ELXS501VSN471MA60S
ELXS501VSN471MA60S
    NCC(贵弥功)
    Radial,35x60mm
    ELXS501VSN471MA60S
ELXS501VSN471MA60S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS LXS Long life snap-ins, 105℃ LXM Series Longer life ・For solar power generation ・Endurance with ripple current : 5,000 hours at 105℃ ・Rated voltage range : 160 to 600V ・Downsized from LXQ series ・Non solvent resistant type ・RoHS2 Compliant LXS Downsizing LHS Longer life KMS ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +105℃ 160 to 600Vdc ±20% (M) I≦3 CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 160 to 400V 420 to 600V tanδ (Max.) 0.15 0.20 Rated voltage (Vdc) 160 to 400V 420 to 600V Z(-25℃)/Z(+20℃) 4 8 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 5 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value (500Vdc : ≦ 250%, 550, 600Vdc : ≦ 300%) Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±15% of the initial value D.F. (tanδ) ≦150% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] ●Terminal Code : VS (φ22 to φ35) : Standard Sleeve (PET : Brown) Negative mark PC board pin-out (View from Solder side) Code : LI (φ30,φ35) Sleeve (PET : Brown) Negative mark L±2.5 Vent φD+1max. φD+1max. 10 2-φ2 4.0±0.5 PC board pin-out (View from Solder side) 2-1.2×6 4.2±0.5 ●Terminal Vent 5±0.5 L±2.5 4.5±1 14.2±1 The standard design has no plastic disc. ◆PART NUMBERING SYSTEM 1 2 3 4 E LXS 5 6 7 8 9 10 VS N 11 12 13 14 M 15 16 17 18 S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 330µF:331, 2,200µF:222) Dummy terminal code Terminal code(VS, LI) Voltage code (ex. 160V:161, 315V:3B1, 450V:451) Series code Category Please refer to "Product code guide (snap-in type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Long life snap-ins, 105℃ LXSSeries ◆STANDARD RATINGS WV (Vdc) 160 180 200 Cap (µF) Rated ripple Case size current tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 470 680 680 820 820 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,200 1,500 1,500 1,800 1,800 1,800 2,200 2,200 2,200 2,700 2,700 3,300 390 560 560 680 820 820 820 820 1,000 1,000 1,000 1,000 1,000 1,200 1,200 1,500 1,500 1,500 1,800 1,800 2,200 2,200 2,200 2,700 390 470 560 560 680 680 680 820 820 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,200 1,500 1,500 22 ×25 22 ×30 25.4×25 22 ×35 25.4×30 22 ×40 22 ×45 25.4 ×35 30 ×25 22× 50 25.4× 40 30× 30 35 × 25 25.4× 45 30 × 35 25.4× 50 30 ×40 35 ×30 30 ×45 30 ×50 35 ×35 35× 40 35 × 45 35 × 50 22 × 25 22 × 30 25.4×25 22 ×35 22 ×40 25.4×30 25.4×35 30 ×25 22 ×45 22 ×50 25.4×40 30 ×30 35 ×25 25.4×45 30 ×35 25.4×50 30 ×40 35 ×30 30 ×45 35 ×35 30 ×50 35 ×40 35 ×45 35 ×50 22 ×25 22 ×30 22 ×35 25.4×25 22 ×40 25.4×30 30 × 25 22 × 45 25.4× 35 22 ×50 25.4×40 30 ×30 35 ×25 25.4 ×45 25.4 ×50 30 ×35 35 ×30 30× 