电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
MTX001-48-C
MTX001-48-C
    MITEX
    VFQFN48
    JPEG IMAGE COMPRESSING IC
MTX001-48-C 数据手册
MTX MTX series MJPEG compression processor Rev 2 Data Sheet 02/16/21 www.mitex.us 1 MTX Table of Contents 1 Overview ........................................................................................................... 3 2 Key specifications ........................................................................................... 3 3 Targeted application ..................................................................................... 4 4 System level description ............................................................................... 5 4.1 4.2 4.3 4.4 4.5 4.6 02/16/21 Architecture Overview .............................................................................. 5 Pin Configuration and Functions ............................................................ 6 Image Sensor interface Timing ............................................................... 9 MJPEG data interface Timing ................................................................ 10 Frame Dimension .................................................................................... 11 Ratings ..................................................................................................... 12 5 Package Specifications ................................................................................ 13 6 Ordering information .................................................................................. 14 7 Revision history............................................................................................. 15 8 Disclaimer ....................................................................................................... 15 www.mitex.us 2 MTX 1 Overview The MTX is an Image Compression Processor series that performs the JPEG Baseline Algorithm. The MTX performs Discrete Cosine Transform, Quantization, and Entropy Encoding. It does not use any external memory and is designed to operate without any host intervention. The MTX series has different options. Its base option is MTX001. It includes a Lattice Semiconductor FPGA ICE40UP5K, packaged in a 30-ball WLCSP and in a 48pin VFQFN Exposed Pad, preconfigured with the MJPEG encoder IP. Figure 1. a) MTX001-48; b) MTX001-30 2 Key specifications  Image Sensor interface - Pixel input data 8 bits YUV 4:2:2 - Pixel clock 25MHz max - ITU-R compliant parallel digital video interface timing  Host interface paralleled to data interface - 8 bits JPEG compressed data - 1-bit data enabled pulse. Data enabled pulse duration equals to period of Pixel clock     02/16/21 Selectable 4 compression rates Standard Huffman Tables No external memory No programming required www.mitex.us 3 MTX Latency 8 times of Frame length Image resolution 4K, 2K, VGA Image Sensor OV7690 CameraCube default configuration Package  7.0mm x 7.0mm 48-pin VQFN  2.5mm x 2.1mm 30-Ball WLSC  Customization availability     3 Targeted application The MTX001 is designed for products that record video. Some examples are:  Small action cameras  Wireless doorbells  Surveillance cameras  Tracking device with camera capability  Smart wallets with camera 02/16/21 www.mitex.us 4 MTX  Drone cameras 4 System level description 4.1 Architecture Overview The MTX001 performs JPEG Baseline compression for both Still Image and Real Time Video streams. Figure 2 shows the simplified block diagram of this device. Figure 2. MJPEG encoder simplified block diagram 02/16/21 www.mitex.us 5 MTX 4.2 Pin Configuration and Functions Figure 3. MTX001-48-x pinouts Table 1 lists the pin descriptions and their corresponding pin numbers for the MTX001-48 base version. 