KMEB-1-24-2,5-LED
KMEB-1-24-2,5-LED
    FESTO(Festo)
    PLUG SOCKET WITH CABLE
KMEB-1-24-2,5-LED 数据手册
Plug socket with cable KMEB-1-24-2.5-LED Part number: 151688 Data sheet Feature Value Signal status display LED yellow Mounting position Any Product weight 125 g Electrical connection 1 Socket, as per EN 175301-803, form C Electrical connection 1, design Rectangular Electrical connection 1, connection type Socket Electrical connection 1, cable outlet Angled Electrical connection 1, information on cable outlet 90° Electrical connection 1, number of pins/wires 3 Electrical connection 1, type of mounting On air solenoid valve with M2.5 central screw Electrical connection 2, connection technology Open end Electrical connection 2, number of pins/wires 3 Nominal operating voltage DC 24 V Surge resistance 0.8 kV Protective earth connection Available Cable length 2.5 m Cable characteristic Standard Cable diameter 5.2 mm Cable design 3 x 0.5 mm² Wire ends Cable end sleeve Degree of protection IP65 as per IEC 60529 Ambient temperature -20 °C ... 80 °C CE marking (see declaration of conformity) As per EU RoHS directive UKCA marking (see declaration of conformity) To UK RoHS instructions LABS (PWIS) conformity VDMA24364-B2-L Contamination level 3 Corrosion resistance class (CRC) 1 - Low corrosion stress Material of cable sheath PVC Housing material PA66-GF30 Seals material NBR Material of pin contacts Copper alloy, silver-plated 10/21/22 - Subject to change - Festo SE & Co. KG 1/1
KMEB-1-24-2,5-LED 价格&库存
很抱歉,暂时无法提供与“KMEB-1-24-2,5-LED”相匹配的价格&库存,您可以联系我们找货
