Serial No.
2006-0570
DATE :
2006/04/27
Techfaith Wireless Communication Technology (Shanghai) Ltd.
QUARTZ CRYSTAL
ITEM :
TYPE :
DSX321G
NOMINAL FREQUENCY :
24.000000MHz
SPEC No. :
1B224000BC0E
1C224000BC0E
USER PARTS NO . :
Please acknowledge receipt of this specification by
signing and returning a copy to us.
RECEIPT
DATE
(signature)
RECEIVED
(name)
General Manufacture of Quartz Devices
DAISHINKU CORP.
1389 Shinzaike, Hiraoka-cho, Kakogawa, Hyogo
675-0194 Japan
http://www.kds.info/english.html
Phone(81)794-25-3141
Fax
(81)794-25-1134
C.ENG.
ENG.
Serial No.
2006-0570
1. ELECTRICAL CHARACTERISTICS
(This test shall be performed under the conditions of temp.at 25 +/- 3deg. C, humidity 60% max.)
1-1
NOMINAL FREQUENCY
24.000000 MHz
1-2
MODE
1-3
LOADING CAPACITANCE
1-4
FREQUENCY TOLERANCE
+/- 20 ppm Max. at +25 deg.C +/- 3 deg.C
1-5
DRIVE LEVEL
10 uW +/-
1-6
EQUIVALENT SERIES RESISTANCE
60 ohms Max. / Series
1-7
OPERATING TEMPERATURE RANGE
-10
1-8
FREQUENCY TEMPERATURE CHARACTERISTICS
+/- 30 ppm Max. /
1-9
SHUNT CAPACITANCE
2.0 pF Max.
1-10
INSULATION RESISTANCE
500 Mohms Min. / DC100V +/- 15V
1-11
STORAGE TEMPERATURE RANGE
-40
Fundamental
12.0
pF
deg.C
deg.C
2 uW
to +70 deg.C
-10
deg.C
to +70 deg.C
to +85 deg.C
2.CONSTRUCTION
2-1
HOLDER
DSX321G Ceramic Base
2-2
DIMENSIONS AND MARKING
Refer to Fig.-1 and Table-1.
3.OTHER SPECIFICATIONS
3-1
EMBOSS CARRIER TAPE & REEL
Refer to Fig.-2,3,4,5 and Table-2.
3-2
PACKING
Refer to Fig.-6.
3-3
REFLOW CONDITIONS (REFERENCE)
Refer to Fig.-7.
3-4
LAND PATTERN (REFERENCE)
Refer to Fig.-8.
4. Environmental and mechanical performance shall be specified by attached general specification.
TITLE
DSX321G TYPE SURFACE MOUNT TYPE
QUARTZ CRYSTAL SPECIFICATION
Date
2006/04/27
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
1B224000BC0E
1C224000BC0E
1
7
DM-Z0008:Style-108
< DIMENSIONS AND MARKING >
3 .20+ / -0 .1
3 .20+ / -0 .1
2 .50+ / -0 .1
2 .50+ / -0 .1
0 .15
(1 ) (2 ) (3 )
D1 2
F requenc y
F requency
Lo t No .
Lo t No .
8 - (0 .10 )
0 .75+ / -0 .15
Logo
Logo
##11
# 22
## 34
# 43
0 .70
(0 .90 )
0 .70
C0 .30( I NDEX)
< T O P V I EW >
0 .90
(1 .20 )
0 .90
It is recommended
mm
un i t : m
mthat #2,4 is connected with GND.
unit : mm Ma rk ing #2 ,#4 is no t connec ted w i th any th ing .
Tolerance To
: +/-0.1
le rance : + / -0 .1
# 4
# 3
# 1
# 2
(Fig.-1)
Marking is Laser Marking:
Marking should be printed as follows:
Logo , Nominal Frequency , manufactured year & month
Logo and manufacturing location ( 1 )
Producing District
Marking
Our Specification.No.
