NFA200VB68M12.5*20 LO
    SAMYOUNG(韩国三莹)
NFA200VB68M12.5*20 LO 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS NFA Series 105℃ 7,000~10,000Hrs assured. Non-solvent proof. High Ripple, Long Life. For ballasts stabilizer. RoHS compliant. Halogen-free capacitors are also available. NFC NFA Long Life SPECIFICATIONS ltem Characteristics Rated Voltage Range 160~400 VDC 420~500 VDC Operating Temperature Range -40~+105℃ -25~+105℃ Capacitance Tolerance ±20%(M) Time c·v Leakage Current 1000 > 1000 (at 20℃, 120Hz) After 1 minute After 5 minutes I=0.1CV+40 I=0.03CV+15 I=0.04CV+100 I=0.02CV+25 Where, I:Max. Leakage current(㎂) C:Nominal capacitance(㎌) V:Rated voltage(VDC) (at 20℃) Dissipation Factor(Tan δ) Temperature Characteristics (Max. Impedance ratio) Load Life Shelf Life Rated Voltage(VDC) 160~250 350~500 Tanδ(Max.) 0.20 0.24 Rated Voltage(VDC) 160~250 350~400 420~500 Z(–25℃)/Z(20℃) 3 5 6 Z(–40℃)/Z(20℃) 6 6 - DIMENSIONS OF NFA Series (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 10,000 hours at 105℃. (where, 7,000 hours for Ø8, 8,000 hours for Ø10) Capacitance change ±20% of the initial value Tan δ 200% of the initial specified value Leakage current The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change Tan δ Leakage current Others (at 20℃, 120Hz) ±20% of the initial value 200% of the initial specified value 500% of the initial specified value Satisfied characteristics KS C IEC 60384-4 Unit(mm) Marking : DARK BROWN SLEEVE, SILVER INK ØD 8 10 12.5 16 18 20 22 25.4 Ød 0.6 0.6 0.6 0.8 0.8 0.8 1.0 1.0 F 3.5 5.0 5.0 7.5 7.5 7.5 10.0 10.0 ØD′ ØD+0.5 max. L′ L+1.5 max. L+2.0 max. 164 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NFA Series VDC Capacitance (㎌) 22 33 47 68 100 150 220 330 160 390 470 560 680 820 1000 22 33 47 68 100 150 200 220 330 390 470 560 820 ØD×L(㎜) 10 × 20 10 × 20 12.5 × 20 12.5 × 25 16 × 25 16 × 31.5 16 × 31.5 16 × 35.5 22 × 25 22 × 30 25.4 × 30 22 × 35 22 × 40 22 × 45 25.4 × 35 22 × 50 25.4 × 40 25.4 × 50 10 × 20 10 × 20 12.5 × 20 12.5 × 20 10 × 33 12.5 × 25 16 × 25 12.5 × 35 16 × 31.5 12.5 × 45 16 × 31.5 18 × 31.5 22 × 25 16 × 45 22 × 30 22 × 35 25.4 × 30 22 × 40 25.4 × 35 22 × 45 22 × 50 25.4 × 40 25.4 × 50 Rated Ripple Current (mArms/105℃, 120Hz) 192 236 312 409 548 724 876 1110 1130 1310 1540 1650 1730 1990 1950 2270 2240 2670 192 236 262 312 409 409 548 600 701 700 800 906 730 1100 1090 1250 1270 1440 1470 1640 1710 1680 2200 VDC Capacitance (㎌) 10 22 33 47 56 68 100 150 180 250 220 270 330 390 470 560 10 22 33 47 68 100 120 350 150 180 200 220 270 