40 30 × 45 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.47 1.86 1.84 2.09 2.08 2.35 2.40 2.40 2.50 2.69 2.68 2.77 2.91 3.05 3.17 3.40 3.57 3.62 4.05 4.11 4.07 4.67 4.78 5.40 1.34 1.68 1.67 1.90 2.13 2.08 2.17 2.26 2.40 2.45 2.45 2.52 2.66 2.73 2.83 3.10 3.26 3.31 3.66 3.68 4.11 4.22 4.32 4.88 1.34 1.54 1.72 1.67 1.94 1.89 2.06 2.17 2.17 2.45 2.45 2.52 2.66 2.73 2.78 2.83 2.96 3.26 3.34 Part No. ELXS161VSN471MP25S ELXS161VSN681MP30S ELXS161VSN681MQ25S ELXS161VSN821MP35S ELXS161VSN821MQ30S ELXS161VSN102MP40S ELXS161VSN102MP45S ELXS161VSN102MQ35S ELXS161VSN102MR25S ELXS161VSN122MP50S ELXS161VSN122MQ40S ELXS161VSN122MR30S ELXS161VSN122MA25S ELXS161VSN152MQ45S ELXS161VSN152MR35S ELXS161VSN182MQ50S ELXS161VSN182MR40S ELXS161VSN182MA30S ELXS161VSN222MR45S ELXS161VSN222MR50S ELXS161VSN222MA35S ELXS161VSN272MA40S ELXS161VSN272MA45S ELXS161VSN332MA50S ELXS181VSN391MP25S ELXS181VSN561MP30S ELXS181VSN561MQ25S ELXS181VSN681MP35S ELXS181VSN821MP40S ELXS181VSN821MQ30S ELXS181VSN821MQ35S ELXS181VSN821MR25S ELXS181VSN102MP45S ELXS181VSN102MP50S ELXS181VSN102MQ40S ELXS181VSN102MR30S ELXS181VSN102MA25S ELXS181VSN122MQ45S ELXS181VSN122MR35S ELXS181VSN152MQ50S ELXS181VSN152MR40S ELXS181VSN152MA30S ELXS181VSN182MR45S ELXS181VSN182MA35S ELXS181VSN222MR50S ELXS181VSN222MA40S ELXS181VSN222MA45S ELXS181VSN272MA50S ELXS201VSN391MP25S ELXS201VSN471MP30S ELXS201VSN561MP35S ELXS201VSN561MQ25S ELXS201VSN681MP40S ELXS201VSN681MQ30S ELXS201VSN681MR25S ELXS201VSN821MP45S ELXS201VSN821MQ35S ELXS201VSN102MP50S ELXS201VSN102MQ40S ELXS201VSN102MR30S ELXS201VSN102MA25S ELXS201VSN122MQ45S ELXS201VSN122MQ50S ELXS201VSN122MR35S ELXS201VSN122MA30S ELXS201VSN152MR40S ELXS201VSN152MR45S WV (Vdc) 200 250 315 400 Cap (µF) Rated ripple Case size current tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 1,500 1,800 1,800 2,200 2,700 270 330 390 390 470 470 560 560 560 680 680 680 680 820 820 820 820 1,000 1,200 1,200 1,200 1,200 1,500 1,800 180 220 220 270 270 330 330 390 390 390 470 470 470 470 560 560 560 680 680 680 820 820 1,000 1,200 120 150 180 180 220 220 220 270 270 270 330 330 330 390 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 25.4 × 50 30 × 35 35 × 30 30 × 40 30 × 45 30 × 50 35 × 35 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 25.4 × 25 22 × 35 25.4 × 30 22 × 40 30 × 25 22 × 45 22 × 50 25.4 × 35 25.4 × 40 25.4 × 45 30 × 30 35 × 25 25.4 × 50 30 × 35 35 × 30 30 × 40 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 30 × 25 22 × 45 22 × 50 25.4 × 35 25.4 × 40 30 × 30 35 × 25 25.4 × 45 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 3.36 3.72 3.81 4.32 4.88 1.11 1.29 1.44 1.40 1.61 1.57 1.79 1.79 1.87 2.02 2.02 2.08 2.19 2.26 2.29 2.34 2.45 2.66 2.99 3.04 3.00 3.11 3.56 3.98 0.95 1.10 1.10 1.24 1.25 1.40 1.43 1.56 