KDS U-M124WM124A-T2104-020 数据手册
Part no.: 50140498 – KDS U-M124W-M124A-T2104-020 – Interconnection cable
Technical data
Connection
Connection 1
Type of connection
Connector
Thread size
M12
Type
Female
No. of pins
4 -pin
Encoding
A-coded
Design
Angled
Connection 2
Type of connection
Connector
Thread size
M12
Type
Male
Handle body material
TPU
No. of pins
4 -pin
Encoding
A-coded
Design
Axial
Lock
Screw fitting, nickel-plated brass, recommended torque 0.5 Nm,
self-locking
Cable properties
Number of conductors
4 Piece(s)
Wire cross section
0.82 mm²
AWG
18
Sheathing color
Yellow
Shielded
No
Silicone-free
Yes
Cable design
Cable length
2,000 mm
Sheathing material
TPE
Wire insulation
PVC
Suitability for drag chains
Yes
Mechanical data
Width across flats
14.5 mm
Bending cycles
1,000,000 Piece(s)
Environmental data
Ambient temperature, operation, flexible use
-15 ... 90 °C
Ambient temperature, operation, stationary use
-35 ... 105 °C
Certifications
Degree of protection
IP 67
IP 65
NEMA 6P
Classification
eCl@ss 8.0
27279218
eCl@ss 9.0
27060311
ETIM 5.0
EC001855
Leuze electronic GmbH + Co. KG, In der Braike 1, 73277 Owen
Phone: +49 7021 573-0, Fax +49 7021 573-199
info@leuze.com • www.leuze.com
We reserve the right to make technical changes • eng 2018-08-14
2/3
Electrical connection
Connection 1
Type of connection
Connector
Thread size
M12
Type
Female
No. of pins
4 -pin
Encoding
A-coded
Design
Angled
Connection 2
Type of connection
Connector
Thread size
M12
Type
Male
TPU
No. of pins
4 -pin
Encoding
A-coded
Design
Axial
Lock
Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking
3/3
KDS U-M124WM124A-T2104-020 价格&库存
很抱歉,暂时无法提供与“KDS U-M124WM124A-T2104-020”相匹配的价格&库存,您可以联系我们找货