Japan
Indonesia
D
D
1B224000BC0E
1C224000BC0E
Nominal Frequency ( 2 ) = Mark two dights from upper
( ex. 24.0000 MHz -->
24
Manufacturing lot No.( 3 )
(year) ex. 2006
(Month) ex. April
Jan.
A
Feb.
B
shall be marked as ' 6
shall be marked as ' D
(Table-1)
Mar.
Apr.
C
D
May.
E
TITLE
Date
2006/04/27
Jun.
F
' (The last digit of the year)
' (As shown in Table-1.)
Jul.
G
Aug.
H
Sep.
J
Oct.
K
Nov.
L
Dec.
M
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
1B224000BC0E
1C224000BC0E
2
7
DM-Z0008:Style-108
< EMBOSS CARRIER TAPE & REEL >
1 .55d ia .+ / -0 .05
2 . 0+ / -0 . 05
4 . 0+ / -0 . 1
3 . 5+ / - 0 . 0 5
D249B
8 . 0+ / - 0 . 2
3 . 5+ / - 0 . 1
4 . 0+ / -0 . 1
0 . 25+ / -0 . 05
1 . 7 5+ / - 0 . 1
(1)Dimensions of embossed carrier tape
1 .15d ia .+/ -0 .05
1 .0+/ -0 .1
User Direction of feed
2 .8+ / -0 .1
( Un i t :mm )
(Fig.-2)
q
F3
(2)Dimensions of tape reel
U
q 2
F
E
V
B
A
C
F1
W1
(Fig.-3)
TITLE
Date
2006/04/27
W2
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
1B224000BC0E
1C224000BC0E
3
7
DM-Z0008:Style-108
(Table-2)
(UNIT:mm)
Item
Diameter
Inside of Frange
Outside of Frange
Inside Diameter
Flange
Width
Center Core Slit
Center
Core
Length
Angle
Spindle Diameter
Width
Key Seats
Length
Angle
Mark
A
W1
W2
B
F1
F2
F3
V
q
C
E
U
q
Dimensions Angle
180 dia. +0.0 / -3.0
9.0 + / - 0.3
11.4 + / - 1.0
60 dia. +1.0 / -0.0
3.0 + / - 0.2
4.0 + / - 0.2
5.0 + / - 0.2
11.9
120 deg.
13 dia. + / - 0.2
2.0 + / - 0.5
10.5 + / - 0.4
120 deg.
(3)Storage condition
Temperature : +40 deg.C Max.
Relative Humidity : 80% Max.
( It is a guaranteed term because it obtains an excellent soldering: 6 months)
(4)Standard packing quantity
3,000 pcs/reel for 180 dia.
(5)Material of the tape
Tape
Carrier tape
Cover tape
Material
Polystyrene+Carbon
Polyester
(6)Label contents
Type
Our specification No.
Your Part No.
Lot No.
Nominal Frequency
Quantity
Our Company Name
Producting Country
Stick a label on the each reel.
TITLE
Date
2006/04/27
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
1B224000BC0E
1C224000BC0E
4
7
DM-Z0008:Style-108
(7)Taping dimension
Leader
Cover-tape The length of cover-tape in the leader is more than 400mm
including empty embossed area.
Carrier-tape After all products were packaged, must remain more than
twenty pieces or 400mm empty area, which should be sealed
by cover-tape.
Terminal
Cover-tape The tip of cover-tape shall be fixed temporary by paper
tape and roll around the core of reel one round.
Carrier-tape The empty embossed area which are sealed by cover-tape
must remain more than 40mm.
Terminal
Leader
Component
Empty Components Unreeling direction
Empty Components
Cover-tape
Carrier-tape
(Fig.-4)
(8)Joint of tape
The carrier-tape and cover-tape should not be jointed.
(9)Release strength of cover tape
It has to between 0.1N to 0.7N under following condition.
