智新电子(厦门)有限公司
JIMSON ELECTRONICS (XIAMEN) CO.,LTD.
规
格
书
SPECIFICATION
☆客户名称
CUSTOMER:
立创
☆产品名称
PROD NAME:
电容器/Capacitor
☆类别
TYPE:
MRC
☆规格
DESCRIPTION:
0.1uF+120Ω K 300VAC
0.01uF +120Ω K 300VAC
☆日期
DATE:
2019-10-14
File NO:JS-S191014209
1.SPECIFIC REFERENCE DATA
DESCRIPTION
Capacit Rated Capacitance 0.1uF、0.01uF
ance
标称值
容量
Capacitance olerance K=±10%
容量误差
300VAC
Voltage Rated voltage
电压
额定电压
Voltage proof
耐电压
TEST CONDITIONS
VALUE
Measuring
frequency:
1kHz±10%
Measuring voltage: 1Vms.max.
4.3*UR
Unit:VDC (1 minute at 20℃)
无永久性击穿及飞弧
Resistance 电阻阻值
Insulation resistance
绝缘电阻(仅指串联)
120Ω
Endurance
耐久性
1000 hours with 125% of rated
ΔC/C≤10%;
voltage
at 85℃.
ΔDF≤0.8% (C≤1uF)
ΔDF≤0.5%;(C>1uF)
IR≥50% of the specified value(标
称值)
Climatic catalogue
气候类别
Solder ability
可焊性
40/100/21
Heat shock
耐焊接热
Lead tensile strength:
引脚拉伸强度
Lead bending strength
引脚弯曲强度
Vibration
震动
Reference standard
引用标准
C≤0.33uF
C >0.33uF
IR≥15000MΩ
IR*C≥5000S
measured at rated voltage or less than
100VDC
1 minute at 20℃ and RH≤65%
solder bath : 235±5℃
bath time: 2.0±0.5 sec
speed: 25±6 mm/sec
depth: 1.5+0.5/-0mm from the
bottom of the body
ΔC/C≤±5%,
solder bath : 260±5℃
DF≤1.2*规定值。
bath time: 5.0±0.5 sec
试 验 后 电 容 器 外 观 应 无 可 见 损 speed: 25±6 mm/sec
伤,
bottom of the body
外观无损伤
Pull:2.2 LBS
time: 5 sec
引脚无损伤
Load of lead:1.1 LBS
The body of capacitor is bent 90
degrees and returned to its original
position
Solder should cover at least 75% of
the circumference of the lead
浸没部分引脚需有 75%以上面积
挂上锡
外观无可见损伤
Frequency cycle: from 10Hz to 55Hz
and then 10Hz
Amplitude: 1.5mm in three directions
Time: 2 hours each directions with a
total of 6 hours
IEC 60384-14,EN60384-14
Page1 (MRC)
2.CONSTRUCTION:
2.1 Dielectric
介质
polypropylene film
聚丙烯薄膜
2.2 Electrodes
电极
vacuum evaporated metal
真空蒸镀金属
Encapsulated in reinforced flame
retardant plastic case sealed with
epoxy resin meeting the requirement
of-UL94V-0
(阻燃盒子并以环氧树脂灌封)
Tinned Wire
orpolyvinylchloride(PVC)insulatio
n stranded copper wire
径向镀锡导线或绝缘导线
2.3 Coating
灌封
2.4 Leads
导线
2.5 Resistance
电阻
2.6 Terminal
contact
引线连接方式
Non-Inductive,high pulse resistor(无
感型,耐脉冲电阻)
electrically welded;
电弧点焊
3.SAFETY APPROVALS
RC -- (SERIES)
CHINA 中国
GB/T14472-1998
欧共体
EN132400 IEC60384-14
USA
美国
UL 1283
CQC03001002848
SE/0364-1
E221606
4.FEATURE:
小体积,性能佳
Small size with superior performance;
可安装于 PCB
Suitable for PCB mounting ;
适用于交/直流
Ideal for AC or DC application
多种电阻功率 1/4,1/2 和 1 瓦特,电容 0.001µF 至 1.0µF 供选择
Lage product selection range with 1/4,1/2 and 1 watt resistors ,0.001µF to 1.0µF capacitance
可选软引线式、管状或盒子结构
Providing flexible wire , tubular and box type on request.
Page2 (MRC)
5.APPLICATION:
设备切换时,保护触点,消除火花及噪音
Protection for contacts from noise during switching operations of equtpment;
接触器、继电器、电机等操作时保护电子设备
Protection of electronic instruments during operation of relays ,solenoids, motors and so on
消除晶闸管、电子体、电机、焊接机等半导体设备之电谐干扰
Electrical noise protection of semiconductor equipment during the control of triacs,
transistor, motors, welders, etc.
