ES7144LV
ES7144LV
    EVEREST(顺芯)
    ES7144LV
ES7144LV 数据手册
ES7144LV 10-pin, 24-Bit, 192 kHz Stereo D/A Converter for PCM Audio GENERAL DESCRIPTION FEATURES The ES7144LV is a low cost 10-pin stereo digital to analog converter. The ES7144LV can accept I²S serial audio data format up to 24-bit word length. The device uses advanced multi-bit ∆-∑ modulation technique to convert data into two channel analog outputs. The multi-bit ∆ -∑ modulator makes the device with very low sensitivity to clock jitter and very low out of band noise.      100 dB SNR -85 dB THD+N Up to 200 kHz sampling frequency I2S audio data format, 16-24 bits Single power supply 3V to 5.5V APPLICATIONS      Digital Photo Frame Set top box Digital TV DVD player Audio player ORDERING INFORMATION ES7144LV -40°C ~ +85°C TSSOP-10 (Same as MSOP-10) BLOCK DIAGRAM SDATA SCLK LRCK Audio Data Interface Clock Manager/ Sample Rate Detector Interpolation Filter Interpolation Filter Multi-level Sigma-delta DAC Output Amp Low Pass Filter AOUTL Multi-level Sigma-delta DAC Output Amp Low Pass Filter AOUTR CLKIN Rev 7.0 1 May, 2017 Everest Semiconductor ES7144LV 1. PIN DESCRIPTIONS AOUTR SDATA 1 10 SCLK 2 9 VDD LRCK 3 8 GND CLKIN 4 7 AOUTL CAP1 5 6 CAP2 I/O ES7144LV PIN PIN DESCRIPTION 1 SDATA I Serial audio data input 2 SCLK I Bit clock input 3 LRCK I Left and right channel clock input indicating input data sampling rate (Fs) and channel selection 4 CLKIN I System clock input 5 CAP1 O Filtering capacitor 6 CAP2 O Filtering capacitor 7 AOUTL O Analog output of left channel 8 GND I Ground 9 VDD I Device power supply 10 AOUTR O Analog output of right channel 2. RECOMMENDED APPLICATION CIRCUIT Figure 1 Recommended Application Circuit Rev 7.0 2 May, 2017 Everest Semiconductor ES7144LV 3. APPLICATION DESCRIPTIONS Sampling Rate and Input Clocks The serial audio input data is transmitted to the device at SDATA pin. According to the sampling rate, the device can work in three speed modes, single speed, double speed and quad speed. The device can detect the speed mode of the input data stream automatically when the sampling rate falls into the auto detection ranges listed in Table1. If the sampling rate is outside the auto detection ranges, the device will not work properly. Table 1 Auto Detection Ranges and CLKIN/LRCK Ratio MODE Fs Auto Detection Range CLKIN/LRCK Ratio Single Speed 8kHz – 50kHz 256, 384, 512, 768, 1024 Double Speed 84kHz – 100kHz 128, 192, 256, 384, 512 Quad Speed 167kHz – 200kHz 128, 192, 256 The device works with the input system clock CLKIN, sample data clock LRCK and bit clock SCLK. The data clock and bit clock must be synchronously derived from the system clock with some specific rates. The device only supports the CLKIN/LRCK ratios listed in Table1. The LRCK/SCLK ratio is normally 64. The device detects clock ratios automatically, and it will not work properly if any ratio is incorrect. Audio Data Input The ES7144LV can accept I²S serial audio input data from 16-bit to 24-bit. The device can detect the data word length automatically. The relationship of SDATA, SCLK and LRCK for the format is illustrated through Figures 2. 1 SCLK SDATA 1 2 1 SCLK 3 n-2 n-1 MSB n 1 LSB MSB 2 3 n-2 n-1 n LSB SCLK LRCK LEFT CHANNEL RIGHT CHANNEL Figure 2 I²S serial audio data format up to 24-bit Power Up and Power Down The device resets itself when VDD ramp from ground voltage to supply voltage. The ground voltage needs to be less than 0.2V for proper reset. When VDD voltage is removed, it is important to let it drop below 0.2V before next power up. An optional discharge resistor (3.3K, for example) can be placed between VDD and GND. Rev 7.0 3 May, 2017 Everest Semiconductor ES7144LV Upon applying VDD, the device will reset itself and enter power down state. During this state, the device clamps outputs to ground and power down the device operation except for clock management unit. Once proper CLKIN and LRCK clocks are applied, the device will leave power down state, and the device outputs ramp from ground to common mode voltage softly. Then the device enters the normal operation. 