02/16/21 www.mitex.us 6 MTX Table 1. Pin descriptions Pin# Name Description Direction 36 RST_SYSn System Reset. Active Low. Pulled-up 10k internally 27 ALIVE “Heart Beat” pulses 48 SCL 45 SDA 28 QLEV-1 31 QLEV-0 37 CLK_PXL Pixel Clock from Image Sensor in 43 HREF Horizontal reference from Image Sensor in 44 VSYNC Vertical sync from Image Sensor in 42 YCbYCr-0 YCbYCr Pixel data bit 0 from Image Sensor in 47 YCbYCr-1 YCbYCr Pixel data bit 1 from Image Sensor in 41 YCbYCr-2 YCbYCr Pixel data bit 2 from Image Sensor in 40 YCbYCr-3 YCbYCr Pixel data bit 3 from Image Sensor in 34 YCbYCr-4 YCbYCr Pixel data bit 4 from Image Sensor in 25 YCbYCr-5 YCbYCr Pixel data bit 5 from Image Sensor in 39 YCbYCr-6 YCbYCr Pixel data bit 6 from Image Sensor in 38 YCbYCr-7 YCbYCr Pixel data bit 7 from Image Sensor in 6 MD_GATE MJPEG data Gate out 9 MD_ENB MJPEG data enable signal out 12 MD-0 MJPEG data bit 0 out 2 MD-1 MJPEG data bit 1 out 13 MD-2 MJPEG data bit 2 out 3 MD-3 MJPEG data bit 3 out 32 MD-4 MJPEG data bit 4 out 4 MD-5 MJPEG data bit 5 out 11 MD-6 MJPEG data bit 6 out 10 MD-7 MJPEG data bit 7 out 49 EP_GND Exposed Pad for grounding - 5 VCC Power supply, Core, 1.2V - 30 VCC Power supply, Core, 1.2V - 33 VCCIO0 Power supply, I/0 bank 0, 3.3V - 22 VCCIO1 Power supply, I/0 bank 1, 3.3V - 1 VCCIO2 Power supply, I/0 bank 2, 3.3V - 02/16/21 SCCB clock to Image Sensor. 4.7k pull-up to 3.3V required SCCB data to/from Image Sensor. 4.7k pull-up to 3.3V required Quant level selecting bit 1. Pulled-up 10k internally Quant level selecting bit 0. Pulled-up 10k internally www.mitex.us out out inout in in 7 MTX 29 VCC_PLL Power supply, PLL, 1.2V - 24 VCC_PP Power supply, Configuration Memory, 2.5V - 7 NC Not Connected - 8 NC Not Connected - 14 NC Not Connected - 15 NC Not Connected - 16 NC Not Connected - 17 NC Not Connected - 18 NC Not Connected - 19 NC Not Connected - 20 NC Not Connected - 21 NC Not Connected - 23 NC Not Connected - 26 NC Not Connected - 35 NC Not Connected - 46 NC Not Connected - The four levels of quant levels selecting by the input signals applying to pins QLEV-1 and QLEV-0 "11" - Level 0 "10" - Level 1 "01" - Level 2 "00" - Level 3 During the initial powering up or after system reset, the Image Sensor OV7690 CameraCube is configuring through SCCB interface (SCL and SDA pins). OV7690 default configuration stored in MTX001-48-x. Afer configuration finished, the “Heart Beat” pulces generated from the pin ALIVE. MTX001-48-x is ready to receive the the frame from the image sensor, JPEG compressing image frames, and sending compressed data to out. Other than OV7690, a different image sensors could be connected to MTX001-48x. However in this case the image sensor should be configured from the external I2C interface. 02/16/21 www.mitex.us 8 MTX 4.3 Image Sensor interface Timing Image sensor interface timing diagram shown in Figure 3. Figure 4. Image Sensor interface timing diagram Table 2 lists the image sensor interface timing parameters and descriptions for the MTX001. 02/16/21 www.mitex.us 9 MTX Table 2. Image Sensor interface timing parameters Min Max Unit Pixel Clock frequency 10 25 MHz Pixel Clock period 40 100 nsec Data Setup time 7.7 nsec Data Hold time 1.1 nsec Symbol fpclk tpclk tsu thd tphl tpdv tline tvh tvs Description Pixel Clock [↓] to Horizontal Reference [↓] 0 5 nsec Pixel Clock [↓] to Data-out Valid 0 5 nsec Video frame width - - nsec Vertical Sync [↓] to Horizontal Reference [↑] 8 × tline - nsec Vertical Sync width 2 × tpclk - nsec 4.4 MJPEG data interface Timing MJPEG data interface timing diagram is shown in Figure 4. Figure 4. MJPEG data interface timing diagram Table 3 lists the MJPEG data interface timing parameters and descriptions for the MTX001. 