1.59 1.57 1.76 1.79 1.73 1.82 1.99 1.93 2.02 2.19 2.25 2.26 2.51 2.57 2.91 3.25 0.77 0.90 1.02 0.99 1.15 1.13 1.17 1.29 1.32 1.30 1.47 1.45 1.52 1.63 Part No. ELXS201VSN152MA35S ELXS201VSN182MR50S ELXS201VSN182MA40S ELXS201VSN222MA45S ELXS201VSN272MA50S ELXS251VSN271MP25S ELXS251VSN331MP30S ELXS251VSN391MP35S ELXS251VSN391MQ25S ELXS251VSN471MP40S ELXS251VSN471MQ30S ELXS251VSN561MP45S ELXS251VSN561MQ35S ELXS251VSN561MR25S ELXS251VSN681MP50S ELXS251VSN681MQ40S ELXS251VSN681MR30S ELXS251VSN681MA25S ELXS251VSN821MQ45S ELXS251VSN821MQ50S ELXS251VSN821MR35S ELXS251VSN821MA30S ELXS251VSN102MR40S ELXS251VSN122MR45S ELXS251VSN122MR50S ELXS251VSN122MA35S ELXS251VSN122MA40S ELXS251VSN152MA45S ELXS251VSN182MA50S ELXS3B1VSN181MP25S ELXS3B1VSN221MP30S ELXS3B1VSN221MQ25S ELXS3B1VSN271MP35S ELXS3B1VSN271MQ30S ELXS3B1VSN331MP40S ELXS3B1VSN331MR25S ELXS3B1VSN391MP45S ELXS3B1VSN391MP50S ELXS3B1VSN391MQ35S ELXS3B1VSN471MQ40S ELXS3B1VSN471MQ45S ELXS3B1VSN471MR30S ELXS3B1VSN471MA25S ELXS3B1VSN561MQ50S ELXS3B1VSN561MR35S ELXS3B1VSN561MA30S ELXS3B1VSN681MR40S ELXS3B1VSN681MR45S ELXS3B1VSN681MA35S ELXS3B1VSN821MR50S ELXS3B1VSN821MA40S ELXS3B1VSN102MA45S ELXS3B1VSN122MA50S ELXS401VSN121MP25S ELXS401VSN151MP30S ELXS401VSN181MP35S ELXS401VSN181MQ25S ELXS401VSN221MP40S ELXS401VSN221MQ30S ELXS401VSN221MR25S ELXS401VSN271MP45S ELXS401VSN271MP50S ELXS401VSN271MQ35S ELXS401VSN331MQ40S ELXS401VSN331MR30S ELXS401VSN331MA25S ELXS401VSN391MQ45S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Long life snap-ins, 105℃ LXSSeries ◆STANDARD RATINGS WV (Vdc) 400 420 450 Cap (µF) Rated ripple Case size current tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 390 390 390 470 470 560 560 560 680 820 100 120 120 150 180 180 180 220 220 220 270 270 270 270 330 330 330 390 390 390 470 470 560 680 82 120 120 120 150 150 180 180 180 220 220 25.4×50 30 ×35 35 ×30 30 ×40 35× 35 30× 45 30 × 50 35 × 40 35 ×45 35 ×50 22 ×25 22 ×30 25.4 ×25 22× 35 22 × 40 25.4× 30 30 × 25 22 × 45 22 ×50 25.4×35 25.4×40 25.4×45 30 ×30 35 ×25 25.4 ×50 30 ×35 35 ×30 30 ×40 30 ×45 35 ×35 30 ×50 35 ×40 35 ×45 35 ×50 22 ×25 22 ×30 22 ×35 25.4×25 22 ×40 25.4×30 22 ×45 25.4×35 30 ×25 22 ×50 25.4×40 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 1.66 1.61 1.68 1.82 1.88 2.04 2.07 2.13 2.40 2.69 0.70 0.81 0.81 0.93 1.04 1.02 1.06 1.17 1.20 1.18 1.33 1.36 1.31 1.38 1.52 1.48 1.55 1.66 1.70 1.71 1.90 1.95 2.17 2.45 0.64 0.81 0.83 0.81 0.94 0.93 1.06 1.06 1.06 1.20 1.20 Part No. ELXS401VSN391MQ50S ELXS401VSN391MR35S ELXS401VSN391MA30S ELXS401VSN471MR40S ELXS401VSN471MA35S ELXS401VSN561MR45S ELXS401VSN561MR50S ELXS401VSN561MA40S ELXS401VSN681MA45S ELXS401VSN821MA50S ELXS421VSN101MP25S ELXS421VSN121MP30S ELXS421VSN121MQ25S ELXS421VSN151MP35S ELXS421VSN181MP40S ELXS421VSN181MQ30S