EPIC®
UNCONTROLLED COPY
POWER LS1
Circular connectors
EPIC® POWER LS1
Rugged nickel-plated zinc connectors for power applications
Approvals
Application advantage
• Rugged nickel-plated, die-cast zinc body
ositive vibration protection for use with motor drives and moving
•P
assemblies
• Integral EMC cable gland provides strain-relief, IP67/68 protection, and
360° shielding
EPIC® POWER LS1 connectors are available in seven housing styles and two contact configurations. Common to all arrangements are a rugged
nickel-plated zinc body, plastic contact insulation body and sleeve, and gold-plated electrical contacts (included with the connector part number).
Cable-mounted arrangements also include an integral EMC shield ring, cable clamp, and seal. The figure above shows the general construction of
these connectors.
These connectors are offered with two contact configurations. The 5+PE contact configuration for power distribution has 5 contacts plus ground,
and is rated at 630V and 25A. For feedback and servo motor with brake applications, the 3+PE+4 contact configuration handles mixed power and
signal requirements with 3 contacts plus ground, rated 630V and 26A, and 4 contacts rated 250V and 7A. When used in combination, they connect
one flexible cable with another (cable coupler) or one flexible cable to fixed wiring on a machine (appliance coupler).
Technical data
Number of contacts: 5+PE, 3+PE+4
Temperature range: -25°C to +125°C
Rated voltage:
- UL: 600V
- VDE:
- 2 mm contacts: 630V
- 1 mm contacts: 250V
Wire gauge (crimp termination):
- 2 mm contacts:
- styles A1, A3, G5: 20 - 14 AWG (0.5 - 2.5 mm²)
- styles D, F: 20 - 12 AWG (0.5 - 4.0 mm²)
- 1 mm contacts: 26 - 18 AWG (0.14 - 1.0 mm²)
Cable diameter: 7.5 - 15.5 mm
- styles D & F: 14 - 17 mm
Mating cycles: 500
Rated current:
- 2 mm contacts: 25A (5+PE)
26A (3+PE+4)
- 1 mm contacts: 7A
Impulse voltage:
- 2 mm contacts: 6kV
- 1 mm contacts: 4kV
Protection class: IP68 (10h/1m)
- style A3: IP65
Material:
- housing:
- insulation body:
- contacts:
- gaskets & seals:
Contact resistance:
nickel-plated die-cast zinc
PA, PBT, V-0 per UL 94
gold-plated copper alloy
FPM
< 4 mΩ
Approvals: DIN EN 61984
cRUus #E75770
for current information see: www.lappusa.com • www.lappcanada.com
441
EPIC®
UNCONTROLLED COPY
Circular connectors
POWER LS1
EPIC® POWER LS1
5+PE
3+PE+4
view from contact side
male insert
female insert
male insert
female insert
Contact size
AWG
mm2
2 mm contacts
0.34
22
0.50
18
1.50
16
2.50
14
4.00
12
1 mm contacts
up to 0.14
up to 26
1.00
18
Max. current according to UL
5+PE
3+PE+4
5A
9A
13A (11A*)
12A
22A
25A
5A
9A
13A (11A*)
12A
22A
26A
1A
7A
EPIC® POWER LS1 style A1
Straight panel mount inlet with male contacts
5+PE
3+PE+4
all dimensions are in mm
Contact
configuration
Part number
5+PE
3+PE+4
76003000
76004000
Contact tools
Crimp tool:
11148000
Locator:
11148300
Removal tool:
1 mm contacts:75017400
2 mm contacts:75017500
If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question.