02/16/21 www.mitex.us 10 MTX Table 3. MJPEG data interface timing parameters Symbol Description Duration tmsu MJPEG Data Setup time Tpixel_clock / 2 tmsu.start Last MJPEG Data Setup time 5 * Tpixel_clock / 2 tmhd MJPEG Data Hold time 3 * Tpixel_clock / 2 tmhd.last Last MJPEG Data Hold time Tpixel_clock tmde MJPEG Data Enable width Tpixel_clock / 2 tmbde Interval between consecutive MJPEG Data Enables, min 3 * T pixel_clock / 2 4.5 Frame Dimension Frame image dimensions shown in Figure 5. Figure 5. Frame image dimensions 02/16/21 www.mitex.us 11 MTX The frame’s horizontal width and vertical height calculate automatically. The horizontal width has the following constraints:  Value should be divided by 32  Max value is 4096 The vertical height has the following constraints:  Value should be divided by 32  Max value not limited 4.6 Ratings Table 4. Absolute Maximum Ratings Min Max Unit Core Power supply -0.5 1.42 V I/0 Power supply -0.5 3.60 V PLL Power supply -0.5 1.42 V TA Storage Temperature (Ambient) -65 150 °C TJ Junction Temperature -65 125 °C Min Max Unit Symbol Vcc VCCIO VCC_PLL Description Table 5. Recommended operating conditions Symbol Description Vcc Core Power supply 1.14 1.26 V VCCIO I/0 Power supply 3.14 3.46 V PLL Power supply 1.14 1.26 V 0 85 °C -40 100 °C VCC_PLL TJCOM Junction Temperature Commercial Operation TJIND Junction Temperature Industrial Operation 02/16/21 www.mitex.us 12 MTX 5 Package Specifications The MTX001-30 is packaged in a 30-Ball WLSC. Its package dimensions are shown in Figure 6 (in millimeters). Figure 6. MTX001-30 package The MTX001-48 is packaged in a 48 pin VFQFN Exposed Pad. Its package dimensions are shown in Figure 7 (in mm). 02/16/21 www.mitex.us 13 MTX Figure 7. MTX001-48 package 6 Ordering information 02/16/21 www.mitex.us 14 MTX 7 Revision history Date Revision Version 5/14/2019 0 Original revision 02/01/2020 1 Product table added 02/09/2021 2 Timing digarramm updated 8 Disclaimer We expressly disclaim any liability arising out of the application or use of the MTX. We reserve the right to make changes, at any time, to the MTX as deemed desirable in the sole discretion of ours. We assume no obligation to correct any errors contained herein or to advise you of any correction if such be made. We will not assume any liability for the accuracy or correctness of any engineering or technical support or assistance provided to you in connection with the MTX. THE DESIGN IS PROVIDED “AS IS” WITH ALL FAULTS, AND THE ENTIRE RISK AS TO ITS FUNCTION AND IMPLEMENTATION IS WITH YOU. YOU ACKNOWLEDGE AND AGREE THAT YOU HAVE NOT RELIED ON ANY ORAL OR WRITTEN INFORMATION OR ADVICE, WHETHER GIVEN BY US, OR OUR AGENTS OR EMPLOYEES. WE MAKE NO OTHER WARRANTIES, WHETHER EXPRESS, IMPLIED, OR STATUTORY, REGARDING THE DESIGN, INCLUDING ANY WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE, AND NONINFRINGEMENT OF THIRD-PARTY RIGHTS. The MTX is not designed or intended for use in the development of on-line control equipment in hazardous environments requiring fail-safe controls, such as in the operation of nuclear facilities, aircraft navigation or communications systems, air traffic control, life support, or weapons systems (“High-Risk Applications”). We specifically disclaim any express or implied warranties of fitness for such High-Risk Applications. You represent that use of the MTX in such High-Risk Applications is fully at your risk. 02/16/21 www.mitex.us 15
MTX001-48-C 价格&库存
很抱歉,暂时无法提供与“MTX001-48-C”相匹配的价格&库存,您可以联系我们找货
  • 1+ 0.0902 1+ 0
  • 500+ 0.0789 500+ 0
  • 1000+ 0.0733 1000+ 0
  • 5000+ 0.0676 5000+ 0
库存:34407
    • 1+ 0.5748 1+ 0
    库存:927
      • 1+ 0.6188 1+ 0
      • 100+ 0.5895 100+ 0
      库存:6675
      • 1+ 0.6537 1+ 0
      • 200+ 0.6199 200+ 0
      库存:500
        • 1+ 2.254 1+ 0
        • 100+ 2.0286 100+ 0
        库存:5046
          • 1+ 4.3728 1+ 0
          库存:128
          • 1+ 8.0111 1+ 0
          库存:223
          • 1+ 9.8616 1+ 0
          库存:113
            • 1+ 5.2944 1+ 0.6743
            • 10+ 3.9999 10+ 0.5094
