
4. Part Numbering
TMPC
0502
HP
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F: D/C
2R2
D
MG E
D
F
BxC
H: Carbonyl powder, P: PAD broaden
2R2=2.2uH
M=±20%
印字:黑色, 2R2 及 D/C 1150 (D/C 前二碼是年份,後二碼是週期,依實際生產週期而定)
5. Specification
Part Number
Inductance
L0 (uH) @ 0 A
I rms
(A) typ.
I sat
(A) typ.
DCR
DCR
(mΩ) typ. @25℃ (mΩ) max. @25℃
TMPC0502HP-R33MG-D
0.33±20%
12
21.3
6.3
TMPC0502HP-R47MG-D
0.47±20%
11.5
18
7.3
8.6
TMPC0502HP-R68MG-D
0.68±20%
10
12.8
11
12.4
TMPC0502HP-1R0MG-D
1.00±20%
7.0
13.7
17.5
TMPC0502HP-1R2MG-D
1.20±20%
6.2
11.0
23
28
TMPC0502HP-1R5MG-D
1.50±20%
5.5
9.8
26.5
30.5
TMPC0502HP-2R2MG-D
2.20±20%
4.2
9.0
42.0
50.0
TMPC0502HP-3R3MG-D
3.30±20%
3.3
7.3
66.0
76
TMPC0502HP-4R7MG-D
4.70±20%
2.8
5.0
103
116
TMPC0502HP-5R6MG-D
5.60±20%
2.5
4.0
112
122
TMPC0502HP-6R8MG-D
6.80±20%
2.4
3.8
130
150
TMPC0502HP-8R2MG-D
8.2±20%
2.3
3.5
148
171
TMPC0502HP-100MG-D
10±20%
2.3
3.4
180
199
7.3
Note:
1. Test frequency : L : 100KHz /1.0V
2. All test data referenced to 25℃ ambient.
3. Testing Instrument : L/Q: HP4284A,CH11025,CH3302,CH1320 ,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately Δt≦40℃ (keep 1min.).
5. Saturation Current (Isat) will cause L0
to drop ≦ 20% typical. (keep quickly).
6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Special inquiries besides the above common used types can be met on your requirement.
TAI-TECH
P3
6. Material List
NO
Items
Materials
1
Core
Carbonyl powder or equ.
2
Wire
Polyester Wire or equivalent.
3
Solder Plating
100% Pb free solder
7. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Inductance
Refer to standard electrical characteristics list.
DCR
HP4284A,CH11025,CH3302,CH1320,CH1320S
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
△L≦20% typical.
Saturation DC Current (Isat) will cause L0
to drop △L(%)(keep quickly).
Approximately △T≦40℃
△T(℃) without core loss.
1.Applied the allowed DC current(keep 1 min.).
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through IR reflow for 2
times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature:125±2℃(Bead)
Life Test
Temperature: 85±2℃(Inductor)
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
times.( IPC/JEDEC
Humidity:85±2﹪ R.H,
Load Humidity
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Appearance:No damage.
Thermal
shock
Inductance:within±10% of initial value
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not
times.( IPC/JEDEC J-STD-020DClassification
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Step2:25±2℃ ≦0.5min
Step3:105±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Vibration
Shock
Bending
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
Peak
Normal
Velocity
Wave
orientations)。
Type
value
duration (D)
change
form
(g’s)
(ms)
(Vi)ft/sec
SMD
1500
0.5
Half-sine
15.4
Lead
100
6
Half-sine
12.3
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805:40x100x1.2mm
=0805:1.2mm
0805:1kg ,
很抱歉,暂时无法提供与“TMPC0502HP-R22MG-D”相匹配的价格&库存,您可以联系我们找货