Pulling direction
165 deg. to 180 deg.
Speed
300mm/min.
Otherwise unless specified.
165 to 180 deg.
Pulling direction
(Fig.-5)
Other standards shall be based on JIS C 0806 -1990.
TITLE
Date
2006/04/27
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
1B224000BC0E
1C224000BC0E
5
7
DM-Z0008:Style-108
< PACKING >
(1)STORAGE METHOD
Label contents
The type of product
Lot No.
Specification
Quantity
Shipment Day
Remark
LABEL
(Fig-6)
(2)BOX SIZE
From lot size packingsize shall be changed.
In the upper and lower part and the opening in box it shall be protected products using
aircushion sheets.
TITLE
Date
2006/04/27
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
1B224000BC0E
1C224000BC0E
6
7
DM-Z0008:Style-108
< REFLOW CONDITIONS (REFERENCE) >
During the solder reflow process, please complete within following temperature, period.
Reflow soldering shall be allowed only two times.
260deg.C+/-5deg.C
220deg.C+/-5deg.C
160deg.C to 180deg.C
10 s
60 s
120 s
Total time : 240 s Max.
(Fig.-7)
HANDSOLDERING METHOD : 340 [deg.C] Max. / 3[s] Max.
(Please take care so that a soldering iron should not touch a product directly.)
< LAND PATTERN (REFERENCE) >
0 .8
1 .4
1 .2
0 .5
1 .2
1 .4
unit : mm
(Fig.-8)
TITLE
Date
2006/04/27
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
1B224000BC0E
1C224000BC0E
7
7
DM-Z0008:Style-108
1.MECHANICAL ENDURANCE
1.1 SHOCK
After the following test,parts shall conform specification3-1-2.
10cycles(60times) drop from 150 [cm] heights to concrete.
Further,parts shall be solderd on substrate, fixed bakelite materials(about 100[g]).
Substrate materials
Glass Epoxy
1 cycle
each 1 times of 6 directions
1.2 VIBRATION
After the following test,parts shall conform specification3-1-1.
and no abnormal appearance shall be observed.
(1)Frequency of Vibration
10[Hz] to 55[Hz]
(2)Amplitude(p-p)
Sine waves of 1.5[mm ]
(3)Vibration axis
X.Y.Z
(4)Vibration period
2 [h] for each axis
1.3 SUBSTRATE BENDING
and no abnormality shall be observed in external appearance and sealing
tightnen and others shall be based on ET-7403 of EIAJ.
Mount the specimen on substrate.
Apply the following pressure
Direction
Speed
Hours
Amount of substrate
see Fig.-1
0.5 [mm/s]
5 +/- 1 [s]
3 [mm] Max.
pressure jig
R230
P.C.B.
45+/-2
45+/-2
(Fig.-1)
TITLE
Date
2006/04/27
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
Attached sheet
1B224000BC0E
1C224000BC0E
1
5
DM-Z0008:Style-108
1.4 SHEAR
After the following test, parts shall conform specification3-1-1.
tightness and others shall be based on ET-7403 of EIAJ.
Weight
10 [N]
Hours
10 +/- 1 [s]
Direction
see Fig.-2
P.C.B.
pressure jig
specimen
R0.5
(Fig.-2)
1.5 BODY STRENGTH
Weight
10 [N]
Hours
10 +/- 1 [s]
Direction
see Fig.-3
pressure jig
R0.5
specimen
W
L
0.5L
L >= W
L
(Fig.-3)
TITLE
Date
2006/04/27
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
Attached sheet
1B224000BC0E
1C224000BC0E
2
5
DM-Z0008:Style-108
1.6 SEAL
Less than 2.0×10-9 [Pa m 3/sec]. by Helium leak detector.
Also, no serial bubble is observed by Fluorinert tests.
1.7 SOLDERABILITY
After the following test, more than 90[%] of terminal shall be covered by new
solder.