ELXS421VSN181MR25S ELXS421VSN221MP45S ELXS421VSN221MP50S ELXS421VSN221MQ35S ELXS421VSN271MQ40S ELXS421VSN271MQ45S ELXS421VSN271MR30S ELXS421VSN271MA25S ELXS421VSN331MQ50S ELXS421VSN331MR35S ELXS421VSN331MA30S ELXS421VSN391MR40S ELXS421VSN391MR45S ELXS421VSN391MA35S ELXS421VSN471MR50S ELXS421VSN471MA40S ELXS421VSN561MA45S ELXS421VSN681MA50S ELXS451VSN820MP25S ELXS451VSN121MP30S ELXS451VSN121MP35S ELXS451VSN121MQ25S ELXS451VSN151MP40S ELXS451VSN151MQ30S ELXS451VSN181MP45S ELXS451VSN181MQ35S ELXS451VSN181MR25S ELXS451VSN221MP50S ELXS451VSN221MQ40S WV (Vdc) 450 500 550 600 Cap (µF) Rated ripple Case size current tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 220 220 270 270 270 270 330 390 390 390 470 470 560 100 120 120 150 180 180 220 220 270 270 330 390 470 120 150 180 180 220 220 270 330 390 120 120 150 150 180 180 220 220 270 330 30 × 30 35 × 25 25.4 × 45 25.4 × 50 30 × 35 35 × 30 30 × 40 30 × 45 30 × 50 35 × 35 35 × 40 35 × 45 35 × 50 30 × 25 30 × 30 35 × 25 30 × 35 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 35 × 60 30 × 30 30 × 35 30 × 40 35 × 30 30 × 50 35 × 40 35 × 45 35 × 50 35 × 60 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 30 × 60 35 × 45 35 × 50 35 × 60 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 1.18 1.24 1.36 1.38 1.34 1.40 1.52 1.70 1.73 1.71 1.95 1.99 2.22 0.82 0.91 0.88 1.04 1.17 1.10 1.33 1.23 1.50 1.42 1.60 1.78 2.03 0.91 1.04 1.17 1.10 1.35 1.28 1.45 1.64 1.85 0.96 0.95 1.10 1.07 1.22 1.22 1.40 1.38 1.56 1.79 Part No. ELXS451VSN221MR30S ELXS451VSN221MA25S ELXS451VSN271MQ45S ELXS451VSN271MQ50S ELXS451VSN271MR35S ELXS451VSN271MA30S ELXS451VSN331MR40S ELXS451VSN391MR45S ELXS451VSN391MR50S ELXS451VSN391MA35S ELXS451VSN471MA40S ELXS451VSN471MA45S ELXS451VSN561MA50S ELXS501VSN101MR25S ELXS501VSN121MR30S ELXS501VSN121MA25S ELXS501VSN151MR35S ELXS501VSN181MR40S ELXS501VSN181MA30S ELXS501VSN221MR45S ELXS501VSN221MA35S ELXS501VSN271MR50S ELXS501VSN271MA40S ELXS501VSN331MA45S ELXS501VSN391MA50S ELXS501VSN471MA60S ELXS551VSN121MR30S ELXS551VSN151MR35S ELXS551VSN181MR40S ELXS551VSN181MA30S ELXS551VSN221MR50S ELXS551VSN221MA40S ELXS551VSN271MA45S ELXS551VSN331MA50S ELXS551VSN391MA60S ELXS601VSN121MR40S ELXS601VSN121MA30S ELXS601VSN151MR45S ELXS601VSN151MA35S ELXS601VSN181MR50S ELXS601VSN181MA40S ELXS601VSN221MR60S ELXS601VSN221MA45S ELXS601VSN271MA50S ELXS601VSN331MA60S ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) 160 to 250Vdc 315 to 450Vdc 500 to 600Vdc 50 0.81 0.77 0.70 120 1.00 1.00 1.00 300 1.17 1.16 1.16 1k 1.32 1.30 1.30 10k 1.45 1.41 1.41 50k 1.50 1.43 1.43 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
ELXS501VSN471MA60S 价格&库存
很抱歉,暂时无法提供与“ELXS501VSN471MA60S”相匹配的价格&库存,您可以联系我们找货
ELXS501VSN471MA60S
    • 1+71.47440
    • 10+64.53000
    • 30+52.71480
    库存:17
