Page 1/4
P/N
360271
2014/12/12
Data Sheet
360271
Illustration
see enlarged drawing at the end of the document
Product specification
• screw type terminal block, solderable
• direction of connection 90°
• wire protector
• color black
• with molded housing, single solder pin, screw brought down by hand (transport safety)
• Connection data
V / A / AWG 50 / 15 / 24 - 14
Page 2/4
P/N
360271
2014/12/12
Data Sheet
360271
Technical Data
General Data
Tightening torque SEV
Tightening torque UL
Solder pin length
min. number of poles
max. number of poles
Insulating material class
Overvoltage category
Pollution degree
Rated test voltage
0.5 Nm
7 lb-in
2.9 mm
1
1
CTI 600
III
3
0.8 kV
III
2
4 kV
Connection data
V / A / AWG
50 / 15 / 24 - 14
Material
terminal body material
terminal body surface
screw surface
wire protector material
screw thread
CuZn
Ni + Sn
Zn Cr(VI)-frei/free
CuNi18
M3
Climatic properties
upper limit temperature
lower limit temperature
105 °C
-40 °C
General
solderability
Tolerance
Acc. to JEDEC JESD22-B102E 245°C/5s
ISO 2768 -mH
II
2
2.5 kV
Data Sheet
360271
Illustration
Drawing
Page 3/4
P/N
360271
2014/12/12
Data Sheet
360271
PCB Layout
Powered by TCPDF (www.tcpdf.org)
Page 4/4
P/N
360271
2014/12/12
很抱歉,暂时无法提供与“360271”相匹配的价格&库存,您可以联系我们找货
