GHSE-19-050-A-02-10-S
    ALLIANCESENSORS(联盟传感器)
    Cylinder
    SENSOR LINEAR 50.8MM CONNECTOR
GHSE-19-050-A-02-10-S 数据手册
For use in: Factory Automation PLC Position Feedback Test and Measurement Packaging Equipment GHS-19 Series Spring-Loaded LVIT Linear Position Sensor Low Cost, Compact, High Performance Gaging Probes The GHS-19 series of LVIT (Linear Variable Inductance Transducer) spring-loaded position sensors by Alliance Sensors Group are contactless devices designed for dimensional measurements in QA labs, or position measuring applications in factory automation systems and in various industrial and commercial applications, such as: automotive testing, mil/aero test stands, robotic arms, and packaging equipment. An ideal solution for when the sensing element cannot be attached to the object being measured. GHS-19s are offered in nominal full scale ranges from 6.4 to 100 mm (0.25 to 4.0 inches) with excellent resolution and high stroke-to-length ratios. The maximum tip contact force on the item being measured is 1 pound. GHS-19 sensors have a 0.75 inch (19 mm) diameter aluminum or stainless steel body with a 1/2-20 UNF-2A thread 1.5 inches (38 mm) long with two 19 mm (0.75 inch) hex jam nuts for drop-in installation in place of a spring-loaded DC-LVDT gage head. These sensors utilize a probe equipped with a No. 9 contact tip, and are offered with a PT02-10-6P (6-pin) connector. Operating from a variety of DC voltages. These sensors are available with a choice of one of four analog outputs. They all include ASG's proprietary Senset™ field recalibration feature. Features:     Spring-loaded LVIT Technology™ (Linear Variable Inductance Transducer) Contactless operation prevents internal wearout from dithering or rapid cycling Excellent stroke-to-length ratio Proprietary SenSet™ field adjustable range scaling Specifications: Analog I/Os: 0-5 V or 0.5-4.5 V output with 8 -30 V input, 35 mA max. 0-10 V output with 12-30 V input, 35 mA max. 4-20 mA (3-wire) output with 18-30 V input, 60 mA max (75 C max). Measuring Ranges: 6.4 to 100 mm (0.25 to 4.0 inches) Full Scale (nominal) Linearity Error: ± 0.15% of FSO typical, ± 0.25% of FSO max Resolution: 0.025% of FSO Operating Temperature: -20 to 85 C (-40 to 105 C extended temperature range) Temperature Coefficient:
GHSE-19-050-A-02-10-S 价格&库存
很抱歉,暂时无法提供与“GHSE-19-050-A-02-10-S”相匹配的价格&库存,您可以联系我们找货
