HYG400P10LR1D/U/V
P-Channel Enhancement Mode MOSFET
Feature
Pin Description
-100V/-40A
RDS(ON)= 42mΩ(typ.) @ VGS = -10V
RDS(ON)= 48mΩ(typ.) @ VGS = -4.5V
100% Avalanche Tested
Reliable and Rugged
Halogen Free and Green Devices Available
(RoHS Compliant)
TO-252-2L
TO-251-3L
TO-251-3S
Applications
Portable equipment and battery powered systems
DC-DC Converters
Motor control.
P-Channel MOSFET
Ordering and Marking Information
Package Code
D
G400P10
U
G400P10
V
G400P10
XYMXXXXXX
XYMXXXXXX
XYMXXXXXX
D: TO-252-2L
U: TO-251-3L
V: TO-251-3S
Date Code
XYMXXXXXX
Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green”
to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous
material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr
-oduct and/or to this document at any time without notice.
www.hymexa.com
1
V1.0
HYG400P10LR1D/U/V
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (Tc=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
-100
V
VGSS
Gate-Source Voltage
±20
V
Maximum Junction Temperature
175
°C
-55 to 175
°C
Tc=25°C
-40
A
Tc=25°C
-145
A
Tc=25°C
-40
A
Tc=100°C
-28.3
A
Tc=25°C
100
W
Tc=100°C
50
W
TJ
TSTG
IS
Storage Temperature Range
Source Current-Continuous(Body Diode)
Mounted on Large Heat Sink
Note:
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RJC
Thermal Resistance, Junction-to-Case
1.5
°C/W
RJA
Thermal Resistance, Junction-to-Ambient **
110
°C/W
EAS
SinglePulsed-Avalanche Energy ***
270
mJ
L=0.3mH
* Repetitive rating;pulse width limited by max.junction temperature.
** Surface mounted on 1in2 FR-4 board.
*** Limited by TJmax , starting TJ=25°C, L = 0.3mH, VD=-80V, VGS =10V.
Electrical Characteristics(Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HYG400P10LR1
Unit
Min
Typ.
Max
VGS=0V,IDS= -250μA
-100
V
VDS= -100V,VGS=0V
-1
μA
-5
μA
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Drain-to-Source Leakage Current
VGS(th)
IGSS
RDS(ON)
TJ=55°C
Gate Threshold Voltage
VDS=VGS, IDS= -250μA
-1
-2
-3
V
Gate-Source Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS= -10V,IDS= -20A
42
55
VGS= -4.5V,IDS=-20A
48
63
ISD= -20A,VGS=0V
-0.8
-1.3
V
90
ns
70
nC
Drain-Source On-State Resistance
mΩ
Diode Characteristics
VSD*
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
www.hymexa.com
ISD=-20A,dISD/dt=100A/μs
2
V1.0
HYG400P10LR1D/U/V
Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HYG400P10LR1
Min
Typ.
Max
Unit
Dynamic Characteristics
RG
Gate Resistance
VGS=0V,VDS=0V,F=1MHz
9.4
Ciss
Input Capacitance
VGS=0V,
5003
Coss
Output Capacitance
VDS= -25V,
189
Crss
Reverse Transfer Capacitance
Frequency=1.0MHz
111
td(ON)
Turn-on Delay Time
22
Tr
Turn-on Rise Time
VDD= -50V,RG=6.8Ω,
26
td(OFF)
Turn-off Delay Time
IDS= -20A,VGS= -10V
74
66
83.1
16.8
12
Tf
Turn-off Fall Time
Gate Charge
Ω
pF
ns
Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS = -50V, VGS= -10V,
ID= -15A
nC
Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2%
www.hymexa.com
3
V1.0
HYG400P10LR1D/U/V
Typical Operating Characteristics
Figure 2: Drain Current
Power Dissipation (w)
-ID-Drain Current(A)
Figure 1: Power Dissipation
Tc-Case Temperature(℃)
Thermal
Zθjc
Impedance
Figure 4: Thermal Transient Impedance
Normalized Transient
Figure 3: Safe Operation Area
Maximum Effective Transient Thermal
Impedance, Junction-to-Case
-VDS-Drain-Source Voltage(V)
Figure 6: Drain-Source On Resistance
RDS(ON)-ON-Resistance(mΩ)
Figure 5: Output Characteristics
-VDS-Drain-Source Voltage (V)
www.hymexa.com
4
V1.0
HYG400P10LR1D/U/V
Typical Operating Characteristics(Cont.)
Figure 8: Source-Drain Diode Forward
-IS-Source Current (A)
Normalized On-Resistance
Figure 7: On-Resistance vs. Temperature
Tj-Junction Temperature (℃)
-VSD-Source-Drain Voltage(V)
Figure 9: Capacitance Characteristics
Figure 10: Gate Charge Characteristics
C-Capacitance(pF)
-VGS-Gate-Source Voltage (V)
12
www.hymexa.com
QG-Gate Charge (nC)
5
V1.0
HYG400P10LR1D/U/V
Avalanche Test Circuit and Waveforms
Switching Time Test Circuit and Waveforms
Gate Charge Test Circuit and Waveforms
www.hymexa.com
6
V1.0
HYG400P10LR1D/U/V
Device Per Unit
Package Type
Unit
Quantity
TO-252-2L
TO-251-3L
TO-251-3S
Tube
Tube
Tube
75
75
75
Package Information
TO-252-2L
COMMON DIMENSIONS
mm
SYMBOL
MIN
NOM
MAX
A
2.20
2.30
2.40
A1
0.00
0.20
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
7
2.286BSC
H
9.40
10.10
10.50
L
1.38
1.50
1.75
L1
2.90REF
L2
0.51BSC
L3
0.88
1.28
L4
1.00
L5
1.65
1.80
1.95
θ
0°
8°
V1.0
HYG400P10LR1D/U/V
TO-251-3L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b2
0.00
0.04
0.10
b2'
0.00
0.04
0.10
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
2.286BSC
H
16.22
16.52
16.82
L1
9.15
9.40
9.65
L3
0.88
1.02
1.28
L5
1.65
1.80
1.95
8
V1.0
HYG400P10LR1D/U/V
TO-251-3S
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
2.286BSC
H
10.00
11.22
11.44
L1
3.90
4.10
4.30
L3
0.88
1.02
1.28
L5
1.65
1.80
1.95
9
V1.0
HYG400P10LR1D/U/V
Classification Profile
Classification Reflow Profiles
Profile Feature
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmax to TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body Temperature
(Tp)*
Time (tP)** within 5°C of the specified
classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to peak temperature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 °C
150 °C
150 °C
200 °C
60-120 seconds
60-120 seconds
3 °C/second max.
3°C/second max.
183 °C
217 °C
60-150 seconds
60-150 seconds
See Classification Temp in table 1
See Classification Temp in table 2
20** seconds
30** seconds
6 °C/second max.
6 °C/second max.
6 minutes max.
8 minutes max.
*Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.hymexa.com
10
V1.0
HYG400P10LR1D/U/V
Table 1.SnPb Eutectic Process – Classification Temperatures (Tc)
Package
Volume mm³
Volume mm³
Thickness
很抱歉,暂时无法提供与“HYG400P10LR1D”相匹配的价格&库存,您可以联系我们找货