330 ØD×L(㎜) 10 × 20 12.5 × 20 12.5 × 25 12.5 × 25 10 × 33 16 × 25 16 × 31.5 18 × 25 22 × 25 18 × 31.5 22 × 30 22 × 35 25.4 × 30 20 × 40 22 × 40 25.4 × 35 22 × 45 25.4 × 40 22 × 50 25.4 × 50 10 × 20 12.5 × 20 16 × 20 16 × 25 16 × 31.5 18 × 31.5 22 × 25 22 × 30 18 × 40 25.4 × 30 22 × 35 22 × 40 25.4 × 35 22 × 45 22 × 50 25.4 × 40 25.4 × 50 Rated Ripple Current (mArms/105℃, 120Hz) 130 214 285 340 350 452 591 700 770 850 910 1060 1080 1196 1230 1260 1400 1430 1600 1860 126 207 284 364 472 591 530 620 760 740 800 880 900 970 1110 1090 1310 NFA RATED RIPPLE CURRENT MULTIPLIERS 1K 10K 50K 100K 1.25 1.50 1.60 1.75 Series Frequency Multipliers 120 Freq.(Hz) Factor 1.00 165 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NFA Series VDC Capacitance (㎌) 2.2 3.3 4.7 6.8 8.2 10 15 22 33 47 68 82 400 100 120 150 180 200 220 270 330 2.2 3.3 4.7 6.8 8.2 10 15 22 33 47 68 420 82 100 120 150 180 200 220 270 166 ØD×L(㎜) 8 × 11.5 8 × 11.5 8 × 11.5 8 × 15 8 × 20 10 × 20 10 × 20 12.5 × 25 16 × 20 16 × 25 16 × 31.5 18 × 31.5 22 × 25 18 × 35.5 18 × 40 22 × 30 18 × 40 22 × 35 25.4 × 30 20 × 40 22 × 40 25.4 × 35 22 × 45 22 × 45 22 × 50 25.4 × 40 25.4 × 50 25.4 × 50 8 × 11.5 8 × 11.5 8 × 11.5 8 × 20 10 × 16 10 × 20 10 × 25 12.5 × 20 16 × 20 16 × 25 18 × 25 16 × 31.5 22 × 25 18 × 31.5 22 × 30 18 × 40 22 × 35 25.4 × 30 18 × 45 22 × 40 25.4 × 35 22 × 45 25.4 × 40 22 × 50 25.4 × 50 Rated Ripple Current (mArms/105℃, 120Hz) 27 33 39 63 75 126 154 225 284 364 472 536 490 611 680 630 760 750 800 855 860 880 940 996 1030 1010 1220 1260 25 31 37 76 87 116 155 191 262 335 435 507 490 580 580 659 670 680 757 790 800 900 970 1030 1200 VDC Capacitance (㎌) 2.2 3.3 4.7 6.8 8.2 10 22 33 47 56 450 68 82 100 120 150 180 200 220 3.3 4.7 6.8 8.2 10 22 33 47 56 500 68 82 100 120 150 180 ØD×L(㎜) 8 × 15 10 × 16 10 × 16 10 × 20 10 × 20 10 × 20 12.5 × 20 16 × 25 12.5 × 30 16 × 31.5 18 × 25 16 × 31.5 18 × 25 18 × 31.5 22 × 25 18 × 35.5 18 × 40 22 × 30 18 × 40 22 × 35 25.4 × 30 20 × 40 22 × 40 25.4 × 35 22 × 45 25.4 × 40 22 × 50 25.4 × 50 10 × 12.5 10 × 12.5 10 × 16 10 × 20 12.5 × 20 16 × 25 18 × 20 18 × 25 18 × 31.5 18 × 31.5 22 × 25 16 × 45 18 × 35.5 22 × 30 25.4 × 30 22 × 35 22 × 40 22 × 45 25.4 × 35 25.4 × 40 22 × 50 25.4 × 50 Rated Ripple Current (mArms/105℃, 120Hz) 44 63 74 96 106 108 114 241 315 319 368 410 435 473 440 537 602 570 659 660 670 757 780 790 892 910 970 1090 52 62 83 98 120 228 230 260 393 393 390 625 550 460 540 590 620 710 690 720 827 960
NFA200VB68M12.5*20 LO 价格&库存
很抱歉,暂时无法提供与“NFA200VB68M12.5*20 LO”相匹配的价格&库存,您可以联系我们找货
