SPAU-P10R-T-R18M-L-PNLK-PNVBA-M12D
    FESTO(Festo)
    Module Box with Display
    PRESSURE SENSOR
SPAU-P10R-T-R18M-L-PNLK-PNVBA-M12D 数据手册
Pressure sensor SPAU-P10R-T-R18M-L-PNLK-PNVBA-M12D Part number: 8001206 Data sheet Feature Value Symbol 00995410 Certification RCM compliance mark c UL us - Listed (OL) CE marking (see declaration of conformity) As per EU EMC directive As per EU RoHS directive UKCA marking (see declaration of conformity) To UK instructions for EMC To UK RoHS instructions KC characters KC EMC Note on materials RoHS-compliant Measured variable Relative pressure Method of measurement Piezoresistive pressure sensor Pressure measuring range initial value 0 bar Pressure measuring range end value 10 bar Max. overload pressure 15 bar Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Inert gas Information on operating and pilot media Operation with oil lubrication possible Temperature of medium 0 °C ... 50 °C Ambient temperature 0 °C ... 50 °C ADC resolution 12 bit Accuracy in ± % FS 1.5 %FS Repetition accuracy in ± %FS 0.3 %FS Temperature co-efficient in ± %FS/K 0.05 %FS/K Switching output 2 x PNP or 2 x NPN switchable Switching function Freely programmable Switching element function N/C contact/N/O contact switchable Max. output current 100 mA Analog output 0 - 10 V 4 - 20 mA 1-5V Rise time 3 ms Max. load resistance of current output 500 Ohm Min. load resistance of voltage output 10 kOhm Short-circuit protection yes Protocol IO-Link® IO-Link®, protocol version Device V 1.1 IO-Link®, profile Smart sensor profile 10/20/22 - Subject to change - Festo SE & Co. KG 1/2 Feature Value IO-Link®, function classes Binary data channel (BDC) Process data variable (PDV) Identification Diagnostics Teach channel IO-Link®, communication mode COM2 (38,4 kBd) IO-Link®, SIO mode support Yes IO-Link®, port class A IO-Link®, process data width OUT 0 Byte IO-Link®, process data width IN 2 Byte IO-Link®, process data content IN 14 bit PDV (pressure measurement) 2 bit BDC (pressure monitoring) IO-Link®, minimum cycle time 3 ms IO-Link®, data memory required 500 byte DC operating voltage range 20 V ... 30 V Reverse polarity protection for all electrical connections Electrical connection 1, connection type Plug Electrical connection 1, connection technology M12x1 A-coded as per EN 61076-2-101 Electrical connection 1, number of pins/wires 4 Electrical connection for input 1, connection pattern 00995386 Type of mounting With thread Mounting position Any Pneumatic connection R1/8 Product weight 80 g Display type Illuminated LCD Displayable unit(s) MPa bar inH2O inHg kPa kgf/cm² mmHg psi Setting options IO-Link® Teach-in Via display and pushbuttons Protection against tampering IO-Link® PIN code Setting range threshold value 0 % ... 100 % Setting range hysteresis 0 % ... 90 % Degree of protection IP65 IP67 Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L 10/20/22 - Subject to change - Festo SE & Co. KG 2/2
SPAU-P10R-T-R18M-L-PNLK-PNVBA-M12D 价格&库存
很抱歉,暂时无法提供与“SPAU-P10R-T-R18M-L-PNLK-PNVBA-M12D”相匹配的价格&库存,您可以联系我们找货