442
EPIC®
UNCONTROLLED COPY
POWER LS1
Circular connectors
EPIC® POWER LS1 style A3
Angled rotatable panel mount inlet with male contacts
5+PE
3+PE+4
Contact
configuration
Part number
5+PE
3+PE+4
24420058
24420056
Contact tools
Crimp tool:
11148000
Removal tool:
Locator:
11148300
EPIC® POWER LS1 style A6
Panel mount receptacle with female contacts
5+PE
3+PE+4
Contact
configuration
Part number
5+PE
3+PE+4
76083000
76084000
Contact tools
Crimp tool:
11148000
Locator:
11148300
EPIC® POWER LS1 style D6
Cable connector with female contacts
standard body
Contact tools
short body
Contacts
page 445
Crimp tool:
11148000
Locator:
11148300
Part
number
Contact
configuration
Wire size
Clamping
range
mm
Contacts
included
Standard body
76123000
76124000
44420091
44420089
5+PE
3+PE+4
5+PE
3+PE+4
20 - 14 AWG
20 - 14 AWG
12 AWG
12 AWG
7.5 - 15.5
7.5 - 15.5
14 - 17
14 - 17
yes
yes
yes
yes
Part
number
44420090
44420088
Short body
76123100
76124100
Contact
configuration
Wire size
Clamping
range
mm
Contacts
included
5+PE
3+PE+4
20 - 14 AWG
20 - 14 AWG
14 - 17
14 - 17
no
no
5+PE
3+PE+4
20 - 14 AWG
20 - 14 AWG
7.5 - 15.5
7.5 - 15.5
yes
yes
443
EPIC®
UNCONTROLLED COPY
Circular connectors
POWER LS1
EPIC® POWER LS1 style F6
Cable coupler with male contacts
5+PE
Contact tools
3+PE+4
Contacts
page 445
Crimp tool:
11148000
Locator:
11148300
Part
number
Contact
configuration
Wire size
Clamping
range
mm
Contacts
included
Part
number
Contact
configuration
Wire size
Clamping
range
mm
Contacts
included
76133000
76134000
44420094
5+PE
3+PE+4
5+PE
20 - 14 AWG
20 - 14 AWG
20 - 14 AWG
7.5 - 15.5
7.5 - 15.5
14 - 17
yes
yes
no
44420092
44420095
44420093
3+PE+4
5+PE
3+PE+4
20 - 14 AWG
12 AWG
12 AWG
14 - 17
14 - 17
14 - 17
no
yes
yes
EPIC® POWER LS1 style F7
3+PE+4
5+PE
Contact
configuration
Part number
Clamping
range
mm
5+PE
3+PE+4
76143000
76144000
7.5 - 15.5
7.5 - 15.5
Contact tools
Crimp tool:
11148000
Locator:
11148300
EPIC® POWER LS1 style G5
Straight panel mount inlet with male contacts & locknut
5+PE
3+PE+4
Contact
configuration
Part number
5+PE
3+PE+4
76153000
76154000
Contact tools
Crimp tool:
11148000
Locator:
11148300
Removal tool:
444
EPIC®
UNCONTROLLED COPY
POWER LS1
Circular connectors
EPIC® POWER LS1 accessories
metal screw cap
plastic protection cap
SILVYN® adapter
Connector style
Part number
Connector style
Part number
Size
Part number
A1, A3, F6, F7, G5
75018310
A6, D6
A1, F6, F7, G5
75007710
75007810
M25 x 1.5
55001310
Adapter allows connection to jacketed
cable run in SILVYN® conduit.
EPIC® POWER LS1 tools
crimp tool
locator
Part number
Part number
Contact size
Part number
11148000
11148300
1 mm
2 mm
75017400
75017500
removal tool
Replacement contacts
style A1, A3 & G5
style F6 & F7
style D6 & A6
Part number
1 mm contacts
74033001
74033000
74034001
74034000
74034501
74034500
2 mm contacts
74033101
74033100
74034101
74034100
44429371
44429370
44420103
44420104
44420105
mm2
Wire size
AWG
Contact
type
Connector
style
Strip length
mm
Pack
size
0.14 - 1.0
0.14 - 1.0
0.14 - 1.0
0.14 - 1.0
0.14 - 1.0
0.14 - 1.0
26 - 18
26 - 18
26 - 18
26 - 18
26 - 18
26 - 18
male
male
male
male
female*
female*
A1, A3, G5
A1, A3, G5
F6, F7
F6, F7
D6, A6
D6, A6
8
8
6
6
6.5
6.5
10
100
10
100
10
100
0.50 - 2.5
0.50 - 2.5
0.50 - 2.5
0.50 - 2.5
0.50 - 2.5
0.50 - 2.5
4.0
4.0
4.0
20 - 14
20 - 14
20 - 14
20 - 14
20 - 14
20 - 14
12
12
12
male
male
male
male
female*
female*
male
female*
female*
A1, A3, G5
A1, A3, G5
F6, F7
F6, F7
D6, A6
D6, A6
F6, F7
D6
D6
7
7
8
8
8
8
8
8
8
10
100
10
100
10
100
100
10
100
* Hyper boloid
445