4. ELECTRICAL CHARACTERISTICS Absolute Maximum Ratings At or beyond this condition, operating continuously may cause permanent damage to the device. The performance and functions of the device are not guaranteed at these extremes. PARAMETER MIN MAX Supply Voltage Level -0.3V +7.0V Input Voltage Range GND-0.3V VDD+0.3V Operating Temperature Range -40°C +85°C Storage Temperature -65°C +150°C Recommended Operating Conditions PARAMETER MIN TYP MAX UNIT Supply Voltage Level 3 3.3 5.5 V Analog Characteristics Test conditions: VDD=3.3V, GND=0V, ambient temperature=25°C, Fs=48KHz, CLKIN/LRCK=256, input 0dB 1KHz sinewave PARAMETER MIN TYP 90 100 MAX UNIT DAC Performance Signal to Noise Ratio (Note 1) dB THD+N -85 Channel Separation (1KHz) 100 dB Dynamic Range 100 dB Interchannel Gain Mismatch 0 dB Frequency Response -0.02 -80 dB +0.08 dB 0.454 Fs (20Hz-20KHz) Filter Frequency Response characteristics Single Speed Passband 0 Stopband 0.547 ±0.05 Passband Ripple Rev 7.0 Fs 4 dB May, 2017 Everest Semiconductor Stopband Attenuation ES7144LV -53 dB Double Speed Passband 0 0.417 Stopband 0.583 Stopband Attenuation Fs ±0.005 Passband Ripple Fs dB -56 dB Quad Speed Passband 0 0.2083 Stopband 0.792 Stopband Attenuation Fs ±0.006 Passband Ripple Fs -50 dB dB Analog Output Characteristics Full Scale Output Level 0.7*VDD Vpp Output Impedance 120 Ω Minimum Load Resistance 2 KΩ Maximum Capacitance 100 pF Note 1. A-weighted filter is used in measurement. Rev 7.0 5 May, 2017 Everest Semiconductor ES7144LV Serial Audio Port Switching Characteristics PARAMETER SYMBOL MIN CLKIN Frequency CLKIN Duty Cycle 40 LRCK Frequency LRCK Duty Cycle 40 SCLK Frequency MAX UNIT 51.2 MHz 60 % 200 KHz 60 % 26 MHz SCLK Pulse Width Low TSCKL 15 ns SCLK Pulse Width High TSCKH 15 ns SCLK Rising to LRCK Edge Delay TLRH 10 ns SCLK Rising to LRCK Edge Setup Time TRSU 10 ns SDATA Valid to SCLK Rising Setup Time TSDS 10 ns SCLK Rising to SDATA Hold Time TSDH 10 ns TSDS TSDH SDATA TSCKL TSCKH SCLK TSCKY LRCK TLRH TLRSU Figure 3 Serial Audio Port Timing DC Characteristics PARAMETER MIN TYP MAX UNIT VDD Current VDD=3.3V 15 20 mA Power Dissipation VDD=3.3V 50 70 mW Normal Operation Mode Digital Voltage Level Input High-level Voltage 2.0 V Input Low-level Voltage Rev 7.0 0.8 V Output High-level Voltage VDD V Output Low-level Voltage 0 V 6 May, 2017 Everest Semiconductor ES7144LV 5. PACKAGE INFORMATION TSSOP-10 (3mm BODY) Outline Dimensions Symbols Dimensions (inch) Dimensions (mm) Min TYP Max Min TYP Max A --- 0.1929 --- --- 4.9 --- B --- 0.0197 --- --- 0.5 --- C --- --- 0.0433 --- --- 1.10 D 0.0059 --- 0.0118 0.15 --- 0.30 E --- 0.1181 --- --- 3.0 --- F 0.0295 --- 0.0374 0.75 --- 0.95 G 0 --- 0.0059 0 --- 0.15 H 0.0157 0.0236 0.0315 0.40 0.60 0.80 I --- 0.1181 --- 3.0 --- --- 0.406 x45o --- 0.23 --- 8o J 0.0100x45 K 0.0031 L 0 o o --- 0.0160 x45 --- 0.0091 --- 8 o --o 0.254 x45 0.08 0 o o Note: 1. Reference JEDEC MO-187 Rev 7.0 7 May, 2017 Everest Semiconductor ES7144LV 6. Contact Information: Everest Semiconductor Co., Ltd. 苏州工业园区金鸡湖大道 1355 号国际科技园, 邮编 215021 Email: info@everest-semi.com Rev 7.0 8 May, 2017
ES7144LV 价格&库存
很抱歉,暂时无法提供与“ES7144LV”相匹配的价格&库存,您可以联系我们找货
