FKBA3004
N-Ch 30V Fast Switching MOSFETs
FETek Technology Corp.
Product Summary
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
BVDSS
RDSON
ID
30V
8.5mΩ
58A
PRPAK5X6 Pin Configuration
Description
The FKBA3004 is the high cell density trenched
N-ch MOSFETs, which provide excellent RDSON
and gate charge for most applications.
The FKBA3004 meet the RoHS and Green
Product requirement, 100% EAS guaranteed with
full function reliability approved.
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V
1
58
A
ID@TC=100℃
1
38
A
1
12
A
1
9.6
A
115
A
57.8
mJ
ID@TA=25℃
ID@TA=70℃
IDM
Pulsed Drain Current
2
EAS
Single Pulse Avalanche Energy
IAS
Avalanche Current
3
34
A
Total Power Dissipation
4
46
W
PD@TA=25℃
4
2
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
PD@TC=25℃
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
Thermal Resistance Junction-Case
Data and specifications subject to change without notice.
www.fetek.com.tw Ver : A
1
Max.
Unit
62
℃/W
2.7
℃/W
1
FKBA3004
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
2
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.027
V/℃
VGS=10V , ID=30A
6.5
8.5
VGS=4.5V , ID=15A
11
14
1.2
1.5
2.5
V
-5.8
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
m
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=30A
38
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.7
2.9
Qg
Total Gate Charge (4.5V)
12.6
17.6
4.2
5.9
VDS=15V , VGS=4.5V , ID=15A
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
5.1
7.1
Td(on)
Turn-On Delay Time
4.6
9.2
uA
nC
Rise Time
VDD=15V , VGS=10V , RG=3.3
12.2
22
Turn-Off Delay Time
ID=15A
26.6
53
Fall Time
8
16
Ciss
Input Capacitance
1317
1844
Coss
Output Capacitance
163
228
Crss
Reverse Transfer Capacitance
131
183
Min.
Typ.
Max.
Unit
58
A
115
A
1
V
9.2
nS
2
nC
Tr
Td(off)
Tf
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
Parameter
Continuous Source Current
Pulsed Source Current
2,5
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Conditions
1,5
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=30A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=25V,VGS=10V,L=0.1mH,IAS=34A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
2
FKBA3004
Typical Characteristics
100
ID Drain Current (A)
75
VGS=10V
VGS=7V
VGS=5V
50
VGS=4.5V
VGS=3V
25
1
1.5
2
2.5
VDS , Drain-to-Source Voltage (V)
3
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source
Voltage
10
12
ID =15A
VGS , Gate to Source Voltage (V)
IS -Source Current(A)
10
8
TJ=150℃ TJ=25℃
6
4
2
0.6
8
6
VDS=24V
4
2
VSD , Source-to-Drain Voltage (V)
Fig.3 Forward Characteristics of reverse
6
12
18
QG , Total Gate Charge (nC)
24
30
Fig.4 Gate-Charge Characteristics
diode
1.8
Normalized On Resistance
1.8
1.4
1.4
Normalized VGS(th)
VDS=15V
1.0
1
0.6
0.6
0.2
0.2
-50
100
TJ ,Junction Temperature (℃ )
Fig.5 Normalized VGS(th) vs. TJ
150
-50
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON vs. TJ
3
FKBA3004
10000
1000.00
F=1.0MHz
100us
1000
10.00
ID (A)
Capacitance (pF)
10us
100.00
Ciss
Coss
10ms
100ms
DC
1.00
100
Crss
0.10
TC= 2 5
Single Pulse
10
1
5
9
13
17
21
0.01
0.1
25
1
10
VDS , Drain to Source Voltage (V)
100
1000
VDS (V)
Fig.8 Safe Operating Area
Fig.7 Capacitance
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
P DM
T ON
SINGLE
T
D = TON/T
TJpeak = TC+P DMXRθJC
0.001
0.00001
0.0001
0.001
0.01
0.1
1
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
1
L x IAS2 x
2
BVDSS
BVDSS
BVDSS-VDD
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
VGS
Fig.17 Unclamped Inductive Switching Waveform
FFARMwaveform
4
