5FS1S102M6QES
5FS1S102M6QES
    DAILYWELL(德利威)
    5FS1S102M6QES
5FS1S102M6QES 数据手册
5F Series Sub-Miniature Slide Switches SPECIFICATIONS CONTACT RATING: Dependent upon contact material See Page 89. MECHANICAL LIFE: 30,000 make-and-break cycles. CONTACT RESISTANCE: 20 mȟġmax. initial @ 2-4VDC 100mA for both silver and gold plated contacts. INSULATION RESISTANCE: 1,000 Mȟġmin. IN DIELECTRIC STRENGTH: 1,000 Vrms min.@sea level. D OPERATING TEMPERATURE: -40°C to 85°C.(std) O -30°C to 85°C.(SMT) MATERIALS M Slide Switches 5F C CASE: Diallyl phthalate (DAP) (UL94v-0). HOUSING: Stainless steel or phosphor bronze,tin plated. ACTUATOR: Nylon,black std. CONTACT: Brass or copper alloy,with silver or gold plated. TERMINALS: Copper alloy,with silver and gold plated. (See Page 89) HOW TO ORDER MODEL NO. Model NO. 5FS1 SP On-None-On 5FS3 SP On-Off-On 5FD1 DP On-None-On 5FD3 DP On-Off -On ACTUATOR TERMINATIONS TERMINAL PLATING Actuator Terminal plating Q Silver R Gold C Gold over silver S102 3.10 high S202 5.00 high(SPDT only) SEAL RoHS SOLDERING Seal E EPOXY (std) N NO EPOXY Terminations M2 M5 M6 M6N M7N MZ 86 We have invented the rules www.dailywell.com.tw PC thru-hole Wire wrap Right angle, PC thru-hole Right angle, snap-in, PC thru-hole Vertical right angle, snap-in, PC thru-hole Surface mount. RoHS soldering S RoHS & Lead Free 5F Series Sub-Miniature Slide Switches SWITCH FUNCTION NO. POLES UL/CSA MODEL MODEL NO. NO. Q2511 SP 5FS1 CONNECTED TERMINALS / SCHEMATIC SWITCH FUNCTION POS.1 POS.2 POS.3 POS.1 POS.2 POS.3 ON NONE ON 2-1 N/A 2-3 2 (COMM) Q2513 5FS3 ON OFF ON 1 Q2521 5FD1 ON NONE ON 2-1,5-4 DP 2 (COMM) Q2523 5FD3 ON OFF ON 1 2(COMM) OPEN 3 3 1 3 2-3,5-6 N/A 2(COMM) 5 4 OPEN 6 1 3 5 4 6 MOM=MOMENTARY .362 9.20 .120 3.05 TRAVEL .100 2.54 .020 0.51 .400 10.16 .100 2.54 .320 8.13 .130 3.30 .040 1.02 .098 2.49 P.C. MOUNTING EPOXY SEAL .122 3.10 Slide Switches .200 5.08 5F POLE OPTIONS .100 2.54 3 2 1 3 2 1 .030 0.76 Ø.043 Ø1.09 Waterproof transparent cover SPDT Part No. Shown : 5FS1S102M2QES P.C. MOUNTING .362 9.20 .354 9.00 .122 3.10 .400 10.16 .100 2.54 EPOXY SEAL 6 5 4 .100 2.54 6 5 4 .130 3.30 .040 1.02 .100 2.54 .020 0.51 .030 0.76 3 2 1 .200 5.08 3 2 1 6 5 4 .100 2.54 Ø.043 Ø1.09 .200 5.08 DPDT Part No. Shown : 5FD1S102M2QES TERMINATION OPTIONS M2 PC Thru-hole OTHER TERMINATION OPTIONS .130 3.30 .130 3.30 EPOXY SEAL M6 Right angle P.C. Mount M6N Snap-in,Right angle P.C. Mount EPOXY SEAL .030 0.76 SP .030 0.76 .200 5.08 DP We have invented the rules www.dailywell.com.tw 87 5F Series Sub-Miniature Slide Switches M6 P.C. MOUNTING .120 3.05 TRAVEL .200 .100 5.08 2.54 .100 2.54 EPOXY SEAL .122 3.10 .020 0.51 .400 10.16 .100 2.54 .130 3.30 3 2 1 .200 5.08 1 2 3 .195 4.95 .035 0.88 .010 0.25 .200 5.08 .100 2.54 Ø.043 Ø1.09 .200 5.08 .020 0.51 .200 5.08 SPDT Slide Switches 5F Part No. Shown : 5FS1S102M6QES M6 P.C. MOUNTING .100 2.54 .122 3.10 EPOXY SEAL .100 2.54 4 5 6 .035 0.90 .354 9.00 .100 2.54 .195 4.95 .035 0.88 .010 0.25 .200 5.08 .400 10.16 .100 2.54 .130 3.30 6 5 4 3 2 1 1 2 3 1 4 .020 0.51 .100 2.54 Ø.043 Ø1.09 .100 2.54 .200 5.08 .100 2.54 .200 5.08 .200 5.08 DPDT Part No. Shown : 5FD1S102M6RES MZ P.C. MOUNTING .122 3.10 .220 5.59 .100 2.54 .200 5.08 .421 10.70 EPOXY SEAL .400 10.16 .512 13.00 .039 1.00 .039 1.00 .100 2.54 1 2 3 .079 2.00 .493 12.50 .010 0.25 .020 0.51 .047 1.20 .346 8.80 .118 3.00 .079 2.00 .346 8.80 .100 2.54 .200 5.08 .098 2.50 .032 0.80 .100 2.54 SPDT Part No. Shown : 5FS1S102MZRES M7N .200 5.08 .120 3.05 TRAVEL .100 2.54 .400 10.16 P.C. MOUNTING .362 9.20 EPOXY SEAL .122 3.10 .108 2.73 .200 5.08 3 .189 4.80 .098 2.49 .200 5.08 88 We have invented the rules www.dailywell.com.tw .200 5.08 .189 4.80 .100 2.54 1 2 3 Ø.043 Ø1.09 1 .030 0.76 .100 2.54 Part No. Shown : 5FS1S102M7NRES 3 2 1 2 .405 10.28 SPDT Only .320 8.13 5F Series Sub-Miniature Slide Switches SNAP-IN TERMINATION OPTIONS M6N Q C R Silver Gold over Silver Gold TERMINAL PLATING RATINGS Q = Silver 3 Amps with resistant load @ 120VAC or 28VDC C = Gold over silver 1 Amps with resistant load @ 250VAC R = Gold 0.4 Volt - Amps ( VA ) max. @ 20V max. ( AC or DC ) Slide Switches CONTACT PLATING 5F CONTACT MATERIAL OPTIONS SOLDERING PROCESSES MANUAL SOLDERING: Use soldering iron of 30 watts, controlled at 350°C approximately 5 seconds while applying solder. WAVE SOLDERING: Recommended Soldering Temperature: 270 ± 5°C Duration of Solder Immersion: Max 5 sec. (PCB is 1.6mm in thickness) We have invented the rules www.dailywell.com.tw 89
5FS1S102M6QES 价格&库存
很抱歉,暂时无法提供与“5FS1S102M6QES”相匹配的价格&库存,您可以联系我们找货