6.APPLICATION EXAMPLE
7.THE MARKING:
内容 Those marking include:
■ 生产商 Manufacturer: JIMSON
■ 产品型号 Manufacturer’s type designation: MRC
■ 额定容量 Rated capacitance in uF, such as0.1uF
■ 容量偏差 Tolerance on rated capacitance: K=±10%
■ 额定电压 Rated voltage (AC), such as 300VAC
■ 气候类别 Climatic catalogue GMF
■ 产品等级 Sub-class, such as X2
■ 安规标志 Safety approvals: Products will be marked with all approvals which have
been achieve.(show in Page2.)
■ 引用标准 Reference standard:IEC60384-14。
Page3 (MRC)
7.HOW TO DESCRIBE JIMSON CAPACITOR
MRC
type
104
capacitance
K
tolerance
300VAC
rated voltage
RC
■TYPE:
■ 容量 CAPACITANCE:
产品的电容量用三位数字来表示,其中前两位数代表电容量的标称值,后一位表示电
容量的指数值,亦即标称值后零的个数,单位为 PF。
The rated capacitance value of the product is indicated with three digits. The first two digits indicate the two most significant
digits of capacitance value, and the third digit gives the number of following zeroes. This gives the capacitance value expressed in
Pico farad.
For example:
10 2=10×102pF=1000pF=1nF=0.001uF
15 3=15×103pF=15000pF=15nF=0.015uF
22 4=22×104pF=220000pF=220nF=0.22uF
33 5=33×105pF=3300000pF=3300nF=3.3uF
■ 容量单位 CAPACITANCE UNIT:
1F=1,000mF=1,000,000uF=1,000,000,000nF=1,000,000,000,000pF
■ 容量偏差符号 SYMBOL OF CAPACITOR TOLERANCE
SYMBOL
B
C
D
F
G
H
I
J
K
M
N
V
Z
TOLERANCE
± ± ± ± ± ± ± ± ± ± ± 20 +80
PERCENTAGE 0.1 0.2 0.5 1.0 2.0 2.5 3.0 5.0 10 20 30 -10 -20
■ 额定电压符号 SYMBOL OF RATED VOLTAGE
A
B
C
D
E
F
G
1
H
J
K
50
63
80
2
100
125
160
200
250
315
400
500
630
800
3
1000
1250
1600
2000
2500
3150
4000
5000
6300
8000
For example:
1J=63V;2E=250V;3D=2000V
Page4 (MRC)
8. PROPERTIES OF CAPACITOR AND THE DIELECTRICS:
Page5 (MRC)
9.OUTLINE
DRAWING:
10. DIMENSION:
Unit: mm
SYMBOL
CAP
RESIS
RC104K300A12
(串联)
0.1uF
120Ω
SYMBOL
CAP
RESIS
RC103K300A01
(串联)
0.01uF
120Ω
COLOR
W
±0.5
H
±0.5
T
±0.5
P
±1.0
d
±0.05
L
±0.5
YELLOW 18.0
12.0
6.0
15.0
0.6
3.8
W
±0.5
H
±0.5
T
±0.5
P
±1.0
d
±0.05
L
+5/-10
YELLOW 18.0
13.5
6.0
15.0
0.6
25.0
COLOR
Page6 (MRC)
11.使用注意事项 Caution
焊接建议 Soldering Suggestion
为了达到更好的可焊性,建议按照下列的标准;
In order to achieve a better solderability, recommended in accordance with the
following criteria
最大的焊接温度 Maximum Soldering Temperature
预热 Pre-heating
焊接 Soldering
T max
105℃
270℃
Time
1min
4S
12.存储环境及条件 Storage Environment and Conditions
12.1 存储环境 Storage Environment
储存在温度≤30℃,湿度≤70%的情况下,MBB(Moisture Barrier Bag)
未打开能够保证 24 个月的储存期。
In the storage temperature are less than 30, humidity less than 70% conditions,
MBB(Moisture Barrier Bag)is not open to ensure that the storage period of 24 months.
12.2 存储条件 Storage Condition
由于大气中存在氢氯化物、氢硫化物、硫酸物质等,因此产品储存在空气中,
引出端的可焊性会变差。
产品不能暴露在高温高湿状态,必须在 12 的存储环境条件下保存
Due to the presence of hydrogen chloride, hydrogen sulfide, sulfuric acid, etc.
in the atmosphere,So the product is stored in the air, solderability of terminations
will be poor.
Products can not be exposed to high temperature and high humidity condition,
must be stored under 12 of the storage environment.
13.绿色产品 Green Products
符合 RoHS 标准 In compliance with RoHS
智新电子公司提供的产品均符合 RoHS 2.0 环保指令的要求
JIMSON ELECTRONICS CO., LTD Products are RoHS Compliant.
THE
END
Page7 (MRC)
很抱歉,暂时无法提供与“MRC104K300A12”相匹配的价格&库存,您可以联系我们找货
