HT293A
Low Power Low Offset Voltage Dual Comparators
1. DESCRIPTION
The HT293 consists of two independent precision voltage comparators with an offset voltage specification as low as 2.0 mV
max for two comparators which were designed specifically to operate from a single power supply over a wide range of
voltages.
Application areas include limit comparators, simple analog to digital converters; pulse, square wave and time delay generators;
wide range VCO; MOS clock timers; multi-vibrators and high voltage digital logic gates.
2. FEATURES
Single or Split Supply Operation
Low Input Bias Current
Low Input Offset Current
Input Common Mode Voltage Range to Gnd
Low Output Saturation Voltage
TTL and CMOS Compatible
ORDERING INFORMATION
HT293N Plastic
HT293R SOIC
TA =-40 to 85 C for all packages.
LOGIC DIAGRAM
PIN ASSIGNMENT
PIN 8 = VCC
PIN 4 = GND
Rev. 01
HT293A
3. MAXIMUM RATINGS
Symbol
Value
Unit
Power Supply Voltages
Single Supply
Split Supplies
36
18
V
VIDR
Input Differential Voltage Range
36
V
VICR
Input Common Mode Voltage Range (1)
-0.3 to VCC
V
ISC
Output Short Circuit to Ground
Continuous
IIN
Input Current, per pin (2)
50
mA
TJ
Junction Temperature
Plastic Packages
150
C
Storage Temperature
-65 to +150
C
VCC
Tstg
Parameter
TL
Lead Temperature, 1mm from Case for 10 Seconds
260
C
PD
Power Dissipation @TA=25C
Plastic Package
Derate above 25C
570
5.7
W
mW/C
Maximum Ratings are those values beyond which damage to the device may occur.
Functional operation should be restricted to the Recommended Operating Conditions.
Notes:
1. Split Power Supplies.
2. VIN
很抱歉,暂时无法提供与“HT293ARZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.56700
- 50+0.43740
- 150+0.37260
- 500+0.31104