3 seconds +/- 1 second dip in 235 [deg.C] +/- 5 [deg.C] solder.
(Use rosin type flux for solder.)
2.ENVIRONMENTAL ENDURANCE
2.1 HUMIDITY
Two hours past at room temperature after following test, parts
240 hours +60 [deg.C] +/- 2 [deg.C] , relative humidity 85[%] +/- 5[%].
2.2 LOW TEMPERATURE
240 hours -40 [deg.C] +/- 2 [deg.C].
2.3 HIGH TEMPERATURE
240 hours +85 [deg.C] +/- 2 [deg.C].
2.4 TEMPERATURE CYCLE
Two hours past at room temperature after 25 cycles of following
test, parts shall conform specification3-1-2.
+85deg.C
30min.
1 to 2 min.
+25deg.C
30min.
-40deg.C
1cycle
(Fig.-4)
2.5 RESISTANCE TO SOLDERING HEAT
24 hours past at room temperature from following test, parts
VPS:30 Seconds in FC-70 vapor(215 [deg.C] Boiling Point)
TITLE
Date
2006/04/27
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
Attached sheet
1B224000BC0E
1C224000BC0E
3
5
DM-Z0008:Style-108
3.SPECIFICATION
Frequency Variation and Equivalent Resistance shall be within
Table-1 after the test.
(Table-1)
3-1-1
3-1-2
3-1-3
Frequency Variation
±2[ppm]
±5[ppm]
±10[ppm]
TITLE
Date
2006/04/27
±15[%] or 2[ohms] max. (Use larger specification)
±20[%] or 3[ohms] max. (Use larger specification)
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
Attached sheet
1B224000BC0E
1C224000BC0E
4
5
DM-Z0008:Style-108
[ DSX321G SERIES , IN USE ]
1.SOLDERING
Please perform the attached Reflow conditions to reference within 2 times.
2.MOUNT
Although it corresponds to automatic mounting,
please carry out the loading test by the loading machine to be used,
and check that there is no influence in the characteristic.
Please be careful of the Curve not to influence
the characteristic of a product, and a soldering state
at the process which makes a substrate generate the Curve,
the break of a board etc. .
3.WASHING
About use of the washing liquid of a basin system,
an alcoholic system, and a chlorofluorocarbon-replacing
material system, it is checking that it is satisfactory.
However please consult in advance about other washing liquid.
Although the check about ultrasonic washing is performed,
since it is an examination with a simple substance,
the check for the second time by the use state is recommended.
4.THE CAUTIONS ON USE
The piece of crystal it is processed very smaller than the conventional thing
inside DSX321G series crystal unit may be damaged,
if excessive excitation electric power is applied.
Please use it below with the value specified on a catalog and specifications.
Please refrain from forming patterns under crystal resonators since there is
a possibility to cause crack in base.
If the temperature is higher than 280 [deg.C], there is a possibility for the sealing glass to remelt.
Avoid using the product at temperature higher than specified.
5.HANDLING OF A PRODUCT
DSX321G series has sufficient intensity to fall and vibration.
However when too much shock is added according to a certain cause,
the use after a characteristic check is recommended.
6.STORAGE
Since the soldering nature of a terminal may be degraded,
please avoid storage in high temperature and a humid place.
Please keep it in the place which direct rays do not hit
and dew condensation does not generate.
TITLE
Date
2006/04/27
Trigonometry
Unit
Scale
Drawing No.
Rev.
Page
Attached sheet
1B224000BC0E
1C224000BC0E
5
5
DM-Z0008:Style-108
2006-0570 REVISION RECORD
Rev.No
Date
2006/04/27
Reason
Contents
The first edition.
Approved
Checked
Drawn
T. Nakamura
H. Matsuda
K. Nakanishi
DM-Z0002:Style-008
很抱歉,暂时无法提供与“1C224000BC0E”相匹配的价格&库存,您可以联系我们找货
