LVI-45-375-R-01-20-S
    ALLIANCESENSORS(联盟传感器)
    Cylinder
    SENSOR LINEAR 381MM CONNECTOR
LVI-45-375-R-01-20-S 数据手册
LV-45 Series For use in: Steel, Aluminum, and Paper Mills Power Generation Steam Valves Material Creep Measurements Roadway/Bridge Expansion Hydro Power Plants LVIT Linear Position Sensor Designed Specifically for Heavy Duty Industrial and Civil Engineering Applications Alliance Sensors Group's LV-45 series LVIT (Linear Variable Inductance Transducer) position sensors are specifically targeted for measuring applications requiring rugged devices, whether measuring position of steam turbine valves, mounted in a paper mill head box or calendar roll stand, or operating outdoors fastened to a bridge or structure. LV-45 sensors use a contactless inductive technology that allows them to replace other technology sensors like potentiometers and DC-LVDTs in most applications. With a simple coil design, a captive connecting rod, and a thick-walled housing, the sensors are both shorter and more robust than their DC-LVDT counterparts while operating over a wider temperature range. They can withstand the vibration and shock levels found in mills and power plants, as well as the temperature and humidity found in outdoor applications. Once a sensor has been installed, ASG’s SenSet™ range adjustment process permits a user to match the sensor’s zero and full scale output to the workpiece’s actual range of motion. Features:     LVIT Technology™ (Linear Variable Inductance Transducer) Contactless operation Excellent stroke-to-length ratio Proprietary SenSet™ field adjustable range scaling Specifications: Analog I/Os: 0-5 V or 0.5-4.5 V output with 8-30 V input, 35 mA max. 0-10 V output with 12 -30 V input, 35 mA max. 4-20 mA (3-wire) output with 18-30 V input, 60 mA max. (75 C max). Measuring Ranges: 100 mm to 450 mm (4 to 18 inches) full scale (nominal) Linearity Error:
LVI-45-375-R-01-20-S 价格&库存
很抱歉,暂时无法提供与“LVI-45-375-R-01-20-S”相匹配的价格&库存,您可以联系我们找货
