Data Sheet
RT063xxHBNC
Page 1/4
P/N
310601xx
xx=number of poles
2014/01/27
Illustration
see enlarged drawing at the end of the document
Product specification
• screw type terminal block, solderable
• centerline 3.50 mm, direction of connection 90°
• fittable without loss of poles
• color black
• Connection data
V / A / AWG 125 / 15 / 20 - 14
1 mm² 125 V / 13.5 A / T60
Page 2/4
P/N
310601xx
xx=number of poles
2014/01/27
Data Sheet
RT063xxHBNC
Technical Data
General Data
Tightening torque SEV
Tightening torque UL
Solder pin length
min. number of poles
max. number of poles
Insulating material class
clearance/creepage dist.
protection category
Overvoltage category
Pollution degree
Rated voltage
Rated test voltage
0.15 Nm
3 lb-in
3.4 mm
2
16
CTI 600
2.1 mm
IP 00
III
3
160 V
2.5 kV
III
2
400 V
2.5 kV
Connection data
V / A / AWG
125 / 15 / 20 - 14
1 mm²
Material
insulating material
flammability class
terminal body material
terminal body surface
screw surface
screw thread
PA66
V0
CuZn
Cu + Ni + Sn
Zn Cr(VI)-frei/free
M2
Climatic properties
upper limit temperature
lower limit temperature
105 °C
-40 °C
General
solderability
Tolerance
Acc. to JEDEC JESD22-B102E 245°C/5s
ISO 2768 -mH
II
2
400 V
2.5 kV
Data Sheet
RT063xxHBNC
Illustration
Drawing
L=(pole size - 1) x centerline + 3.5 [0.138]
Page 3/4
P/N
310601xx
xx=number of poles
2014/01/27
Data Sheet
RT063xxHBNC
PCB Layout
Powered by TCPDF (www.tcpdf.org)
Page 4/4
P/N
310601xx
xx=number of poles
2014/01/27
很抱歉,暂时无法提供与“31060102”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+2.84194100+0.34393
- 400+2.82866400+0.34233
- 1000+2.828601000+0.34232
- 2500+2.828532500+0.34231
- 4000+2.828474000+0.34230