            • 25+ 3.8717 25+ 0.4931
            • 100+ 3.7434 100+ 0.4768
            • 250+ 3.6151 250+ 0.4604
            • 500+ 3.2769 500+ 0.4174
            • 1000+ 3.0787 1000+ 0.3921
            • 8000+ 2.8104 8000+ 0.3579
            库存:9959
              • 1+ 7.8133 1+ 0.9357
              • 10+ 6.7754 10+ 0.8114
              • 25+ 5.0378 25+ 0.6033
              • 104+ 4.4547 104+ 0.5335
              • 260+ 4.2798 260+ 0.5125
              • 1040+ 4.2215 1040+ 0.5056
              • 5044+ 3.8717 5044+ 0.4637
              库存:63356
              • 1+ 16.5361 1+ 1.9802
              • 10+ 12.0114 10+ 1.4384
              • 25+ 10.9969 25+ 1.3169
              • 50+ 9.4925 50+ 1.1367
              • 100+ 8.6529 100+ 1.0362
              • 250+ 7.1486 250+ 0.8561
              • 400+ 6.822 400+ 0.817
              • 1200+ 6.1107 1200+ 0.7318
              • 2800+ 6.0174 2800+ 0.7206
              库存:994
                • 500+ 0.0845 500+ 0
                • 1000+ 0.0784 1000+ 0
                • 5000+ 0.0725 5000+ 0
                库存:34501
                  • 2000+ 0.1244 2000+ 0
                  库存:64620
                    • 18000+ 0.9581 18000+ 0
                    库存:54422
                      • 1000+ 1.7374 1000+ 0
                      库存:8338
                        • 100+ 2.1733 100+ 0
                        库存:5400
                          • 5+ 2.2 5+ 0
                          库存:816
                            • 2200+ 2.64 2200+ 0
                            库存:34076
                              • 1+ 4.73 1+ 0
                              • 100+ 3.5475 100+ 0
                              • 2200+ 2.365 2200+ 0
                              库存:6445
                                • 1+ 5.47735 1+ 0
                                • 10+ 4.75441 10+ 0
                                • 100+ 4.17657 100+ 0
                                • 1000+ 3.41647 1000+ 0
                                • 8000+ 2.53237 8000+ 0
                                库存:8738
                                  • 1+ 6.47317 1+ 0
                                  • 10+ 5.70886 10+ 0
                                  • 100+ 5.16684 100+ 0
                                  • 1248+ 4.26045 1248+ 0
                                  • 2496+ 3.05514 2496+ 0
                                  • 4992+ 2.33707 4992+ 0
                                  库存:5155
                                    • 1000+ 1.89275 1000+ 0
                                    • 8000+ 1.808 8000+ 0
                                    库存:8995
                                      • 0+ 0 0+ 0
                                      库存:419
                                        • 1+ 4230.41663 1+ 0
                                        库存:97
                                          • 2200+ 2.1894 2200+ 0
                                          库存:5272
                                            • 2080+ 5.8032 2080+ 0
                                            库存:9021
                                              • 1+ 252.22075 1+ 0
                                              • 2+ 252.20877 2+ 0
                                              • 3+ 243.54867 3+ 0
                                              库存:543
                                                • 5+ 5.45957 5+ 0
                                                • 100+ 5.34937 100+ 0
                                                • 375+ 5.24157 375+ 0
                                                • 1500+ 5.13617 1500+ 0
                                                • 3000+ 5.03316 3000+ 0
                                                库存:567
                                                  • 10+ 9.1488 10+ 0
                                                  • 250+ 8.98949 250+ 0
                                                  • 1000+ 8.7655 1000+ 0
