EL CONNECTOR
4.5mm pitch/Disconnectable Crimp style Wire-to-wire connectors
Specifications –––––––––––––––––––
• Current rating: 10A AC, DC max.
• Voltage rating: 300V AC, DC max.
• Temperature range: -25˚C to +90˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/7m Ω max.
After environmental testing/10m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #26 to #16
0.13 to 1.25mm2
• Applicable panel thickness: 0.8 to 2.0mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Note: The current rating varies depending on the number of circuits and the
wire size used in each connector. The table below lists the current rating
as a function of the number of circuits and the wire size.
The contacts for the compact EL connector
can be easily inserted into the connector
housings. The plug housing and the
receptacle housing can be smoothly mated
even if they are mechanically distorted.
• Easy insertion and secure installation of
contacts
• A smooth connection even when pried
during mating
• Durable arm lock mechanism
• Two contact styles
• Interchangeability with ML connector
Current unit : A
Circuits
2
3
4
6
9
12
15
#16
10
10
10
8
6
6
6
#18
6
6
6
5
4
4
4
Wire size (AWG)
#20
#22
5
4
5
4
5
4
4
3
3
3
3
3
3
3
#24
4
4
4
3
2
2
2
#26
3
3
3
3
2
2
2
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
2 R75052
Panel layout and Assembly layout
A
39.2
B
C
D
A
Circuits
Dimensions A (mm)
2 ∼4
(Single-line arrangement)
10.4
4
(Double-line arrangement)
15.0
6
14.9
9∼15
19.4
Panel hole dimensions (mm)
Circuits Receptacle housing
Model No.
A
B
2
15.0
6.0
ELR-02V
3
19.7
6.0
ELR-03V
24.2
6.0
ELR-04V
4
15.6
10.6
ELR-04NV
6
19.7
10.2
ELR-06V
9
19.7
14.8
ELR-09V
12
24.2
14.8
ELR-12V
15
28.7
14.8
ELR-15V
General tolerance ±0.13 Applicable panel
thickness (mm)
C
D
6.85
5.2
6.85
5.2
6.85
5.2
11.6
5.2
11.1
5.2
15.7
5.2
15.7
5.2
15.7
5.2
0.8∼2.0
Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed.
2. The strength of the panel must be considered when punching two or more holes.
3. The connector must be inserted from the same side as the hole is punched.
1
EL CONNECTOR
Contact
Applicable wire
Model No.
1.3
Pin contact
mm2
AWG #
Insulation O.D. Q´ty / reel
(mm)
Pin contact
Socket contact
SLM-01T-P1.3E
SLF-01T-P1.3E
0.13∼0.5
26∼20
1.3∼2.7
SLM-41T-P1.3E
SLF-41T-P1.3E
0.5 ∼1.25
20∼16
1.9∼3.4
*SLM-42T-P1.3E
*SLF-42T-P1.3E
0.3+0.3∼
0.5+0.5
22+22∼
20+20
1.7+1.7∼
2.0+2.0
6,000
4,000
17.7
7.5
4.3
3.8
2.0
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
RoHS compliance
Note: 1. Contact denoted by * is used for two wires.
