Data Sheet
PT115xxHBBN
Page 1/5
P/N
313301xx
xx=number of poles
2014/01/27
Illustration
see enlarged drawing at the end of the document
Product specification
• pin header, solderable
• centerline 5.00 mm, direction of connection 90°
• closed ends
• color black
• codeable
• Connection data
V / A 300 / 15
13.5 A / 320 V / 4 kV / 3 / IEC 61984
Page 2/5
P/N
313301xx
xx=number of poles
2014/01/27
Data Sheet
PT115xxHBBN
Technical Data
General Data
Solder pin length
min. number of poles
max. number of poles
Insulating material class
clearance/creepage dist.
protection category
Overvoltage category
Pollution degree
Rated voltage
Rated test voltage
3.45 mm
2
24
CTI 600
4 mm
IP 00
III
3
320 V
4 kV
III
2
800 V
4.0 kV
Connection data
V/A
300 / 15
Material
insulating material
flammability class
contact pin material
contact pin surface
PA66
V0
CuFe
Ni + Ag
Climatic properties
upper limit temperature
lower limit temperature
105 °C
-40 °C
General
solderability
Tolerance
Acc. to JEDEC JESD22-B102E 245°C/5s
ISO 2768 -mH
II
2
800 V
4 kV
Page 3/5
P/N
313301xx
xx=number of poles
2014/01/27
Data Sheet
PT115xxHBBN
Matching Part to
P/N
313131
313141
313491
313501
ASP045
SP065XXVBNC
SP065XXVBPC
Product name
RP035xxHBLC Typ 313
RP035xxHBLD Typ 314
RP015xxVBLC Typ 349
RP015xxSBLC Typ 350
SP045xxVBNC ASP045
SP065xxVBNC
SP065xxVBPC
Accessories
P/N
700024-01-9
700523-0157 (on request)
700523-0257 (on request)
Product name
700024
Geh_Kappe_swg_Block
Geh_Kappe_swg_Block
Data Sheet
PT115xxHBBN
Illustration
Drawing
L=(pole size - 1) x centerline + 6.2 [0.244]
Page 4/5
P/N
313301xx
xx=number of poles
2014/01/27
Data Sheet
PT115xxHBBN
PCB Layout
Powered by TCPDF (www.tcpdf.org)
Page 5/5
P/N
313301xx
xx=number of poles
2014/01/27
很抱歉,暂时无法提供与“31330102”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+2.11536100+0.25659
- 400+2.10548400+0.25539
- 1500+2.105431500+0.25538
- 2500+2.105392500+0.25538
- 5000+2.105335000+0.25537
- 国内价格 香港价格
- 100+2.16037100+0.26204
- 400+2.15027400+0.26082
- 1500+2.150221500+0.26081
- 2500+2.150182500+0.26081
- 5000+2.150135000+0.26080