                                                  • 2500+ 8.5475 2500+ 0
                                                  • 5000+ 8.33309 5000+ 0
                                                  库存:228
                                                    • 2+ 35.15543 2+ 0
                                                    • 30+ 34.53856 30+ 0
                                                    • 100+ 33.67016 100+ 0
                                                    • 250+ 32.82571 250+ 0
                                                    • 1250+ 27.02237 1250+ 0
                                                    库存:1280
                                                      • 1+ 41.95893 1+ 0
                                                      • 15+ 41.24025 15+ 0
                                                      • 50+ 40.19817 50+ 0
                                                      • 100+ 39.20399 100+ 0
                                                      库存:1511
                                                        • 1+ 41.97091 1+ 0
                                                        库存:498
                                                          • 1+ 43.40827 1+ 0
                                                          • 15+ 42.65366 15+ 0
                                                          • 50+ 41.57564 50+ 0
                                                          • 100+ 40.54553 100+ 0
                                                          库存:557
                                                            • 1+ 44.52223 1+ 0
                                                            • 15+ 43.74366 15+ 0
                                                            • 50+ 42.64168 50+ 0
                                                            • 100+ 41.56366 100+ 0
                                                            库存:809
                                                              • 2+ 74.28756 2+ 0
                                                              • 30+ 73.1736 30+ 0
                                                              • 100+ 72.15547 100+ 0
                                                              • 250+ 70.65223 250+ 0
                                                              • 1250+ 58.1472 1250+ 0
                                                              库存:574
        • 1+ 78.947 1+ 0
        • 10+ 78.76733 10+ 0
        • 50+ 78.4559 50+ 0
        • 100+ 78.25227 100+ 0
        • 500+ 64.40571 500+ 0
        库存:777
        • 1+ 451.55862 1+ 0
        库存:112
        • 100+ 0.11978 100+ 0
        • 1000+ 0.09299 1000+ 0
        • 3000+ 0.07809 3000+ 0
        库存:4721
        • 5+ 0.88906 5+ 0
        • 50+ 0.70244 50+ 0
        • 150+ 0.60912 150+ 0
        • 1000+ 0.50004 1000+ 0
        • 2000+ 0.4441 2000+ 0
        库存:2445
        • 5+ 1.27905 5+ 0
        • 50+ 1.00149 50+ 0
        • 150+ 0.88247 150+ 0
        • 1000+ 0.68969 1000+ 0
        • 2000+ 0.6236 2000+ 0
        库存:3575
        • 5+ 1.59776 5+ 0
        • 50+ 1.23855 50+ 0
        • 150+ 1.08454 150+ 0
        • 1000+ 0.89252 1000+ 0
        • 2000+ 0.80698 2000+ 0
        库存:3619
        • 1+ 7.4088 1+ 0
        • 10+ 7.236 10+ 0
        • 30+ 7.128 30+ 0
        库存:143
        • 64+ 24.16392 64+ 0
        • 208+ 23.67915 208+ 0
        • 304+ 23.28139 304+ 0
        • 512+ 22.88363 512+ 0
        库存:2555
        库存:637
        • 24+ 70.2295 24+ 0
        • 48+ 70.2295 48+ 0
        • 72+ 68.96164 72+ 0
        • 96+ 67.69378 96+ 0
        • 216+ 66.33891 216+ 0
        • 312+ 65.07105 312+ 0
        库存:987
        • 24+ 70.2295 24+ 0
        • 48+ 70.2295 48+ 0
        库存:629
        • 4+ 254.09406 4+ 0
        • 10+ 243.93875 10+ 0
        • 42+ 234.15634 42+ 0
        库存:623