2. Contact JST for special products.
3. Contact JST for brass products.
Socket contact
17.7
11.3
4.3
Dies
Crimp applicator with dies
SLM-01T-P1.3E
MKS-L
SLF-01T-P1.3E
*MKS-SC
SC/SLF/M-01-13E APLSC SLF/M01-13E
SLM-42T-P1.3E
MKS-L
MK/SLF/M-42-13E APLMK SLF/M42-13E
SLF-42T-P1.3E
2.0
Applicator
Crimping
machine Crimp applicator
Contact
AP-K2N
MK/SLF/M-01-13E APLMK SLF/M01-13E
SLM-41T-P1.3E
MKS-L
MK/SLF/M-41-13E APLMK SLF/M41-13E
SLF-41T-P1.3E
*MKS-SC
SC/SLF/M-41-13E APLSC SLF/M41-13E
Note: *Strip-crimp applicator
Contact position location numbers
Contact position numbers are stamped
Plug housing
Receptacle housing
Receptacle housing
2
5
15
3
2 4
1 3
1
4
2
3
3
2
1
1
1
1
4
3
2
1
3
2
1
3
2
1
2
2
1
1
3
2
1
4 2
3 1
4
2
4
4
3
2
1
4
3
2
1
3
2
2
1
Plug housing
12
14
4
4
8
9
6
3
10
3
10
5
15
4
9
11
6
3
4
14
13
5
9
3
7
8
5
3
13
2
12
2
6
7
1
1
4
8
2
9
4
2
12
1
5
7
1
9
4
11
6
1
1
10
5
7
7
2
10
8
7
11
8
1
8
12
9
2
4
6
3
5
3
6
6
1
11
5
6
6 3
5 2
4 1
2
9 6 3
8 5 2
7 4 1
12
11
10
9
8
7
6
5
4
3
2
1
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
3 6
2 5
1 4
3 6 9
2 5 8
1 4 7
4
3
2
1
8
7
6
5
12
11
10
9
5
4
3
2
1
10
9
8
7
6
15
14
13
12
11
EL CONNECTOR
Housing
Material: PA 6, UL94V-0, white
Circuits
Voltage
rating
Current
rating
Receptacle housing(for pin contact)
Plug housing(for socket contact)
Q´ty /
bag
ELP-02V
Q´ty /
bag
10.3
ELR-02V
500
2
300V
5.6
10.3
24.6
10A
ELR-02VF
Q´ty /
bag
5.8
14.6
500
10.3
24.6
24.6
5.8
ELR-03V
10A
ELP-03V
Q´ty /
bag
14.8
300V
Q´ty /
bag
14.8
3
500
500
24.6
24.6
5.6
ELR-04V
500
14.6
5.8
ELP-04V
Q´ty /
bag
19.3
19.3
Q´ty /
bag
500
500
5.8
JST-L
24.6
10A
Q´ty /
bag
ELP-04NV
Q´ty /
bag
10.3
300V
24.6
5.6
ELR-04NV
4
14.6
10.3
10.3
24.6
ELR-04NVF
14.6
10.3
500
500
10.3
24.6
24.6
10.3
ELR-06V
8A
Q´ty /
bag
14.8
300V
ELP-06V
14.8
6
Q´ty /
bag
500
500
14.6
10.3
24.6
9.9
24.6
RoHS compliance
3
EL CONNECTOR
Housing
Circuits
Voltage
rating
Current
rating
ELR-09V
6A
ELP-09V
Q´ty /
bag
14.8
300V
Q´ty /
bag
14.8
9
500
500
14.6
14.8
24.6
24.6
14.4
ELR-12V
6A
Q´ty /
bag
19.3
300V
ELP-12V
19.3
12
Q´ty /
bag
500
500
14.6
14.8
24.6
ELR-15V
6A
ELP-15V
Q´ty /
bag
23.8
300V
Q´ty /
bag
23.8
15
24.6
14.4
500
500
14.6
14.8
24.6
14.4
24.6
RoHS compliance
Note: 1. ELR-02VF and ELR-04NVF are exclusively for free hanging. The other circuits can be used either for panel mounted or free hanging.
See "Panel layout" for the panel hole dimensions.
4
很抱歉,暂时无法提供与“ELP-12V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.18230
- 10+1.81980
- 30+1.66460
- 100+1.08830
- 500+0.93790
- 1000+0.89960
- 国内价格
- 1+2.04056
- 10+1.70165
- 30+1.55650
- 100+1.01771
- 500+0.87696
- 1000+0.84116
- 国内价格 香港价格
- 1+7.374131+0.89474
- 10+3.6749510+0.44590
- 50+2.0838250+0.25284
- 100+1.55883100+0.18914
- 500+1.20345500+0.14602
- 1000+1.138831000+0.13818
- 2000+1.082302000+0.13132
- 4000+1.041914000+0.12642
